Any tips on Oxygen Sensor Heating circuit? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-05-2012, 04:25 PM   #11
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
Originally Posted by jmoryl View Post
Since I had a new front sensor (Ford) sitting around and the car has about 90k miles, I changed that sensor, expecting that would at least clear the P0135. No such luck.
Thanks in advance.
Did you yourself actually clear the current codes after replacing that sensor?That code won't go away by itself for quite awhile, even if the fault is repaired.
6SPD_soul is offline
Old 03-06-2012, 02:29 PM   #12
jmoryl
Fan#: 50300
What I Drive: 2003 SVT Focus (silver)
FF Reputation: 1 jmoryl Good Standing Member
Originally Posted by Grinder View Post
It's possible to meausure the current flow through the heaters but it's a tricky measurement to set up and the heaters are duty cycled controlled which will mess with your readings.
If both heater circuit codes are set, something common between the two sensors is your problem. The only thing common is the power circuit and the PCM. I agree, it's not likely the PCM but it is possible and this type of scenario is one of the common causes of their uncommon failure....
Are you SURE the fuse is good?
I've made some progress. After installing a new front sensor and getting the same codes, I'm down to one code, P0141, after several read/clear/CEL cycles. Funny how these things work sometime. So it looks like I'll just replace the rear sensor now. The SOB is bent, so it looks like it will be a hassle to remove - anyone have any experience to share?
jmoryl is offline
Old 03-06-2012, 02:55 PM   #13
Grinder
Fan#: 85627
What I Drive: 2003 CD silver SVT
FF Reputation: 10 Grinder Great Standing Member
This is common.
When you bottom the header out it flexes enough to smash the sensors against the engine/halfshaft. This bends the sensors and shorts the heating element to the body of the sensor. This will blow the fuse that is common between both sensor's power circuit and you end up with heater circuit codes.
When the PCM is bad it sets codes for both sensors all the time. So... if you're only setting the code for the rear - the heater element/circuity inside the sensor is toast. Replace the rear sensor and you should be good to go.
Make sure you bring your old sensor into the parts store to match it up. All parts stores categorize 02 sensors based on the element design and pigtail harness length. Autozone, Orielly, Napa, CarQuest and Pep Boys all show the incorrect length of pigtail for the rear sensor (at least for my SVT). I had to ziptie a crapload of extra harness because I couldn't find a direct replacement...
Grinder is offline
Old 03-08-2012, 06:45 PM   #14
jmoryl
Fan#: 50300
Thanks. I'm getting a Motorcraft sensor from Steve at Tousley, so I think I'll be OK there.
jmoryl is offline
Old 03-09-2012, 11:13 AM   #15
SonicPDX
SonicPDX's Avatar
Fan#: 84411
What I Drive: (2) 2oo2 SVTF One Sonic, One Red
FF Reputation: 1 SonicPDX Good Standing Member
I would enquire as to what sensor you replaced it with? Factory Motorcraft is my recommendation. I have had many issues with the Bosch/NTK and other aftermarket ones. Steve at Tousley got me the sensors at a reasonable price. $74 and $64 if I recall correctly.
SonicPDX is offline
Old 10-28-2012, 12:34 AM   #16
matmatician
Cars&Corgis
matmatician's Avatar
Fan#: 81361
What I Drive: A ONE COLOR FOCUS, Ducatis
Points 7,177, Level 56
Points: 7,177, Level: 56 Points: 7,177, Level: 56 Points: 7,177, Level: 56
Level Up 14% Completed
Forum Activity 3%
FF Reputation: 4 matmatician Good Standing Member
Sorry to revive the thread, but what kind of issues did you have with the Bosch one? I just picked one up and would like to return it before I install it if its anything serious.
Originally Posted by BertST View Post
Hop on in babe! No really, you're gonna have to hop in. Roll Cage.
ROTM June '13, PNW Crew #42, SR #245, Rally Rev #02
matmatician is offline
Old 10-28-2012, 09:24 PM   #17
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,244, Level 35
Points: 3,244, Level: 35 Points: 3,244, Level: 35 Points: 3,244, Level: 35
Level Up 30% Completed
Forum Activity 9%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
Bosch O2 sensors are crap and you will have problems either go with OEM ford or Denso Ive had no problems with them.
qweesy is offline
Old 10-07-2014, 12:25 AM   #18
Trev FF
Trev FF's Avatar
Fan#: 99052
What I Drive: 2000 focus ZX3 SVT
Points 1,658, Level 23
Points: 1,658, Level: 23 Points: 1,658, Level: 23 Points: 1,658, Level: 23
Level Up 58% Completed
Forum Activity 2%
FF Reputation: 1 Trev FF Good Standing Member
ok so did anybody figure out what the problem is? i pulled up and hit a curb and scrapped the header once, after that the bank 1 sensor 1 code came up and is still on. i checked the wires and changed the fuse everything seems to be fine. i checked the voltage going to sensor 1.. nothing. i checked the rear sensor 10-12 volts. please help. this is getting really frustrating!
2000 infra-red focus zx3 5 speed
AEM short ram intake, Svt header, CAT, fsWerks flexpipe, custom cat-back, custom red interior, SVT contour wheels, Raceland coils, Halo Headlights
Trev FF is offline
Old 10-15-2014, 11:44 AM   #19
Trev FF
Trev FF's Avatar
Fan#: 99052
Forum Activity 2%
anybody???
Trev FF is offline
