2012 Focus Stock Exhaust Size - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-20-2012, 12:05 PM   #1
naegerter
naegerter's Avatar
Fan#: 90207
What I Drive: 2012, Red Candy, Focus SE
FF Reputation: 1 naegerter Good Standing Member
Just curious, does anyone know the exhaust size of the 2012 Ford Focus? From my measurements, it's about 2 inches, but I just was a definitive answer. I'm also curious as to whether a larger 2.25 inch exhaust would have any benefits.
I currently have a Borla muffler installed with a pipe welded in place of my middle resonator (under the center console) but I still have the secondary resonator (by the rear driver side wheel) and would like to have a single pipe running all the way back to the muffler without any welds (except of course for the weld onto the muffler) or resonators. Much like how the stock exhaust is.
I would just like to know which, a 2 inch or a 2.25 inch exhaust, would be better. Thanks in advance for your opinions!
naegerter is offline
Old 02-20-2012, 03:12 PM   #2
GO.army.1969
GO.army.1969's Avatar
Fan#: 69605
What I Drive: 2008 Vapor Silver Coupe 5 speed
Points 2,851, Level 32
Points: 2,851, Level: 32 Points: 2,851, Level: 32 Points: 2,851, Level: 32
Level Up 68% Completed
FF Reputation: 15 GO.army.1969 Great Standing Member
I would run 2.5 if I was to have new pipe put on.
NW Posse#10 Team Duratec#69
F2 Header, Steath Exhaust, CAI, AR103, Tuned by Randy Fswerks, DGR Coil Overs
DOMINANT front and rear LCA DOMINANT endlinks Massive toe and camber arms
GO.army.1969 is offline
Old 02-20-2012, 03:59 PM   #3
naegerter
naegerter's Avatar
Fan#: 90207
How come?
Old 02-20-2012, 05:09 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,807, Level 73
Points: 12,807, Level: 73 Points: 12,807, Level: 73 Points: 12,807, Level: 73
Level Up 90% Completed
Forum Activity 99%
Probably because 2" vs. 2.25" isn't much of a difference....
Usual first step on an older Focus would be to remove the rear resonator & replace it with a straight pipe, as the factory did on some models....
No appreciable performance improvement, just better "sound" and a weight reduction...
That said, the "cats" are the main exhaust restriction, and any changes post cat won't make much difference.... So unless you put on a header, pipe size & muffler makes little difference....
sailor is offline
Old 02-20-2012, 05:45 PM   #5
naegerter
naegerter's Avatar
Fan#: 90207
Thanks for the input!
