Idea for aftermarket HU in a 2011 - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-15-2012, 03:36 PM   #11
nickstewartroc
Fan#: 93665
What I Drive: 2011 Blue Focus SE
Points 301, Level 6
Points: 301, Level: 6 Points: 301, Level: 6 Points: 301, Level: 6
Level Up 2% Completed
FF Reputation: 1 nickstewartroc Good Standing Member
See that's the point of the relay, it's a small current load (very small) and will just act a "switch" to split the always on 12v to the acc on the radio
nickstewartroc is offline
Old 02-15-2012, 03:44 PM   #12
Gazookz
Gazookz's Avatar
Fan#: 82103
What I Drive: 2011 Metallic Gray Focus SE
FF Reputation: 5 Gazookz Good Standing Member
Oh ok. I understand what you're saying now. Use one side of the relay to the accessory on the HU, the other to the ignition and then the constant 12V+ on the HU to a seperate 12V+ source. That will work just fine then
Gazookz is offline
Old 02-15-2012, 03:45 PM   #13
nickstewartroc
Fan#: 93665
Points 301, Level 6
Sweet looks like I'll be ordering some Audio stuff now haha
Old 02-16-2012, 10:54 PM   #14
mrfatride
mrfatride's Avatar
Fan#: 21759
What I Drive: 2009 Vista Blue SES Coupe
FF Reputation: 42 mrfatride Great Standing Member
The accy wire at the ignition switch it is not necessary to run a relay for it. Aftermarket head units get all their power from the constant wire (yellow) and the accy wire acts just as a signal (similar to a remote wire for an amp) When I was an installer I would just fuse my splice with a 3 amp fuse and never had a single problem. would using a relay hurt? no but it would be easier and less to try and hide
2009 SES Coupe #036
MECP Certified Installer
mrfatride is offline
Old 02-17-2012, 01:58 PM   #15
nickstewartroc
Fan#: 93665
Points 301, Level 6
Awesome! I didn't know that, thanks! Would you happen to know what color wire it is off hand? Or where to locate it? Thanks!
Nick
Old 02-17-2012, 02:04 PM   #16
Gazookz
Gazookz's Avatar
Fan#: 82103
It should be brown/yellow and on the ignition switch on the black 7 pin plug it is pin number 1 on that. Hope this helps. Make sure to double check ALL connections and verify they are what you think they are before doing anything.
Gazookz is offline
Old 02-17-2012, 10:27 PM   #17
mrfatride
mrfatride's Avatar
Fan#: 21759
actually its purple with a green stripe if i am correct unless they changed it
2009 SES Coupe #036
Old 02-17-2012, 10:28 PM   #18
mrfatride
mrfatride's Avatar
Fan#: 21759
just looked it up brown/yellow is ignition purple/green is accesory
2009 SES Coupe #036
Old 02-20-2012, 10:20 AM   #19
nickstewartroc
Fan#: 93665
Points 301, Level 6
Well I attempted to pull the purple/green wire from the a/c control unit. Doesn't work :/ as soon as the controls are activated, the voltage drops to .5v Still looking to find where to pull from easily-
Nick
Old 02-20-2012, 08:31 PM   #20
mrfatride
mrfatride's Avatar
Fan#: 21759
you have to go to the ignition harness. take the black plastic shroud off the steering wheel (yes it will be a pain in the ass) on the left side of the steering wheel (if you are looking at it) there will be a black harness with 5 or so wires tied into it. there should be a purple wire with a green stripe there. to make sure you have the right harness unplug it and then try to start the car. if the car does not turn over you got the right harness
2009 SES Coupe #036
