2012 Focus Timing belt or chain???? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-10-2012, 11:32 AM   #11
twinkymcnugget
Fan#: 93345
What I Drive: 2006 Ford Windstar Sport
FF Reputation: 1 twinkymcnugget Good Standing Member
Originally Posted by Rat Fink View Post
Chain, with no adjustments (hydraulic tensioners). I REALLY REALLY hope our tensioners are made with a flat machined surface mated to the block like the proven way its been done for years (haven't pulled one apart yet and the service manual doesn't really say) because the newer 5.4Ls (I think 2008 was the changeover) in the F150s are turning into a money pit with their crap tensioners with the flimsy silicone bead on the tensioners blowing out and causing loss of oil pressure to the heads and all kinds of cam phaser problems. They went from a steel tensioner with flat machined surface to a phenolic tensioner body with a crappy printed seal. We see at least 1 per week. There was a "hell week" last summer where our relatively small shop did 6 engines in one week because of this. I was happy because I did 4 of them. LOL
lol oh i love those. they make me money so im not complaining haha
Ford Mechanic
85 chev, built motor, 3/4tonne axles, 9inch lift, 38.5 boggers
06 SS S/C Cobalt, 3" pully, 3" zzp intake, 3" cat back, 42.5lb inj, Hptuners, wide band, duel pass, intake spacer, meth injection, exedy spec I
12 Focus Titanium
twinkymcnugget is offline
Old 03-10-2012, 11:49 AM   #12
AJ_BS
Fan#: 95722
What I Drive: 2012
FF Reputation: 1 AJ_BS Good Standing Member
Good thread. Thanks for the info guys.
AJ_BS is offline
Old 03-10-2012, 11:57 AM   #13
greg hazlett
Fan#: 93486
What I Drive: 2012 Black Ford Focus SE Hatchback
FF Reputation: 3 greg hazlett Good Standing Member
Don't forget about the lovely 2 piece spark plugs Ford put in them as well!
greg hazlett is offline
Old 03-10-2012, 12:02 PM   #14
jvillareal78
jvillareal78's Avatar
Fan#: 95766
What I Drive: 2012 White Platinum Titanium HB
FF Reputation: 1 jvillareal78 Good Standing Member
Here is a nice PDF that shows the Direct Injection engine. Just the main basics of it http://media.ford.com/images/10031/2..._DI_Engine.pdf
Although its funny it says it is E85 capable, but right on my gas cap it shows no E85
jvillareal78 is offline
Old 03-10-2012, 01:04 PM   #15
Eurofordfan
Fan#: 87186
What I Drive: 1985 Moto Guzzi T5 850 NT
FF Reputation: 1 Eurofordfan Good Standing Member
Looking at the cutaway, it looks to me like the valve actuation is DAMB (Direct-Acting Mechanical Bucket) and the chain looks to be a multiplate chain, like a Morse HyVo. Not sure what the longevity of that type of chain is. I do know that with a chain drive, it seems to me that the camshaft phasors could leak a bit, and it would not end up "polluting" anything (e.g. the Fiesta, with phasers, and with a timing belt -- that cannot stand to get oil on it).
The DAMB system, for the valves.... it is possible that the buckets are changeable (like they were on the previous model line of Toyota Corolla) - so that valve clearance can be adjusted. Also, on the Ford GDI engine -- it may be that they are not adjustable... but if not, how could you do a valve grind and then adjust....
Anyone have any idea about this?
I personally like the non-hydraulic-tappet clearance engines, 'cause though I do go out of my way to prevent sludge build-up-- invariably the hydraulics do get sludged-up and start tapping. The non-hydraulics type of engine make more tapping sounds when cold, but never suffer collapsed lifters. I prefer these.
Final word -- re belt versus chain.... I don't totally poo poo the belts, though with phasers, they may be a problem like on the Fiesta. Belts are quieter, and though the repair interval is shorter, generally folks probably never have to replace the "sprockets". On a timing chain engine, it is folly NOT to replace sprockets when the chain is replaced. All wear together. So, though a belt engine needs more-often attention, the ease of changeout is probably less. BTW, that is not to say that the oil seals don't need replacement, though -- and they are a bear to get at and NOT damage the sealing surface on the shaft... and also the sealing surfaces can wear.... don't get me started....
Eurofordfan is offline
Old 03-10-2012, 01:05 PM   #16
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,299, Level 28
Points: 2,299, Level: 28 Points: 2,299, Level: 28 Points: 2,299, Level: 28
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 4%
FF Reputation: 13 BetaDnB Great Standing Member
Don't even start that here. There's already a thread dedicated to that. This is about the Focus having a belt or chain.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 03-10-2012, 01:44 PM   #17
Eurofordfan
Fan#: 87186
Originally Posted by Eurofordfan View Post
Looking at the cutaway, it looks to me like the valve actuation is DAMB (Direct-Acting Mechanical Bucket) and the chain looks to be a multiplate chain, like a Morse HyVo. .... The DAMB system, for the valves.... it is possible that the buckets are changeable (like they were on the previous model line of Toyota Corolla) - so that valve clearance can be adjusted. Also, on the Ford GDI engine -- it may be that they are not adjustable... but if not, how could you do a valve grind and then adjust....
My bad, folks.... Looking closely at the pdf, it appears that this is a shim-over-bucket system. The shims are to be changed out at (long) interval. This is certainly not a bad system... and is the same as Fiat used on the 124 Sport and the Fiat 128 -- and that Ford used on the first generation SHO. All you need is the cheap, special valve bucket depressor tool, to be able to flip out and change the clearance adjusting shim... Happiness!
Old 03-10-2012, 01:44 PM   #18
jvillareal78
Fan#: 95766
Wow did not realize I "started" anything here, was just pointing out an inconsistency I noticed. Maybe anyone else notices one they would point it out. But thanks for being so rude to new members Especially since your only post has nothing to do at will with the subject
Old 03-10-2012, 06:58 PM   #19
jbird1955
jbird1955's Avatar
Fan#: 48235
What I Drive: 2014 Tuxedo Black Ti Hatch
Points 788, Level 14
Points: 788, Level: 14 Points: 788, Level: 14 Points: 788, Level: 14
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 jbird1955 Good Standing Member
This thread has me curious. As it is a chain does that mean its a zero clearance head as well?
Joe
Ford Focus 2014 Hatchback 300A Titanium w/ Moonroof
Tuxedo Black Metallic
jbird1955 is offline
Old 03-10-2012, 08:12 PM   #20
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
No shims, only buckets as per the service manual. The buckets are different thicknesses as required to maintain the clearance spec. So...if you are ever disassembling one of these engines you'll want to mark the location of each bucket before taking it apart. There's a number stamped into each bucket that relates to the thickness of them. Its not a new thing Ford has done, as the similar setup is currently used in the 3.5/3.7 and others with very good track records.
Joe
Yep, interference engine.
Rat Fink is offline
