Any tips on Oxygen Sensor Heating circuit? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-04-2012, 09:57 AM   #1
jmoryl
Fan#: 50300
What I Drive: 2003 SVT Focus (silver)
FF Reputation: 1 jmoryl Good Standing Member
My SVT is throwing the P0135 and P0141 CEL codes, which is a fault in the O2 sensor heater for the front and rear sensors. Checking over the wiring, and the #18 fuse (under the hood), all looks good. Since I had a new front sensor (Ford) sitting around and the car has about 90k miles, I changed that sensor, expecting that would at least clear the P0135. No such luck. Any one here have a clue where to look next? Gotta get that light out long enough to pass my state inspection!
Thanks in advance.
jmoryl is offline
Old 03-04-2012, 10:16 AM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,930, Level 100
Points: 51,930, Level: 100 Points: 51,930, Level: 100 Points: 51,930, Level: 100
Level Up 0% Completed
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
Buy-Sell-Trade Rating: (28)
Need to see what the sensor is doing , see if a local member has a xcal and do a datalog , I will be glad to look it over for you
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 03-04-2012, 12:20 PM   #3
Grinder
Fan#: 85627
What I Drive: 2003 CD silver SVT
FF Reputation: 10 Grinder Great Standing Member
If you have done a proper load test of the common power circuit and didn't see high resistance its likely a bad pcm. They rarely fail but the 02 heater circuits are tested by measuring the voltage drop across a resistor inside the pcm. This resistor bridges the control circuits for both heaters so when the pcm grounds one o2 current will flow from the opposite o2 and then through the resistor. Heat will often open this resistor and make the pcm believe both heater circuits have malfunctioned. Be careful if you ever buy a reman'd pcm - this is something that seems to miss their "checks" and I've seen them have this issue out of the box.
Grinder is offline
Old 03-04-2012, 05:10 PM   #4
chada1208
Fan#: 58933
What I Drive: 2000 zx3 focus red
Points 565, Level 11
Points: 565, Level: 11 Points: 565, Level: 11 Points: 565, Level: 11
Level Up 30% Completed
FF Reputation: 1 chada1208 Good Standing Member
I had the same thing happen to my last 02 svtf! It happened when I bottomed out and hit the exhausted! Now I have the same problem with my recent 02 svtf so what can I do to fix it? I am planning on putting an orp and full exhaust on it soon so I will not b running an 02 Senor!
chada1208 is offline
Old 03-04-2012, 05:20 PM   #5
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 00 infared ZTS
Points 2,383, Level 29
Points: 2,383, Level: 29 Points: 2,383, Level: 29 Points: 2,383, Level: 29
Level Up 56% Completed
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
^^^ you NEED the front O2.
Mike_Mac is offline
Old 03-04-2012, 06:02 PM   #6
jmoryl
Fan#: 50300
Tom - thanks for the offer, but I won't be anywhere near NC soon.
Grinder - is there any simple way to check if the heaters are drawing the correct current (e.g. checking the voltage being supplied, measuring the resistance of the heater)? If one of the sensors is bad could it indicate a fault in the heater circuit for both - that seems like a possibility given what you say above. Cause I think the rear sensor might be dinged.
jmoryl is offline
Old 03-04-2012, 07:03 PM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 34%
I you have a ground and power to the plug in for the o2 then 99% chance your fine , there is a 99.99% that you dont have a bad PCM
You dont have to be clost to or in NC for me to help you just find a member with a xcal and I can help you with your problem , you could still have a bad o2 even new , Vac leak , broke wire and much more a datalog will help
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-05-2012, 10:55 AM   #8
JimmySVT170
JimmySVT170's Avatar
Fan#: 68945
What I Drive: 2003 Pitch Black SVT
FF Reputation: 1 JimmySVT170 Good Standing Member
I have the same issue, I hit a massive pothole and bottomed out, now I have this code. Tom, I have the predator tuner, how can I get you a datalog?
JimmySVT170 is offline
Old 03-05-2012, 10:55 AM   #9
JimmySVT170
Fan#: 68945
Just P0135 btw.
Old 03-05-2012, 04:08 PM   #10
Grinder
Fan#: 85627
It's possible to meausure the current flow through the heaters but it's a tricky measurement to set up and the heaters are duty cycled controlled which will mess with your readings.
If both heater circuit codes are set, something common between the two sensors is your problem. The only thing common is the power circuit and the PCM. I agree, it's not likely the PCM but it is possible and this type of scenario is one of the common causes of their uncommon failure....
Are you SURE the fuse is good?
Grinder is offline
