2 Fast 2 Furious Focus. Yeah I know, again. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 02-13-2012, 03:25 PM   #11
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
What I Drive: 2001 CD Silver ZX3
Points 15,567, Level 80
Points: 15,567, Level: 80 Points: 15,567, Level: 80 Points: 15,567, Level: 80
Level Up 44% Completed
FF Reputation: 20 xxMichaelAnthony Great Standing Member
Originally Posted by TerryB View Post
Really ?
Stock is what comes from manufacturer right? Pretty sure it was a Ford built car... And notice the quotes around "stock"?
http://effyeahfordcars.tumblr.com
[HOONIGAN]
iTroll
xxMichaelAnthony is offline
Old 02-13-2012, 03:26 PM   #12
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 2001 ZX3, 2012 SE Sport Hatchback
FF Reputation: 6 teamDFL Good Standing Member
Originally Posted by xxMichaelAnthony View Post
Pretty sure everything is "stock" except for the headlights and taillights
Also made with "stock" Ford parts:
Hey, it is stock car. By definition, the parts are stock!
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
Old 02-13-2012, 03:28 PM   #13
xxMichaelAnthony
Fan#: 58459
OMFG!!!! Someone understands sarcasm!!
[HOONIGAN]
iTroll
Old 02-13-2012, 03:35 PM   #14
xxMichaelAnthony
Fan#: 58459
Focus FR200
Engine Configuration
Induction System
Air Filter Assembly Ford Racing prototype
air filter housing
Mass Air Sensor 1999 Cobra mass air sensor
Turbocharger IHI turbocharger
Intercooler Ford Racing prototype air charge cooler
Throttle Body Ford Racing prototype 70mm throttle body
Intake Manifold Ford Racing high-flow aluminum intake manifold
Cylinder Head
Cylinder Head Ford Racing 2.0L Zetec
high-flow cast aluminum cylinder head w/big valves--33mm intake, 29.8mm exhaust
Camshafts Stock 2.0L Zetec camshafts
Block
Block Stock Zetec block
Displacement 2.0 liters
Compression Ratio 8.0:1
Crankshaft Stock 2.0L Zetec
Rods Stock 2.0L Zetec
Pistons Forged Aluminum
Horsepower 304 hp @ 6750 rpm
Torque 285 lb/ft @ 3500 rpm
Redline 7200 rpm
Electronic Engine Controls
EEC-V Unique calibration to accommodate
turbocharger package
Ignition System
Ignition Stock 2.0L Zetec ignition system
Fuel System
Fuel Pump Modified
Injectors Ford Racing prototype 48 lb/hr injectors
Cooling System
Radiator Ford Racing prototype aluminum radiator
Fans Electric, one 14-inch, one 9-inch
Exhaust System
Exhaust Manifold Ford Racing prototype stainless steel high-flow exhaust manifold
Exhaust Pipe 3-inch diameter stainless steel
Muffler One dual-mode stainless steel muffler
Tail Pipe 3-inch diameter stainless steel
Exhaust Tip Ford Racing prototype polished stainless steel
Powertrain
Flywheel Stock 2.0L Zetec flywheel
Clutch Centerforce prototype clutch disc and presure plate
Transmission European production MTX75 transmission case with Ford Racing prototype MTX75 transmission gears
Differential Torsen limited slip differential
Ring and Pinion 3.82:1 ring and pinion gears
Axles Ford Racing prototype half shafts
Brakes
Front Brakes
Rotors 1999 Cobra 13-inch front rotors,
vented and cross-drilled
Calipers 1999 Cobra, dual piston
Cooling Forced air, ducted from front fascia
Rear Brakes
Rotors 1999 Cobra 11.65-inch rotors,
Calipers 1999 Cobra, single piston
Suspension
Front Suspension
Suspension Ford Racing prototype double A-arm front suspension with
front wheel drive spindles
Shocks Ford Racing prototype three-way adjustable front coil-over shocks
Ride Height Lowered 1-inch from stock
Track Width Increased 4 inches from stock
Steering Modified European Focus rack and pinion power steering
Stabilizer Bar Ford Racing prototype 1.25-inch tubular front stabilizer bar assembly
Rear Suspension
Suspension Stock rear suspension
three-way adjustable rear
coil-over shocks
Track Width Increased 4-inches from stock
Stabilizer Bar Eibach 1-inch diameter rear stabilizer bar
Wheels and Tires
Wheels
Front 18x8-inch Ford Racing prototype wheels
Rear 18x8-inch Ford Racing prototype wheels
Tires
Front Michelin Pilot Sport, 235/35ZR18
Rear Michelin Pilot Sport, 235/35ZR18
Exterior
Body
2000 Ford Focus with a Ford Racing wide body
treatment including all carbon-fiber hood, front fascia,
front fenders, rocker panels, rear quarter panels,
rear fascia and rear wing, European Focus
four-door tail lamps, FR200 badging and
unique DuPont silver paint.
Interior
Color, Trim, Instrumentation
Seating Ford Racing/Classic Soft Trim
two-tone sport leather upholstery
Steering Wheel Ford Racing prototype two-tone leather steering wheel
Gauges 180 mph speedometer, 8000 rpm
tachometer, boost, water temp and oil pressure
Audio System
Tuner JBL TrafficPro Radio/CD/Navigation system
Speakers 11 strategically placed high performance JBL speakers
Amps Two four-channel pre-amp units
One eight-channel mobile amplifier
System Power 570 watts total power
Dimensions
Wheelbase 103.0 inches
Length 168.1 inches
Track, ft/rr 62.8-inch front/62.5-inch rear
Curb Weight 2780 lbs.
Weight Distribution 61%/39%
Performance
Torque 285 lb/ft torque @ 3500 rpm
0-60 mph 5.5 seconds (Ford est.)
Quarter Mile 13.5 seconds/108 mph (Ford est.)
[HOONIGAN]
iTroll
Old 02-13-2012, 03:43 PM   #15
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,249, Level 46
Points: 5,249, Level: 46 Points: 5,249, Level: 46 Points: 5,249, Level: 46
Level Up 50% Completed
FF Reputation: 68 TerryB Excellent Standing Member
Ummmm.........I started this for a little fun. Relax.
TerryB is offline
Old 02-13-2012, 04:02 PM   #16
Minchkin
Minchkin's Avatar
Fan#: 92792
What I Drive: 2009 Black SES Coupe
Points 948, Level 16
Points: 948, Level: 16 Points: 948, Level: 16 Points: 948, Level: 16
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 3 Minchkin Good Standing Member
The dashboard... It is still the stock color. But the gagues on it I am sure aren't....
Originally Posted by Fact Core from Portal 2
Before the Wright Brothers invented the airplane, anyone wanting to fly anywhere was required to eat 200 pounds of helium.
SES #032
Minchkin is offline
Old 02-13-2012, 04:04 PM   #17
teamDFL
teamDFL's Avatar
Fan#: 92060
Brake master cylinder. Believe it or not, the hydraulic requirements of the stock Focus braking system and that of a Mustang Cobra are nearly identical.
teamDFL is offline
Old 02-13-2012, 04:07 PM   #18
xxMichaelAnthony
Fan#: 58459
[HOONIGAN]
iTroll
Old 02-13-2012, 04:09 PM   #19
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,995, Level 40
Points: 3,995, Level: 40 Points: 3,995, Level: 40 Points: 3,995, Level: 40
Level Up 23% Completed
FF Reputation: 14 mac.mogul Great Standing Member
I used to have a model of the FR200 from around the time it came out. Pretty cool concept, but that nose.... hahahaha
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 02-13-2012, 04:12 PM   #20
xxMichaelAnthony
Fan#: 58459
Originally Posted by mac.mogul View Post
i used to have a model of the fr200 from around the time it came out. Pretty cool concept, but that whole exterior.... Hahahaha
fixed!!
[HOONIGAN]
iTroll
