#41 | ||||
TSB
12-4-13 LOW WASHER SOLVENT WARNING MESSAGE MAY NOT DISPLAY ON VEHICLES BUILT ON OR BEFORE 1/14/2012 Publication Date: April 30, 2012 FORD: 2012 Focus ISSUE: Some 2012 Focus vehicles built on or before 1/14/2012 may not display the low washer solvent message as detailed in the Owner's Guide. ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE Using the Ford Integrated Diagnostic System (IDS) start a new IDS session. ID the vehicle; select the tool box at the vehicle screen. Select module programing. Select programmable parameter. Select car configuration parameters. Select vehicle configuration. Retrieve professional technician society (PTS) delivered as-built data. Follow the on-screen prompts. WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. OPERATION DESCRIPTION TIME 120413A 2012 Focus: Follow Service Procedure To Repair Concern (Do Not Use With Any Other Labor Operations) 0.3 Hr. DEALER CODING BASIC PART NO. CONDITION CODE 14A068 04 |
#42 | ||||
Drum n Bass Lover
Thank you, Rat Fink!
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete www.soundcloud.com/betadnb www.facebook.com/betadnb |
#43 | ||||
#45 | ||||
Those who do this TSB, please take your LCD info screen into TEST mode and take a picture of your LED test. I am not seeing an LED warning icon for washer fluid. Which one is it? Maybe it should be at the 0 speedo position?
#46 | ||||
#47 | ||||
Drum n Bass Lover
Somebody who has a working indicator said it shows on the info screen. There is not a dummy light.
#49 | ||||
Should still be doable, but certainly not as easy as washer fluid. A similar thing with motor and transmission oil levels. Brian |
#50 | ||||
'12 SE Sport 5Dr |╠╬╝|Sterling Grey Metallic|203a|Moonroof|17" Mach/Paint Whls|K&N Typhoon|MS3 RMM|Steeda STB, RSB '01 ZX3|╠╬╝|Pitch Black|Prem. pkg.|Moonroof|SVT Snorkel|SVT Springs|S2 Dampers|Steeda STS|Magnaflow exh. |
| Thread Tools | |
| Display Modes | |
