TSB 12-02-17 - Steering issue - New TSB? - Page 17 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-09-2012, 05:19 PM   #161
pinkerton81
Fan#: 99033
What I Drive: 2012 Focus SE
FF Reputation: 1 pinkerton81 Good Standing Member
When was your Focus built? I'm curious to know how you can confirm it has the updated rack. Also, I can say that the steering does require some adapting. My Focus had a very pronounced "wander" before the rack was replaced and now drives fine. However, it does track a little different that any other car I've driven. I've heard this about other EPAS cars too.
pinkerton81 is offline
Old 07-10-2012, 02:29 PM   #162
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,388, Level 36
Points: 3,388, Level: 36 Points: 3,388, Level: 36 Points: 3,388, Level: 36
Level Up 26% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
Originally Posted by sabelson View Post
I am having the same steering problems in my 2012 Focus which I recently purchased and was built after the TSB. I took it back to the dealer who recalibrated the steering and then explained to me how I needed to get used to the electronic unit which is different from the previous mechanical type. While the car is racking somewhat better, it still wanders and is difficult to correct.
I have the SE sedan with the sport package...
Congrats on your Focus purchase! You can obtain a second opinion if you feel the steering hasn't improved to your liking. If you'd prefer, please PM me your VIN, mileage, phone #, and servicing dealer; I'll escalate this to your area's Customer Service Manager.
I have the exact same model and feel that Drift Control helps in continuously correcting for any road irregularities. This system also needs to "learn" and adapt to your steering conditions. Along with EPAS, this feature should help reduce the amount of minor steering corrections you will make.
Originally Posted by Pretherius View Post
Honestly it has taken literally months for me get used to the steering on this car. It took me a long time to decide there isn't something wrong with mine.
The steering is SO tight and has such a high ratio... it's a totally different game from your typical family sedan with hydraulic steering.
You bring up a good point. To me, the handling is crisp and tight. The 14.7:1 steering ratio means we don't have to turn the wheel very far to go around a tight corner. The EPAS makes it much more fluid too.
Originally Posted by pinkerton81 View Post
...I can say that the steering does require some adapting. My Focus had a very pronounced "wander" before the rack was replaced and now drives fine. However, it does track a little different that any other car I've driven. I've heard this about other EPAS cars too.
It also depends on how fast you're driving. At higher speeds, EPAS delivers less steering assist for more confident control. In addition, the automatic Drift Control feature is learning as you drive. It'll adapt to any conditions that can cause your Focus to pull left or right.
Thanks for posting in this thread; keep it going!
Take it easy,
Thomas
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 07-10-2012, 03:09 PM   #163
Kramer2K
Fan#: 99894
What I Drive: 2012 White SEL
FF Reputation: 1 Kramer2K Good Standing Member
^ That's interesting input. Thanks for the information.
I've had my 2012 SEL for about a month now and recently went on my first road trip, which entailed plenty of highway driving. I have to say, the driving experience was horrible! The "breakover" issue was immediately noticeable and had my passenger giving me looks every 10 minutes, as it appeared I was over-correcting my steering constantly. It's as if I couldn't get the car tracking straight down the middle of the road. I'd almost get it there, then the steering wheel would slightly bump over to either side of straight.
The build date of my car is July 2011, so I'm wondering if anything has been done on the steering components of my car. I need to make an appointment at the local dealership I suppose. I am so, so hopeful they can get it straightened out (pardon the pun :p ), b/c the car is enjoyable in almost every other aspect (SYNC not withstanding. Please default to last source mode!!!!)
Kramer2K is offline
Old 07-10-2012, 03:14 PM   #164
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
I assume you meant My Ford Touch (MFT)? The current Sync software seems to work fairly well.
Hatch Nation #90
TboneZX3 is offline
Old 07-10-2012, 04:39 PM   #165
Kramer2K
Fan#: 99894
I don't want to steer the thread away from it's original intent, but no, I meant SYNC. My SYNC system (non-MFT) defaults to Line In every damn time I go to AUX mode. I want it to default to Bluetooth Audio or USB if that is what I used when I last exited the car.
/hijack
Steering...steering...TSB...
Kramer2K is offline
Old 07-13-2012, 01:06 PM   #166
gzrfun
Fan#: 93746
What I Drive: 2012 Oxford White SE 5spd HB Sport
Points 33, Level 1
Points: 33, Level: 1 Points: 33, Level: 1 Points: 33, Level: 1
Level Up 66% Completed
FF Reputation: 1 gzrfun Good Standing Member
My 2012 SE 5spd HB sport has the “breakover force problem”. The car will start to drift left or right and you need to apply a increased effort to turn the steering wheel to correct for the drift. The problem becomes amplified because the increase in steering effort results in an over correction that then needs to be reversed to straighten the vehicle. “PING PONG EFFECT”
Took the car to the dealer yesterday and they had checked my vin#, which showed that the TSB 12-02-17 did apply. That is the end of the discussion about the need to perform the work. The Ford Factory engineers and service departments have determined that there is a problem with the affected cars and the TSB was generated to correct the problem.
gzrfun is offline
Old 07-13-2012, 01:32 PM   #167
kjl2012
Fan#: 97883
What I Drive: 2012 se black
Points 81, Level 1
Points: 81, Level: 1 Points: 81, Level: 1 Points: 81, Level: 1
Level Up 62% Completed
FF Reputation: 1 kjl2012 Good Standing Member
I just had that done and waited three weeks for the parts to come in. It did correct the steering.
kjl2012 is offline
Old 07-13-2012, 08:13 PM   #168
gzrfun
Fan#: 93746
Points 33, Level 1
kjl2012,
Good to hear that the TSB did solve the problem. I'm waiting for the parts so my car can be fixed.
Here is a question for everyone: HOW SHOULD THE STEERING WORK?
I drove my 95 Escort with hydraulic power steering today and noted how it worked. The Escort is clearly a pleasure to steer compared to my new Focus. The Escort requires minimum effort to make a small change in steering, as you turn the steering wheel more the effort required increases. There is a direct relationship between steering effort and how much the wheel is turned. THIS IS HOW THE STEERING SHOULD WORK.
If your Focus's ELECTRIC POWER STEERING requires a significant effort for small steering corrections - it is not working properly.
gzrfun is offline
Old 07-16-2012, 05:16 PM   #169
Kramer2K
Fan#: 99894
Well I just returned home from dropping off my Focus for the steering issue.
Fingers are crossed that they can recognize the issue when it happens.
Upon calling, the gentleman said he's never heard of any steering issues with the Focus, so I'm not sure what to expect here. I just hope it gets all straightened out. And if they need to order parts, what then? Will I have to be in a rental car that long?
The short 10 minute drive home in the crappy Nissan Sentra rental has me missing my sweet Focus already!
I'll hear from them tomorrow once they can diagnose it.
To be continued...
Kramer2K is offline
Old 07-17-2012, 02:32 PM   #170
FordService
Official Ford Rep
Fan#: 79824
Forum Activity 25%
I've had my 2012 SEL for about a month now and recently went on my first road trip, which entailed plenty of highway driving. I have to say, the driving experience was horrible! The "breakover" issue was immediately noticeable and had my passenger giving me looks every 10 minutes, as it appeared I was over-correcting my steering constantly. It's as if I couldn't get the car tracking straight down the middle of the road. I'd almost get it there, then the steering wheel would slightly bump over to either side of straight...
...I just hope it gets all straightened out. And if they need to order parts, what then? Will I have to be in a rental car that long?...
It's my pleasure! If you'd like, please PM me your VIN, mileage, phone #, and dealer info; I'll shoot these details to your region's Customer Service Manager for review.
Originally Posted by gzrfun View Post
kjl2012,
Here is a question for everyone: HOW SHOULD THE STEERING WORK?...
...If your Focus's ELECTRIC POWER STEERING requires a significant effort for small steering corrections - it is not working properly.
Hey guys -
We try very hard to expedite the proper manufacture and shipment of parts. Thanks for hanging in there, kjl2012!
Did your dealer give you a parts ETA, gzrfun? I'd like to fill in your region's CSM; please send me your VIN, mileage, phone #, and dealer info.
The Electric Power-Assisted Steering offers light, responsive steering around town and for parking. At higher speeds, EPAS delivers less steering assist for more confident control.
With regards,
Thomas
FORD SERVICE
p: 800.392.FORD
