2012 System Upgrade DIY: Speakers + LOC + Amp + Sub - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-02-2012, 11:22 AM   #31
jramer
Fan#: 102092
What I Drive: 2012, black, se hatchback
FF Reputation: 1 jramer Good Standing Member
Also, has anyone tried this kit? What do you guys think about it? I don't like the idea of changing the factory setup, but this kit looks decent and the aftermarket radio would make everything sound better.
http://www.ebay.com/itm/Metra-99-582...ht_1923wt_1397
jramer is offline
Old 11-22-2012, 10:22 PM   #32
Besbro
Besbro's Avatar
Fan#: 102785
What I Drive: 2012, black SE Sport
FF Reputation: 1 Besbro Good Standing Member
Hello, you mentioned that the power antenna wire you used as the loc power wire is "hot" as long as the hu is turned on. If you receive a phone call with the hu turned off does the call still play thru the speakers or will the amps be powered off? Does the sync system somehow power the hu on when you receive a phone call?
Thanks!
Besbro is offline
Old 01-15-2013, 09:54 PM   #33
tt69camaro
Fan#: 108118
What I Drive: 2013 focus SE 5-speed
FF Reputation: 1 tt69camaro Good Standing Member
Interesting reading. What speakers (front or rear) provide the best signal for a sub amp? Thanks
tt69camaro is offline
Old 02-03-2013, 10:26 PM   #34
Cadger
Fan#: 109124
What I Drive: 2013 metallic grey se hatchback
FF Reputation: 1 Cadger Good Standing Member
Tt69camaro, I assume you'd be using a LOC. I suggest using the rear speakers for a sub amp, and be sure to set up the amp crossover and such.
Cadger is offline
Old 06-09-2013, 08:17 PM   #35
redzone
Fan#: 114512
What I Drive: 2013 Blue Candy Hatchback SE
Points 769, Level 14
Points: 769, Level: 14 Points: 769, Level: 14 Points: 769, Level: 14
Level Up 69% Completed
FF Reputation: 1 redzone Good Standing Member
hello all. Does anyone know if the 6 speaker system has a built in crossover for the fronts?
Im wondering if i can just use the stock amp to power some high efficiency component speakers replace the tweeter and door speaker and rely on the stock crossover ?
or is it better to run the tweeter wire to the door and use the included crossover instead?
2013 Focus Hatch Se
Blue Candy
Build Date: 03.02.2013
Stock for now
redzone is offline
Old 06-11-2013, 10:43 AM   #36
Okidoki78
Fan#: 90522
What I Drive: 2012 Frosted Glass Metallic HB
FF Reputation: 1 Okidoki78 Good Standing Member
I'd use the supplied crossover, but thats just me. I'd want the speakers to work as intended. However, you could probably get away with using the stock amp/crossover.
Okidoki78 is offline
Old 06-11-2013, 10:55 AM   #37
redzone
Fan#: 114512
i was just looking at ways to reduce running wires.
i assume its still just a 4 channel amp on the hu and the tweeters and front door speakers share the same channel? idealy id like to buy some 6" mids and leave the stock tweeters but unsure how that would effect the amp.
2013 Focus Hatch Se
Blue Candy
Stock for now
redzone is offline
Old 06-11-2013, 12:30 PM   #38
Okidoki78
Fan#: 90522
Not sure, I don't have the Sony system, just upgraded the stock setup. But in previous cars, I would always take out the stock equipment and replace. FYI
Old 06-11-2013, 01:56 PM   #39
redzone
Fan#: 114512
6 speaker is not sony. its the base system in the SE
2013 Focus Hatch Se
Blue Candy
Stock for now
redzone is offline
Old 06-11-2013, 02:11 PM   #40
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
No it's not, the 4 speaker is the base system. The 6 is an upgraded setup between the base and the sony.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
