2012 Focus Timing belt or chain???? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-10-2012, 02:04 AM   #1
focusnfuture
Fan#: 95807
What I Drive: 2008 matrix
FF Reputation: 1 focusnfuture Good Standing Member
One of the things I like about my Matrix is that it has a timing chain, not a belt that needs to be changed every 80,000 miles, etc. With me putting about 30K miles per year, I'd be changing the belt quite often.
So, what does the focus have and if a belt, when does it need to be changed??? Thanks
focusnfuture is offline
Old 03-10-2012, 02:33 AM   #2
GO.army.1969
GO.army.1969's Avatar
Fan#: 69605
What I Drive: 2008 Vapor Silver Coupe 5 speed
Points 2,851, Level 32
Points: 2,851, Level: 32 Points: 2,851, Level: 32 Points: 2,851, Level: 32
Level Up 68% Completed
FF Reputation: 15 GO.army.1969 Great Standing Member
Chain
NW Posse#10 Team Duratec#69
F2 Header, Steath Exhaust, CAI, AR103, Tuned by Randy Fswerks, DGR Coil Overs
DOMINANT front and rear LCA DOMINANT endlinks Massive toe and camber arms
GO.army.1969 is offline
Old 03-10-2012, 05:16 AM   #3
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,789, Level 78
Points: 14,789, Level: 78 Points: 14,789, Level: 78 Points: 14,789, Level: 78
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 18%
FF Reputation: 16 Elizabeth Great Standing Member
Yup second CHAIN.
Elizabeth is offline
Old 03-10-2012, 08:35 AM   #4
JCH841
JCH841's Avatar
Fan#: 79303
What I Drive: 2013 Blue ST3
Points 906, Level 16
Points: 906, Level: 16 Points: 906, Level: 16 Points: 906, Level: 16
Level Up 6% Completed
FF Reputation: 3 JCH841 Good Standing Member
Duratecs have a chain. One of the reasons I dropped the diesel VW from consideration. All that technology and still a belt? Not exactly the same (actually longer chains) but my F-150 has 185,000 miles on its SOHC chains and runs perfectly. You're on the right thought track.
Growing old is unavoidable. Growing up is optional.
JCH841 is offline
Old 03-10-2012, 10:25 AM   #5
dasilvarsa
dasilvarsa's Avatar
Fan#: 89551
What I Drive: 2012 2.0 Gdi Trend
FF Reputation: 2 dasilvarsa Good Standing Member
Buy a Focus and join the Chaingang.
2012 Focus 2.0 GDI Trend (RHD Euro Focus with US Engine)
dasilvarsa is offline
Old 03-10-2012, 10:40 AM   #6
AJ_BS
Fan#: 95722
What I Drive: 2012
FF Reputation: 1 AJ_BS Good Standing Member
What is the interval? 100k miles
AJ_BS is offline
Old 03-10-2012, 10:50 AM   #7
voip-ninja
Fan#: 87642
What I Drive: 2004 Audi A4 Quattro
FF Reputation: 1 voip-ninja Good Standing Member
The timing chain does not have an interval, it's designed to last the life of the car. Although it is possible it might need periodic adjustment if it starts to make noise, etc.
voip-ninja is offline
Old 03-10-2012, 10:57 AM   #8
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
You replace the chain when you rebuild the engine, or if it lasts longer than 200k miles. It's the same as other chains- like some Nissans, for example.
I disagree that belts are lower tech than chains. Chains were first, although shorter on push-rod engines. Chains have a problem with twisting out of shape at high speed, which is why you have tensioners on chain setups. This is due to weight and centrifugal forces. Belts don't have as much weight, much less friction, require no oiling, but don't have as secure of a "grab" as a chain through a sprocket. Those have tensioners and guides also to prevent hopping. A belt can be made to last as long as a chain- ask any BMW owner- their belts are nearly 1 1/2" wide and last 200k + miles. The problem is just that- in order for a belt to be made to last as long as a chain, it takes up 5x the space of the chain. Using a chain allows Ford and Nissan to take up the excess space a belt would use with more space for wider cylinders. These engines are huge anyway. IDK If any of you are old enough to realize it, but a freaking 2.0 GDI engine is not much smaller than an old 302 in physical size. It's surely lighter, but these engines are large- go check out the old pushrod 4 cyls that are out there- those are tiny in comparison.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-10-2012, 11:30 AM   #9
twinkymcnugget
Fan#: 93345
What I Drive: 2006 Ford Windstar Sport
FF Reputation: 1 twinkymcnugget Good Standing Member
chain and as per ford thirs no service intervals. ;)
Ford Mechanic
85 chev, built motor, 3/4tonne axles, 9inch lift, 38.5 boggers
06 SS S/C Cobalt, 3" pully, 3" zzp intake, 3" cat back, 42.5lb inj, Hptuners, wide band, duel pass, intake spacer, meth injection, exedy spec I
12 Focus Titanium
twinkymcnugget is offline
Old 03-10-2012, 11:31 AM   #10
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
Chain, with no adjustments (hydraulic tensioners). I REALLY REALLY hope our tensioners are made with a flat machined surface mated to the block like the proven way its been done for years (haven't pulled one apart yet and the service manual doesn't really say) because the newer 5.4Ls (I think 2008 was the changeover) in the F150s are turning into a money pit with their crap tensioners with the flimsy silicone bead on the tensioners blowing out and causing loss of oil pressure to the heads and all kinds of cam phaser problems. They went from a steel tensioner with flat machined surface to a phenolic tensioner body with a crappy printed seal. We see at least 1 per week. There was a "hell week" last summer where our relatively small shop did 6 engines in one week because of this. I was happy because I did 4 of them. LOL
Rat Fink is offline
