P0772 "Shift Solenoid E Stuck On"- Does this really mean the E solenoid is bad? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-20-2012, 07:41 PM   #1
JayBurke
Fan#: 95360
What I Drive: 2006 Ford Focus
FF Reputation: 1 JayBurke Good Standing Member
Need some help from someone that knows Ford Transmissions: Have a 2006 Ford Focus with automatic transmission (4 Cyl). It has 104K miles on it. (Tranny Numbers are 6S4P-7000-FA-PVAF and A-4920-021205-53360256.)
Tranny started acting up with problems shifting and went into "limp home mode" with the "O/D Amber Light" flashing. Got the code read and code is P0772 which reads "Shift Solenoid E Stuck On".
My question is this: Is the code correct and do I only have to replace the "E" solenoid? Other postings state that the "A" solenoid is usually the culprit. Should I replace the "A & E"? Or is it possible that the solenoids are good and the real problem is that the "control valve is stuck"? Is the control valve a check valve that is causing the solenoid to stay on? If so, will the entire tranny have to be pulled and dismantled to fix it?
Any help from a Ford expert would be greatly appreciated. Thanks in advance.
JayBurke is offline
Old 02-20-2012, 08:38 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,412, Level 75
Points: 13,412, Level: 75 Points: 13,412, Level: 75 Points: 13,412, Level: 75
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 99%
Pan removal is all that's needed to replace solenoids, if I was doing it I'd replace 'em all as long as I was in there....
Just for the "halibut"....
(grin)
sailor is offline
