Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 02-21-2012, 10:58 AM   #1
ibedoughboy
Fan#: 93050
What I Drive: '12 Focus SE Hatch 5 speed
FF Reputation: 2 ibedoughboy Good Standing Member
How to: Add an Auto Dimming Mirror
Head on over to my Flickr account where I've posted step by step instructions on adding an auto dimming mirror to the 2012 Focus. It isn't too difficult.
http://www.flickr.com/photos/ibedoug...7629419449573/
'12 Focus SE Hatch; Oxford White, 5 speed, 203A, SE Sport and Winter Pkg, Moonroof, M&P wheels
'05 Chrysler Crossfire Roadster 6 speed
'62 Chevy Corvair Rampside
ibedoughboy is offline
Fan#: 1
Old 02-21-2012, 12:06 PM   #2
Doug81
Fan#: 85686
What I Drive: 2012 Candy Red Ti Sedan
FF Reputation: 1 Doug81 Good Standing Member
Nice guide!
Doug81 is offline
Old 02-21-2012, 04:13 PM   #3
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
FF Reputation: 43 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (16)
thats a nice guide
fyi try uploading your pictures to photobucket, then post the [img] tag in your post, and then your pictures will shop up in your post
Advocare 24 Day Challenge!
SkyPilot is offline
Old 02-21-2012, 10:14 PM   #4
KaputtEqu1pment
Fan#: 91122
What I Drive: 2012 Triple Plat White Focus Ti HB
FF Reputation: 1 KaputtEqu1pment Good Standing Member
That's nice.
So it woul be possible to add any 3rd party Auto Dimming Mirror? The ford one is like $300...
KaputtEqu1pment is offline
Old 03-06-2012, 07:54 PM   #5
ibedoughboy
Fan#: 93050
Originally Posted by KaputtEqu1pment View Post
That's nice.
As long as you have the plug for the mirror (and a little of the mirror wire harness to attach more easily to) I don't see why not. This mirror is from a Chrysler 300 and works fine. But make sure that the bracket on the mirror you get will fit on the Focus stud attached to the windshield, or you'll have a problem.
If you go to a junk yard, or ebay even, you should be able to get a working mirror for under $50. My friend has a salvage yard, so he just gave me the one I used, I just had to spend 5 mins and take it out.
Good Luck, any questions I'll be glad to help.
Old 03-06-2012, 09:12 PM   #6
-sokO
-sokO's Avatar
Fan#: 93367
What I Drive: 2012 Ford Focus Ti Sedan
FF Reputation: 1 -sokO Good Standing Member
I wonder if my Ti has the wiring already for the auto dimming mirror, I got the one with cloth seats so I didnt get the mirror, but I would love to add an auto dimming mirror. I've seen some good ones for under 100$ that are just Auto dimming with nothing else (already have compass/temp/homelink) which would work out great and be cheap.
-sokO is offline
Old 03-07-2012, 08:07 PM   #7
ibedoughboy
Fan#: 93050
A couple ways to check:
1) Take a voltmeter, if you have one, and find the auto dimming mirror, rain sensing wipers, humidity sensor fuse (In owners manual) and check it for power. My SE has the fuse in the fuse block, but is not powered...and does not have the harness.
2) Take down the front of the headliner and look up in there. To do this, remove the passenger assist handle (2 torx screws). Remove pass sunvisor (I think 3 torx screws, 2 in sunvisor and 1 in clip). Unclip/ unscrew overhead console. To do this, open the sunglasses holder and look up at the overhead console from the windshield side and you'll see a couple slots for a straight screwdriver to go in. Gently unclip the console and there will be 2 screws up inside holding it to the roof. Once that's done you can pull the headliner down enough to look up inside it. Sounds confusing but takes maybe 15mins.
Old 09-22-2012, 06:26 PM   #8
slow3v
slow3v's Avatar
Fan#: 101709
What I Drive: 2012 Sterling Gray Focus SE MTX
FF Reputation: 1 slow3v Good Standing Member
Just to bump this. Went to the junkyard today and pulled a Ford (Gentex) auto-dimming mirror with no other fanciness from a first gen Expedition. It had the same wedge mount that we do (though I can't quite get it to "click", I'm not comfortable pushing that hard).
Wired it up perfectly as well as my radar detector. Came out great thanks to this guide, and boy is it an improvement.
Thanks again!
slow3v is offline
Old 09-22-2012, 10:58 PM   #9
ibedoughboy
Fan#: 93050
Thanks again!
Is the arm on the expedition mirror long enough that the whole mirror is useable and doesn't get cut off by the overhead console? My Chrysler one is a little too short.
Glad the guide was useful.
Old 09-23-2012, 09:29 AM   #10
slow3v
slow3v's Avatar
Fan#: 101709
More then enough. You do realize rear view mirrors are on two articulating balls usually. You should be able to adjust the angle of your mirrors arm. Go tug on it.
Sent from my SGH-I777 using FF Mobile
slow3v is offline
