NO indicator for winshield wiper fluid - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-30-2012, 01:48 PM   #71
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,291, Level 28
Points: 2,291, Level: 28 Points: 2,291, Level: 28 Points: 2,291, Level: 28
Level Up 94% Completed
Forum Activity 3%
FF Reputation: 13 BetaDnB Great Standing Member
I'm probably going to empty my reservoir this weekend. I'll report back. Taking donations for a new bottle of washer fluid.
After thinking back, I recall my "!" coming on briefly once with no message anywhere. I don't remember if it was when I ran low or not.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 08-30-2012, 02:26 PM   #72
Timthom62
Timthom62's Avatar
Fan#: 97579
What I Drive: 2012 Red Candy 5-Door SEL 303A
Points 2,703, Level 31
Points: 2,703, Level: 31 Points: 2,703, Level: 31 Points: 2,703, Level: 31
Level Up 69% Completed
FF Reputation: 5 Timthom62 Good Standing Member
Actually, if you could just get access to the electrical connector for the washer fluid switch/level sensor, it's only a two wire system and it should be pretty easy to simulate a 'closed' switch. Just using a bit of wire as a jumper between the two pins of the connector should cause the message to appear.
Unfortunately, the access is the issue, as you pretty much have to come from underneath the car or remove the right headlight (and deal with the possible adjustment issues there). The level sensor is on the outer side of the tank just back from the washer fluid pump.
Timthom62 is offline
Old 08-30-2012, 03:19 PM   #73
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 913, Level 16
Points: 913, Level: 16 Points: 913, Level: 16 Points: 913, Level: 16
Level Up 13% Completed
Forum Activity 8%
FF Reputation: 4 Tiger-Heli Good Standing Member
Originally Posted by FordCustomerService View Post
It's only on trims with the high level message center.
Newbie question, but what is the high-level message center - do you mean more expensive trims, or do you mean physical location.
Also - there was an earlier comment that the cars have low oil level indication. Not sure about the Focus, but most cars have a low oil PRESSURE, not level indication.
Tiger-Heli is online now
Old 08-30-2012, 03:23 PM   #74
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,043, Level 66
Points: 10,043, Level: 66 Points: 10,043, Level: 66 Points: 10,043, Level: 66
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 24%
As far as I can tell they mean the 4.2" color LCD in the instrument cluster that is bundled with sync w/myford or myford touch equipped vehicles rather than the 3.x monochromatic display of the base SE or the even simpler system on the S.
suss6052 is online now
Old 08-30-2012, 03:29 PM   #75
Tiger-Heli
Fan#: 12379
Forum Activity 8%
That makes sense except that the picture in Reply #66 is of the instrument panel display, not the center console display.
Unless the reply meant the instrument panel display has more functionality if you have the MFT system - seems odd for this circuit, but ...
(Also - I knew there was the color screen with MFD and the monochrome screen with Sync and more basic on the S, but I didn't realize there was a center stack with the larger color screen without MFT).
I did some digging and I think I know what he meant.
The SE and up have a more complex Instrument Panel Screen with the little car to the right side of the screen. The S has a more basic IP display without the little car to the side and with the indicators in a different location (shifter position at the top instead of the bottom) and probably the S doesn't have the low washer fluid display - but that's just a guess.
Old 08-30-2012, 03:32 PM   #76
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 24%
No the instrument panel display is what I'm referring to, but in order to get the high function message center you needed to get MF or MFT, base S or SE models do not come with the higher resolution screen in 2012.
Old 08-30-2012, 03:37 PM   #77
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Forum Activity 3%
You shouldn't need the higher level trims to have this message displayed since the low resolution screens still display messages such as low tire pressure, trunk open, etc. As I said they ran the TSB, so let's just wait until I dump this load.
BetaDnB is offline
Old 08-30-2012, 03:40 PM   #78
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 24%
I concur it shouldn't be required, but I was only trying to explain what they claimed was necessary, which is the full color lcd, but yes if the sensor is still there it should show up on at least the SE since the SE has a trip computer, the S however only has a very basic system that only has a trip odometer afaik.
Old 08-30-2012, 03:44 PM   #79
WiscoGTI
Turböner
WiscoGTI's Avatar
Fan#: 70225
What I Drive: 2002 VW GTI
Points 153,662, Level 100
Points: 153,662, Level: 100 Points: 153,662, Level: 100 Points: 153,662, Level: 100
Level Up 0% Completed
FF Reputation: 33 WiscoGTI Great Standing Member
Buy-Sell-Trade Rating: (9)
Originally Posted by 1sloho View Post
really....know when i know im outta fluid? i push the button and noting comes out. u really need something to tell u ur outta fluid??
Co-signed.
Sent from my SCH-I500 using FF Mobile
WiscoGTI is offline
Old 08-30-2012, 03:45 PM   #80
Tiger-Heli
Fan#: 12379
Forum Activity 8%
I was incorrect above.
The 2012's with SYNC or above have the display with the shift positions at the bottom and the 2013 SE's and up have this and should have the display.
The 2012 SE's without SYNC and S's have the display with the shift position at the top (and the 2013 S?) and might not have the indication ...
