Serpentine Belt Tensioner, Zetec - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-19-2012, 04:07 PM   #1
jmoryl
Fan#: 50300
What I Drive: 2003 SVT Focus (silver)
FF Reputation: 1 jmoryl Good Standing Member
I get about 30 seconds of squealing every time I start up my '03 SVT Focus with 88k miles.
So I thought my water pump was going, and armed with a new belt, pump and these directions, http://www.focusfanatics.com/forum/showthread.php?t=184383, I went off to my garage. Once I drained the coolant, put a jack under the oil pan and removed the motor mount, I was unable to remove the screws holding the pulley onto the pump because the belt did not have enough tension to hold it in place. In fact the serpentine belt didn't seem to have all that much tension, and I couldn't get the tensioner to budge much by using a 15mm wrench on the center bolt (it just seem to loosen/tighten the bolt).
Does this sound like a bad tensioner/stretched belt? Should one be able to detension the belt by putting a wrench on the center bolt? How hard is this to change (looks like there are two bolts holding it on)? TIA.
jmoryl is offline
Old 02-19-2012, 04:14 PM   #2
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
Yea sounds like your tensionair is bad, it should be able to move when you put a wrench 14 or 15MM on the center bolt, so I'd change that out.
And yes it is just 2 bolts, but on my normal Zetec, (IIRC) I had to remove the harmonic balancer to make it easier to get at and out.
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 02-19-2012, 04:18 PM   #3
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
What I Drive: 2001 CD Silver ZX3
Points 15,532, Level 80
Points: 15,532, Level: 80 Points: 15,532, Level: 80 Points: 15,532, Level: 80
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 2%
FF Reputation: 20 xxMichaelAnthony Great Standing Member
Could be both but you're about due for a timing belt if you haven't done it. Save a lot of time and do it all at once. And by about due I mean do it before it breaks and or we'll have one less SVT on the road.
http://effyeahfordcars.tumblr.com
[HOONIGAN]
iTroll
xxMichaelAnthony is online now
Old 02-19-2012, 05:31 PM   #4
jmoryl
Fan#: 50300
Yeah, I'm aware of the 90k recommendation for the timing belt. Got a good link for the procedure on the SVT?
jmoryl is offline
Old 02-20-2012, 06:58 AM   #5
RallieConGoggle
RallieConGoggle's Avatar
Fan#: 50774
What I Drive: 2007 CD Silver ZX4
Points 2,010, Level 27
Points: 2,010, Level: 27 Points: 2,010, Level: 27 Points: 2,010, Level: 27
Level Up 7% Completed
FF Reputation: 9 RallieConGoggle Good Standing Member
This is an alternator change thread, but scroll down and you'll see the belt tensioner stuff. http://www.focusfanatics.com/forum/showthread.php?t=276720
Here is a write up I did on Zetec timing belt change, the SVT should be about the same, it just has a different compression ratio.
http://www.focusfanatics.com/forum/s...27#post2732327
Rally with your goggles on!
2000 Pitch Black ZTS Auto (230,000+ miles)
2007 CD Silver ZX4 SES 5spd
Zetec Crew #190
RallieConGoggle is offline
Old 02-20-2012, 07:16 AM   #6
xxMichaelAnthony
Fan#: 58459
Forum Activity 2%
Timing belt should be the same as a regular ZETEC but I think there is an extra step because of the VCT on the intake side. Hopefully someone will chime in on that for you
[HOONIGAN]
iTroll
