Replace Sony Sub - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-30-2013, 03:11 PM   #11
virtualbeas
Fan#: 109214
What I Drive: 2013 Ruby Red Focus Titanium
FF Reputation: 2 virtualbeas Good Standing Member
This should work great then. I see the recommended box volume on this is less than the CVT too, which should help. I would like to know how this sounds in the factory enclosure. I am holding out for an upgrade to the JL Stealthbox right now but would consider this instead. I'm into SQ more than SPL anyway, so teh $650 price tag on the Stealthbox is hard to justify.
JL XD700/5 amp
Audison Bit Ten LOC & equalization
CDT HD61a components in front and rear
8" Kicker 10CVT8 in factory enclosure
virtualbeas is offline
Old 04-30-2013, 05:04 PM   #12
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
Originally Posted by virtualbeas View Post
Anything deeper than the 8" CVT won't fit though.
How deep is the 8" CVT? Do you know how deep the factory box is? When I had my F150 it had a factory sub that I replaced with a 8" kicker CVR in the factory box and had to use a MDF spacer ring to get the needed depth. The audiophile box in the 150's had a 2.625" depth and the MDF ring was .75 so it gave me 3.375 and the CVR needed 3.25"
It worked and sounded better than the factory sub, then I replaced the factory amp with a kenwood 8104D and it was even better.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
Old 04-30-2013, 05:09 PM   #13
virtualbeas
Fan#: 109214
I can't recall but the specs say 3-3/8" We had to do some slight modifying of the factory enclosure to reduce a bracket in the back of the box but nothing major.
JL XD700/5 amp
Old 04-30-2013, 07:01 PM   #14
I Bleed Ford Blue
Fan#: 94113
I decided to answer my own question so I went out and spent five minutes to pull the sub and measure the factory box. The depth is 3.25" from top mounting surface to the dimple for the back bolt.
L-CCC #18/HOIA #37
Old 04-30-2013, 09:15 PM   #15
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,606, Level 53
Points: 6,606, Level: 53 Points: 6,606, Level: 53 Points: 6,606, Level: 53
Level Up 28% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
It has a 2-11/16th's mounting depth.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 04-30-2013, 09:25 PM   #16
paulf1
Fan#: 95648
What I Drive: 2012 Gray Metallic Focus Ti 5DR
Points 347, Level 6
Points: 347, Level: 6 Points: 347, Level: 6 Points: 347, Level: 6
Level Up 94% Completed
Forum Activity 3%
FF Reputation: 1 paulf1 Good Standing Member
JL is making a stealth box for the 2012 Focus?
paulf1 is online now
Old 04-30-2013, 10:10 PM   #17
virtualbeas
Fan#: 109214
JL already has one out. Priced at $599.95 to $649.95 with the new 10TW3 sub in it. Should be a great box. It might still be on pre-order, but here is a link: http://pacificstereo.com/car-audio/e...5dr-10tw3.html
Here is my post for the JL Stealthbox. http://www.focusfanatics.com/forum/s...39#post4603139
JL XD700/5 amp
Old 04-30-2013, 10:11 PM   #18
virtualbeas
Fan#: 109214
Old 04-30-2013, 10:57 PM   #19
paulf1
Fan#: 95648
Points 347, Level 6
Forum Activity 3%
Well it's good to know they finally have one but I would probably just go with this box it's the same Sub and would fit pretty well in the same space for 200 bucks savings.
http://www.jlaudio.com/cs110lg-tw3-c...-systems-93304
Old 05-06-2013, 10:28 PM   #20
MrMyth
Fan#: 106845
What I Drive: 2013 Performance Blue Focus
Points 21, Level 1
Points: 21, Level: 1 Points: 21, Level: 1 Points: 21, Level: 1
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 2 MrMyth Good Standing Member
I can report that the Rockford Fosgate P3SD2-8 fits in the stock enclosure if you use a 3/4" MDF spacer. Screw the spacer down with the stock holes, then screw the new woofer to the spacer. Don't forget to plug or cover the hole in the back of the enclosure. I used 3 inch 12 gauge speaker wire from the stock connectors to the Punch's push terminals and wrapped the connections in duct tape. I had also stuffed the box with polyfill previously. Completely reversible mod, if you want to put it all back to stock.
The woofer is DVC 2 ohm so its a direct replacement load-wise for the Sony speaker. It also kicks the out of the stock woofer. I turned my bass down to +1 from +4 and still have more low end response. The bass is more vibratory, if that makes sense. Whereas the Sony is boomy and sort of clipped, the Punch goes more into subsonics. My dubstep (yes, I know) sounds like my home stereo now. I feel the music as much as I hear it.
I listen to everything but Country (and even then a little Soggy Bottom Boys) and the Punch makes everything sound better. It helps that I don't have to boost the bass so much, of course, but the Sony was too loud in the 45-55Hz tone and it overpowered the sound. I've had polyfill for about 4 months, and I tried running with the center unplugged for about a month. Each one of those moves made the Sony sound a bit better, but I still wouldn't call it close to the Punch.
The Punch can be had for about $100 on Amazon
MrMyth is offline
