My 2000 Ford Focus wont crank up - Focus Fanatics
Old 02-12-2012, 10:02 AM   #1
xScreamerSE
Fan#: 90662
What I Drive: 2000 Black-Black Flowmaster Cat SE
FF Reputation: 1 xScreamerSE Good Standing Member
Hey guys i have a 2000 Ford Focus SE, One day when i was about to head out to school my pushed in the clutch and turned the key; NOTHING happened. So i checked the clutch switch and it's fine. I left with my grandma for school. That next day assuming it was the starter i bought a starter put it on, still NOTHING. I have no idea what happened all i remember is that the day before my car stumbled to start up.
I have no clue as to what could have caused this i really need it up and running again because im In a very important marching band program down here in South Florida/ Broward County.
When i turn my key the fuel pumps start up and all lights etc.
PLEASE HELP!!
xScreamerSE is offline
Old 02-12-2012, 11:50 AM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Many things could cause this , do you have ------- in the odometer , how did you check the clutch switch ? have you tried jumping it ? Small ground wire beside the Batt if off wont let the starter kick in
Low Batt voltage ? Fuses
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 02-12-2012, 01:59 PM   #3
xScreamerSE
Fan#: 90662
having a brain fart which is the odometer? and the little button under the clutch pedal; to see if anything was in the way and blocking it. havent tried jumping it. and any way you can show me this small ground wire?
just charged the battery the other night when i got the new starter. and ive checked my fuses and everything is good
Old 02-12-2012, 03:02 PM   #4
xScreamerSE
Fan#: 90662
sorry super brain fart yes everything is hooked up, but i need to see what this small wire your talking about looks like...
Old 02-12-2012, 04:36 PM   #5
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
FF Reputation: 86 BC_ZX3 Excellent Standing Member
Jump the neutral safety switch at the top of the clutch pedal as Tom suggested; that's the easiest one to check first. Pumping the clutch pedal sometimes works to free it up if it's stuck or not making proper electrical contact somehow.
What's the PATS light doing during an attempted start?
BC_ZX3 is offline
Old 02-12-2012, 07:01 PM   #6
xScreamerSE
Fan#: 90662
all my lights on my dash and gauges show fine even my AF ratio gauged. I have Zetec so is this nuetral switch black with a grey button on it... what could be the issue though. I will attempt to jump it though... can one of you guys Message me to make this faster. or text me. i will provide the number in the message.
Old 02-12-2012, 07:53 PM   #7
pasta
Fan#: 62350
What I Drive: 2003 eap svt
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (36)
there is like tom said a little wire that goes to ground on battery i did the same thing when changing battery i ripped wire off and car would not start so i got same size wire and fixed it car started up fine so look around the battery for wire
pasta is offline
Old 02-12-2012, 08:26 PM   #8
xScreamerSE
Fan#: 90662
k ill check for it, thnx, can you guys add me, just in case..?
Old 02-13-2012, 06:58 AM   #9
xScreamerSE
Fan#: 90662
i didnt find small black wire. There are like three connected to the ground from the battery is it one of these? one of them leads from the battery, to behind it and down into the engine bay. Might this be it?
Old 02-13-2012, 08:33 AM   #10
winterbeater
Fan#: 93035
What I Drive: 2001 blue wagon
FF Reputation: 3 winterbeater Good Standing Member
Did you try jumping the clutch safety switch yet? Pull the plug off and run a little wire between the plug sockets. Just make sure you don't start it in gear and hurt somebody.
winterbeater is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
