NO indicator for winshield wiper fluid - Page 13 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-03-2012, 11:21 AM   #121
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 904, Level 16
Points: 904, Level: 16 Points: 904, Level: 16 Points: 904, Level: 16
Level Up 4% Completed
Forum Activity 9%
FF Reputation: 4 Tiger-Heli Good Standing Member
Originally Posted by TboneZX3 View Post
"They" and "them" would not refer to the same people in this case. Ford engineers don't write MFT code, but they would oversee a sensor issue.
Not sure I buy this. Sure Ford might have outsourced the actual MFT code, and they probably did the MFD firmware for the WW sensor in-house, but ... There are Ford reps monitoring and responding to these threads and you would think they could pass the word up the chain and get these types of issues resolved. Ultimately the "Fix" is from Ford even if they did outsource the codework.
Tiger-Heli is offline
Old 10-03-2012, 11:25 AM   #122
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Of course. But my point is that the chain of command is different, so just because it hasn't worked efficiently for MFT issues doesn't mean we should assume it won't for a fluid sensor issue.
Hatch Nation #90
TboneZX3 is offline
Old 10-16-2012, 11:59 PM   #123
Guimpy
Fan#: 88333
What I Drive: 2012 Platinum White Titanium
Points 141, Level 2
Points: 141, Level: 2 Points: 141, Level: 2 Points: 141, Level: 2
Level Up 82% Completed
FF Reputation: 1 Guimpy Good Standing Member
I just got the TSB applied. I deliberately let the fluid run low to see if anything would happen. Nothing happened... Now I don't know if what they did worked because they topped off my washer fluid. It will be a few months before I'll be able to tell. I'm told that there would be an indicator light that will go on once the level is low. I will report back once I have an update. Car built is June 17 2011, Titanium Hatch, fully equipped.
Guimpy is offline
Old 10-17-2012, 12:10 AM   #124
Dick W
Fan#: 91695
What I Drive: 2012 5dr SGM Ti/09 135i/07 CR-V
FF Reputation: 2 Dick W Good Standing Member
Look for a message in the MID. Don't think there's a dedicated indicator.
Dick W is offline
Old 10-17-2012, 07:04 AM   #125
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,291, Level 28
Points: 2,291, Level: 28 Points: 2,291, Level: 28 Points: 2,291, Level: 28
Level Up 94% Completed
Forum Activity 3%
FF Reputation: 13 BetaDnB Great Standing Member
Yeah. Let's be clear on this just one more time. There is NO INDICATOR LIGHT. It is a message with text on your message center.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 10-17-2012, 09:29 AM   #126
Guimpy
Fan#: 88333
Points 141, Level 2
I didn't say that that's what it was. I said what I was told and would report back with a follow-up.
I've read the whole thread and when I went at the dealer I was prepared with all the info I got from here. He was adamant that it was an indicator light. So.... no point in me arguing with the guy. The fluid level was now full and we couldn't check.
I'll take pictures when the time comes. I might just empty the fluid and get it done with.
Edit: I was also told at the beginning that my car was not equipped with such a thing.
Guimpy is offline
Old 10-17-2012, 09:41 AM   #127
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Forum Activity 3%
I know you didn't say that, but just putting it out there might confuse people. The Ford techs have put enough of that out there as far as this is concerned. It sounds like you went through about exactly what I went through. Don't waste your fluid if the paper work says it was done unless you just want peace of mind that it was done.
BetaDnB is offline
Old 10-23-2012, 03:20 PM   #128
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
Level Up 50% Completed
Forum Activity 2%
FF Reputation: 1 BrApple Good Standing Member
well I just ran the washer fluid down and I received no message indicating a low level. Can was built Jan 10, 2012 and I have Sync.
If I am not mistake someone else with a SE built in late Jan got the message?
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is offline
Old 10-23-2012, 03:23 PM   #129
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,002, Level 33
Points: 3,002, Level: 33 Points: 3,002, Level: 33 Points: 3,002, Level: 33
Level Up 68% Completed
Forum Activity 8%
TSB states that it affects vehicles built on or before 1/14/2012.
PratoN is online now
Old 10-23-2012, 03:27 PM   #130
Seriously Focused
Seriously Focused's Avatar
Fan#: 101141
What I Drive: 2012 SGM SE Sport 5 Dr
Points 532, Level 10
Points: 532, Level: 10 Points: 532, Level: 10 Points: 532, Level: 10
Level Up 64% Completed
FF Reputation: 1 Seriously Focused Good Standing Member
You should spell your profile name GRUMPY :)
Seriously Focused is offline
