Replace Sony Sub - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-08-2012, 05:58 PM   #1
nxd36
nxd36's Avatar
Fan#: 95761
What I Drive: 2012, Sterling Grey, SEL
FF Reputation: 1 nxd36 Good Standing Member
Replace Sony Sub
I have a 2012 SEL with the Sony package. I'm not a huge audiophile so the speakers suit me fine, but the sub is kind of weak for my taste unless I turn the bass all the way up then the other speakers do sound like crap. After replacing the OEM speakers and putting an amp and sub in my Mustang recently I don't feel like going through all that again right now so is it possible to simply remove the Sony sub and connect the wires to a better sub. I was hoping on putting in a single 10" sub. Thanks in advance.
nxd36 is offline
Old 03-09-2012, 02:42 AM   #2
Gazookz
Gazookz's Avatar
Fan#: 82103
What I Drive: 2011 Metallic Gray Focus SE
FF Reputation: 5 Gazookz Good Standing Member
I believe that would work if the stock sub is 10" and the depth of the new sub can fit into the box. In my opinion that really wouldn't make much difference unless you plan on adding a different amplifier to it or possibly a new box. Also make sure the sub you plan to use calls for that size of box and is the same impedance (ohms). A lot of times if the box isn't within the spec for the sub it doesn't sound that well. I'm sure someone with the 2012 model has done this and can let you know if it's worth it or not.
Gazookz is offline
Old 03-12-2012, 03:58 PM   #3
BlckZTS
BlckZTS's Avatar
Fan#: 78693
What I Drive: 2001 Black zts-1997 Ford Expedition
Points 1,199, Level 18
Points: 1,199, Level: 18 Points: 1,199, Level: 18 Points: 1,199, Level: 18
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 2 BlckZTS Good Standing Member
I did it with my expedition, I just got a 10" sub inside a bandpass box and the bass its MUCH louder. even with the stock amp it was way more bass
Sedan Revolution #171
BlckZTS is online now
Old 03-12-2012, 04:02 PM   #4
leh0825
[:)][:)][:)][:)] I got this!!!!
leh0825's Avatar
Fan#: 63206
What I Drive: 04 F250 FX4 6.0L
FF Reputation: 8 leh0825 Good Standing Member
you will still have to deal with the stock amp which means your speakers will still be run of the same amp so as you turn up bass it will affect all the speakers.
Team Duratec #220/Sedan Revolution #179/NW Posse#5
Originally Posted by jmiller_1974 View Post
Geesh. I mean I know it's just a Focus to the repair shop, but they couldn't give You something other than a rolling vagina to drive?
leh0825 is offline
Old 05-18-2012, 05:21 PM   #5
aaron.b
aaron.b's Avatar
Fan#: 98162
What I Drive: 2012 focus ti
Points 1,087, Level 17
Points: 1,087, Level: 17 Points: 1,087, Level: 17 Points: 1,087, Level: 17
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
FF Reputation: 1 aaron.b Good Standing Member
Has anyone replaced their sony sub with an aftermarket using the stock enclosure/amp? Any improvements in sound??
aaron.b is online now
Old 02-20-2013, 12:01 PM   #6
virtualbeas
Fan#: 109214
What I Drive: 2013 Ruby Red Focus Titanium
FF Reputation: 2 virtualbeas Good Standing Member
Anyone know the depth of the stock 8" enclosure?
virtualbeas is offline
Old 03-06-2013, 11:01 AM   #7
eastern sierras
Fan#: 109752
What I Drive: 2013 steling gray
Points 55, Level 1
Points: 55, Level: 1 Points: 55, Level: 1 Points: 55, Level: 1
Level Up 10% Completed
FF Reputation: 1 eastern sierras Good Standing Member
I know that eartquake makes a 8" dual voice coil 2 ohm sub for small enclosures.
eastern sierras is offline
Old 04-30-2013, 01:49 PM   #8
Anthony14
Fan#: 105866
What I Drive: 13 Focus Ti Plat
FF Reputation: 1 Anthony14 Good Standing Member
Kicker released 2 8" DVC subs recently.
http://www.crutchfield.com/p_2064CWR...ml#details-tab
100-400w RMS
dual 1Ohm or dual 2Ohm
They are a bit pricy at 149.99, but I might take a chance on one. Looking to add the dual 2ohm sub to a 1ohm load with a Rockford Fosgate PBR300X1 (300w @1ohm) .
Anthony14 is offline
Old 04-30-2013, 01:52 PM   #9
virtualbeas
Fan#: 109214
The Kicker 8" CVT fits nearly perfect in the factory box and sound decent. They don't hit very hard but sound better than the factory sub. Hadn't seen the RTs. Anything deeper than the 8" CVT won't fit though.
JL XD700/5 amp
Audison Bit Ten LOC & equalization
CDT HD61a components in front and rear
8" Kicker 10CVT8 in factory enclosure
Old 04-30-2013, 02:11 PM   #10
Anthony14
Fan#: 105866
http://www.focusfanatics.com/forum/showthread.php?t=315453
I started a new thread for my question.
The 40CWRT82 is about an inch smaller so that's not much of an issue I think.
