Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
#51 | ||||
LoL probably should say If you wanna go fast for cheap build a chevy...thats why I have an 83 camaro
#52 | ||||
It isnt always cheap for a chevy lol, right now helpin a family member build his 02 single cab stepside gmc, just your typical 408 with a 91mm attached and a powerglide lol this truck is no where near cheap lil over 2 yrs into it and jus got it moving on its own, but it was cheaper then his 04 88mm turbo'd lightning lol
#53 | ||||
I've heard some so so things about TCI... They seem to make just off the shelve converters and not really designed around your set-up. I like how places like Edge and Yank design the TC around your set-up. I know Andre told me after I filled out my sheet with info he could give me 3500rpm and danm he gave me 3500 on the button. With a TCI they say 3000, but it could be 2800 or 3300 you never know depending on your combo.
Shawn 1998 Ford Escort ZX2 Full Bolt-On's, SCT VCT Tuned ECU, 3500rpm Edge Racing Stall, 205/60R13 M&H D.O.T Street Slicks |
#54 | ||||
Never heard a bad thing about TCI...I guess every company out there has had so so issues. I am going TCI because of $$$. If It was no issue It would be a Circle D...Not sure If Yank makes a converter for the Mustang
Edit: Yank does not make an off the self for the mustang. Probably get one custom built. Performance automatics does make an off the self converter
Hard work never hurt anyone, but why take a chance Last edited by daveyboy; 06-11-2012 at 10:34 PM. Reason: More converter info |
#56 | ||||
#58 | ||||
Boost Junkie!
LSX > Modular motors SBF > SBC BBC > BBF Chevy 4 cylinders > Ford 4 cylinders Motor wise, I like Chevy's newer stuff. The LS motors are awesome engines that can be swapped into dang near anything. The modular motors without a blower are mammoth engines that are expensive and complicated to work on. I like Ford's older pushrod engines though just with Chevy's finer points (HEI distributors, one wire alternators, etc...), Ford tough with Chevy stuff. There's two dream drag car combinations I would love to have. One would be a fox body with a small block Ford 9.5" deck dart block 380ci, 10.5:1 compression, Yates C3 heads, Super Victor intake, a single LF88 turbo mounted in the front bumper with the exhaust dumped in front of the front tires, 2-speed powerglide with 1.72 first gear, and running on Q16. The second one is a fox body with a 572ci big block Chevy with 13.5:1 compression, conventional heads, custom headers dumped right behind the front tires, and a single NX fogger nitrous kit with a progressive 500 shot also with a 2-speed powerglide with a 1.80 first gear, and running on Q16. Ford makes the best rear ends, Chevy makes the best transmissions, and the engines are split between and personal preference. Chrysler just kinda fails on all counts. lol Except for making 500ci top fuel engines. BTW, I grew up in Waynesboro, MS not far from you. Go War Eagles!
2007 Focus ZX3 - FSW Stg 2, cams and cossie mani, stock motor, 7.74 @ 93mph (1/8th mile) w/ 1.84 60ft spinning Built motor on the engine stand! Shout out to FSWerks and Focus Rising 2012! |
#59 | ||||
A 13 sec pass is a piece of cake in my focus, granted, I have stuffed 100K into it. Motor from Japan, Brembo Drum to Disc conversion on the rear, lightened flywheel, 2lb rims with High-Performance Low-Profile tires, a twin turbo, and a complete engine rebuild and tuneup. Granted, like I said, I have 100K into the car, but I run low 10's to high 9's. I wish you the best of luck in your endeavor, but for your budget and everything else, it will be a challenge.
#60 | ||||
Boost Junkie!
| Thread Tools | |
| Display Modes | |
