Eibach Pro Kit vs Sportlines MY12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
View Poll Results: Pro Kit vs Sportline
Pro Kit 13 48.15%
Sportline 14 51.85%
Voters: 27. You may not vote on this poll
Old 02-11-2012, 01:34 AM   #1
FordBass
Fan#: 89775
What I Drive: 2012 Black SE Sport
FF Reputation: 1 FordBass Good Standing Member
My plan for this summer is to get new springs and new wheels/tire.
It is of course a DD and i will take it to autocross a few times and i am a spirited driver.
So thus i contemplate if sportlines would be best because they will provide more aggressive handling but will be a harsher ride.
Or pro kit because it is an improvement and will retain a better ride quality but lack in overall performance.
Second thought is the appearance, do the sportlines make it look strange for being so low?
Pro Kit
http://performance-suspension.eibach...us_pro-kit.pdf
Sportline
http://performance-suspension.eibach..._sportline.pdf
And my idea of what i would like to do
FordBass is offline
Old 02-11-2012, 02:06 AM   #2
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 7,594, Level 58
Points: 7,594, Level: 58 Points: 7,594, Level: 58 Points: 7,594, Level: 58
Level Up 22% Completed
Forum Activity 30%
FF Reputation: 10 Blue5ive Great Standing Member
Buy-Sell-Trade Rating: (8)
Hard to say since you have a 2012. Normally the sportlines while being a 2" drop are not very aggressive at all on the earlier year models. Most actually say they are soft for a 2" drop. Good for dd but not that great for autox. Of course they will probably handle better than stock but they will not handle as well as say H & R's which are a more aggressive rate spring.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is online now
Old 02-11-2012, 10:10 AM   #3
bflesher
Fan#: 84132
What I Drive: 2002 sangria red zx3, 02 yellow zx3
Points 135, Level 2
Points: 135, Level: 2 Points: 135, Level: 2 Points: 135, Level: 2
Level Up 70% Completed
FF Reputation: 1 bflesher Good Standing Member
I've heard the sport's are to soft for autox and since they are progresive, when you hit the rate change they just stop. Not sure if they have changed anything with the 12's though, maybe a little different rates.
bflesher is offline
Old 02-11-2012, 12:56 PM   #4
Trevor@TireRack.com
Trevor@TireRack.com's Avatar
Fan#: 94016
FF Reputation: 2 Trevor@TireRack.com Good Standing Member
For occasional track days, the sportline is not ideal, but it will give you more control of the vehicle and is better than stock. They are right, something like the H&R Super Sport or the Race spring is better for track, but it will greatly decrease ride quality. It's a little over kill for a daily driver with occasional track days if you ask me.
Trevor
888-428-8355 ext. 795
Trevor@TireRack.com
Remember to reference Trevor/FocusFanatics in the "previous contacts" field to make sure the forum get's credit!
Trevor@TireRack.com is offline
Old 02-11-2012, 02:03 PM   #5
FordBass
Fan#: 89775
Hmmm, had 215/45/17 and koni coilovers on my cavy. That was not bad commuting but potholes and large bumps did kill. Though that had ~300lb ish or more spring rates and was lowered 2.5".
I guess i'll see about going for some rides with friends and see how there cars ride with springs/coilovers and decide if i can live with a harsher ride.
FordBass is offline
Old 02-11-2012, 02:46 PM   #6
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
FYI, Pro kit springs are stiffer than the Sportlines. So, if you're looking for AutoX performance, the Pro Kits are the way to go. I'd also recommend either Eibach's or Steeda's 25mm rear sway bar.
PRO-KIT TECHNICAL INFORMATION
FRONT:
OE rate: 20 N/mm (114 lbs/in)
PK rate: Progressive 27-47 N/mm (154-268 lbs/in)
Isolator Tubing: None
Bump-stop: New Eibach bump-stop
Damper: OE
OE wheel center to fender: 368 mm (14.5 in)
PK wheel center to fender: 348 mm (13.7 in)
Front Alignment:
OE Camber = -0.5 +/-0.8 deg
OE Caster = 4.3 +/-0.8 deg
OE Total Toe = 0.20 +/-0.10 deg
PK Camber = -0.5 deg
PK Caster = 4.3 deg
PK Total Toe = 0.20 deg
PRO-KIT can be aligned to factory specifications.
Approximate installation time: 1.0 hr
REAR:
OE rate: 25 N/mm (143 lbs/in)
PK rate: Progressive 33-43 N/mm (188-245 lbs/in)
Damper: OE
OE wheel center to fender: 369 mm (14.5 in)
PK wheel center to fender: 349 mm (13.7 in)
Rear Alignment:
OE Camber = -1.4 +/-0.8 deg
OE Total Toe = 0.38 +/-0.33 deg
PK Camber = -2.0 deg
PK Total Toe = 0.38 deg
PRO-KIT can be aligned to OE specifications.
SPORTLINE TECHNICAL INFORMATION
FRONT:
SLK rate: Progressive 23-30-50 N/mm (131-171-285 lbs/in)
Isolator Tubing: Yes
Damper: OE
SLK wheel center to fender: 330 mm (13.0 in)
Front Alignment:
SLK Camber = -0.6 deg
SLK Caster = 4.3 deg
SLK Total Toe = 0.02 deg
Sportline-Kit can be aligned to factory specifications.
REAR:
SLK rate: Progressive 25-38-48 N/mm (143-217-274 lbs/in)
Damper: OE
SLK wheel center to fender: 331 mm (13.0 in)
Rear Alignment:
SLK Camber = -1.4 deg
SLK Total Toe = 0.38 deg
Sportline-Kit will require additional alignment kit 5.67420K to align to factory specifications.
Zillon is offline
Old 02-13-2012, 10:33 PM   #7
newmission
newmission's Avatar
Fan#: 84688
What I Drive: YB-MK3-MTX-SE-OG Sport-HB
FF Reputation: 5 newmission Good Standing Member
I voted PK because that's what I have. BUT, for your ride height you desire, it seems you want the SLK hands down.
Now Zillion made an AWESOME comparison find! I am actually quite happier now that I now the PK springs start higher than the SLK springs.
Hatch Nation #110
Debadge-and Drive Naked
Home of the Free Blacked Out Grille Mod, and Griffin Ram Air Mod.
Get you some!
newmission is offline
Old 02-14-2012, 11:09 AM   #8
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,801, Level 76
Points: 13,801, Level: 76 Points: 13,801, Level: 76 Points: 13,801, Level: 76
Level Up 38% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
I like the Sportline system. If I wanted more low, I would have gone w/ H&R's Sport cup kit.
felixthecat is online now
Old 12-20-2012, 10:13 AM   #9
TEK30001
Fan#: 94657
What I Drive: 2006 Focus ZX5
Points 20, Level 1
Points: 20, Level: 1 Points: 20, Level: 1 Points: 20, Level: 1
Level Up 39% Completed
FF Reputation: 1 TEK30001 Good Standing Member
Has any one ever order from:
http://massivespeedsystem.com/
I just order my Massive OMNI-KIT Suspension Adaptor for my car.
Hope this is the last thing I need for my Eibach 3588.680 Pro-System-Plus Suspension Kit.
I was so happy to get it than I found out I will need that OMNi-KIT.
TEK30001 is offline
Old 12-20-2012, 10:14 AM   #10
TEK30001
Fan#: 94657
Points 20, Level 1
How can I add photos to this page?
TEK30001 is offline
