Turbo compression ratio - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-19-2012, 07:51 AM   #1
SoBe-it
Fan#: 82542
What I Drive: 1999 Silver frost ZX2
FF Reputation: 1 SoBe-it Good Standing Member
i have a turbo build going on and need some help picking a head gasket for the right c/r. the block has 9:1 je pistons and the head is milled to be 10.5:1, so i know i would be around 10:1 on the c/r. i dont know where i would want to be on c/r but i would say near stock or under.
other parts of my build if it helps:
gt35 .70 a/r c-.63 a/r t
custom ram horn top mount mani
ported head with o/s valves & FR springs(flows 260I/240E)
FRIM and throttle body
3" exhaust
cams 230 I/E@.050 with .411 lift.
esslinger cam gears
crower rods
billet main caps
~thanks all~
SoBe-it is offline
Old 02-19-2012, 09:33 AM   #2
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
Keep it at 10:1 and find a good tuner.
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 02-19-2012, 01:13 PM   #3
Top Speed
Top Speed's Avatar
Fan#: 77307
What I Drive: 02 SVT, 07 ZX3, 04 Sedan, 02 ZX3
Points 7,824, Level 59
Points: 7,824, Level: 59 Points: 7,824, Level: 59 Points: 7,824, Level: 59
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 3 Top Speed Good Standing Member
Agreed, having to run low compression with boost is a myth
Top Speed is offline
Old 02-19-2012, 01:36 PM   #4
SoBe-it
Fan#: 82542
if i get a good tuner what would i be looking at hp wise possibly.
remote tuning any good?
SoBe-it is offline
Old 02-19-2012, 02:15 PM   #5
SoBe-it
Fan#: 82542
SoBe-it is offline
Old 02-19-2012, 04:43 PM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,787, Level 100
Points: 51,787, Level: 100 Points: 51,787, Level: 100 Points: 51,787, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
A "Myth" thats interesting
Higher compression means more heat , heat in the Cyl is the killer to ALL boosted engines lower compression engines have LESS HEAT and sence this is a Focus Forum we need to keep in mind the engine he is running which is a VERY INEFFICIENT Zetec engine which plays a HUGH role in picking the static compression and boost your going to run as well as cam profile , combustion chamber , intercooler size , turbos CFM per psi boost , turbo manifold
ALL needs to be taken into account when saying low compression with boost is a myth
The Zetec engine at 9.6 makes close to the same power as the SVT does at 10.2 compression thats with the exact same turbo kit and tune BUT it did make slightly better mid range TQ but less top end TQ because more timing had to be taken out both were small in the amount of TQ gained and lost
It isnt a "myth" at all when you calculate all the factors , if you want a monstor engine that makes hugh power your not going to use a lot and dont mind running 100+ octane fuel then do 11-1 and add the boost , If you want some thing thats going to live , that you can have fun with and run 93 octane then lower the compression to about 9.0 choose the right turbo for how your going to be driving and go have fun , The Diff in 9.0 to 10.0 wouldnt be worth the gain vs the issues
Look at it this way just a ruff example
9.5 engine with 18psi making 350hp your Cyl temps would be "Y"
8.5 engine with 18psi making 330hp your cyl temps are "X" add 3psi more boost and your Cyl temp is now "Y" again but your now at 370hp
Any good engine builder and tuner would first have to look at what engine your boosting , how efficient it is , intercooler , intake , turbo manifold , cams , combustion chamber etc , It isnt a "myth" at all
9.0 to 9.2 would be my choice
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 02-19-2012, 04:47 PM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
That would be hard to say what your power would be would need a lot more info and remote tuning works great and saves you a ton of dyno time money , I have dynoed a good bit of my remote tunes and there was very very little that had to be changed and most nothing at all got changed in the tune
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 02-19-2012, 06:08 PM   #8
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,851, Level 100
Points: 50,851, Level: 100 Points: 50,851, Level: 100 Points: 50,851, Level: 100
Forum Activity 5%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
Agreed with Tom you need a lower compression for boost
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is online now
Old 02-19-2012, 07:36 PM   #9
SoBe-it
Fan#: 82542
i would like to break 400 or get near it since my stock engine on a kkk k24 draw thru made 189whp 233tq. untuned no intercooler
SoBe-it is offline
Old 02-19-2012, 07:41 PM   #10
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
400 isnt hard to get to , I would still do 9.0-9.2 you do have to deal with 93 octane fuel and it isnt boost friendly
It could be remote tuned
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
