HELP with xcal3 error message 1019 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-08-2012, 08:47 PM   #1
Dago
Dago's Avatar
Fan#: 33842
What I Drive: 2004 comp orange svt
Points 4,550, Level 42
Points: 4,550, Level: 42 Points: 4,550, Level: 42 Points: 4,550, Level: 42
Level Up 50% Completed
FF Reputation: 1 Dago Good Standing Member
Exclamation HELP with xcal3 error message 1019
I got a new xcal3 from Tom, he sent me a file wich I succesfully loaded to the device but when I try to load it to the car it shows this message "1019 unlock ecm failed" then I press select and shows other message saying it wasn't able to return to stock an then another one saying no tune written, I've called sct and they told me to remove all the following fuses #46 and #61 and radio fuse on passenger compartment and the fuel pump fuse in the engine compartment and nothing has worked, I've tried different things, I also disconnected the battery for a while to reset the ecu and nothing has worked. Has anyone has deal with this before?
JRSC BBK tuned by Tom, 65mm TB, 180 deg thermostat, aem wideband, 9mm ford racing wires, removed lunchbox, CFM hfc, front suspension polyurethane bushings, hella dynabeam headlights, keenwood ddx512
John 3:16
Dago is offline
Old 02-08-2012, 09:48 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,553, Level 100
Points: 52,553, Level: 100 Points: 52,553, Level: 100 Points: 52,553, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (28)
Have you tuned this car before ? I wonder if it had a previous tune on the car and its still in there ?
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 02-08-2012, 10:14 PM   #3
bespurcell
bespurcell's Avatar
Fan#: 60917
What I Drive: 2003 black svt
FF Reputation: 2 bespurcell Good Standing Member
This happened to me and by messing around with the position of the ignition switch I finally got it to work.
Dominant Eng. orp, ITG Maxogen panel filter, Focus-Power tune, Team Dynamic Pro Race 2 16x7 wheels in black(36 lb weight reduction from stock tire/wheel combo)
bespurcell is offline
Old 02-09-2012, 09:33 AM   #4
focussvt444
Fan#: 83425
What I Drive: 2002 silver svt
FF Reputation: 1 focussvt444 Good Standing Member
I had the same kind of problem with my svt You need to be sure the battery in the car is fully charge and put a booster pack on it to make sure there no tension variation and it should work you need to reinstall the stock tune before and then the custom tune
focussvt444 is offline
Old 02-09-2012, 06:48 PM   #5
Dago
Dago's Avatar
Fan#: 33842
I got it to work, actually one wire that comes out of the back of the obd port connector was broken, I soldered it back together and it began to write the tune, the problem now is that when I try to write back the stock file it crashed, and now it doesn't let me go back to stock it freezes at 4% writing the stock file, sct already formatted the device and they even sent me a recovery stock file but it doesn't works, still the same, so my last option is to go to a dealer and get it reflashed, I'll let you guys know how this story ends.
John 3:16
Dago is offline
Old 02-09-2012, 09:02 PM   #6
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,880, Level 59
Points: 7,880, Level: 59 Points: 7,880, Level: 59 Points: 7,880, Level: 59
Level Up 65% Completed
Forum Activity 14%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
Posted via FF Mobile That's exactly the same thing that happened to me when I was loading my tune.
When I called and talked to Sct about it, they told me it was a firmware issue and they were having trouble with it on the 07's.
Trying to load the tune and the firmware issue wiped my ecu clean and all that was showing up on my odometer were ----- in place of the mileage. I had to have it towed to the dealer get it reflashed so it would crank. then had to send the flasher
back to sct to have it reset. Then got it back loaded Tom's tune and as soon as you plug it in the port and it asked for you to turn the key on but do not start the engine. The key needs to already be in the on position. that was what it took to get my tune loaded.
FocusedSlayer is offline
Old 02-12-2012, 05:57 AM   #7
Dago
Dago's Avatar
Fan#: 33842
Same story but they told me to get it reflashed back to stock to the dealer and then try again to put it back to stock with the xcal, but it did the exact same thing and now my car shows again only dashes on the odometer. I'm really frustrated with this, the car is my dd so this is really bad.
John 3:16
Dago is offline
Old 03-01-2012, 02:35 PM   #8
svtf1417
MOAR BEWST!!!!
svtf1417's Avatar
Fan#: 58428
What I Drive: 2001 ZTS, 2002 SVTF Turbocharged
Points 6,870, Level 54
Points: 6,870, Level: 54 Points: 6,870, Level: 54 Points: 6,870, Level: 54
Level Up 60% Completed
FF Reputation: 6 svtf1417 Good Standing Member
Buy-Sell-Trade Rating: (6)
I'm excited to see what happens when you get your livewire, hope it fixes it.
I started another thread in here not to long ago stating the exact same problem with my ecu being wiped clean and showing dashes and it needing to be bench flashed. But like I talked about to you earlier I'm also in need of a reliable solution, and soon.
[#1417] 2002 Sonic Blue SVT Focus
Born on June 25, 2002
2001 Silver ZTS Sedan - "Ol' Reliable"
svtf1417 is offline
Old 03-03-2012, 03:42 PM   #9
1sloho
12 years strong
1sloho's Avatar
Fan#: 111
What I Drive: '02 zx5
Points 14,518, Level 78
Points: 14,518, Level: 78 Points: 14,518, Level: 78 Points: 14,518, Level: 78
Level Up 17% Completed
FF Reputation: 17 1sloho Great Standing Member
I'm getting these same error codes on my 02. Any insight as to how to load the tune would be appreciated.
1sloho is online now
Old 03-03-2012, 06:56 PM   #10
1sloho
12 years strong
1sloho's Avatar
Fan#: 111
ok...this is exactly whats happening with me but, i dont have any frayed or broken wires coming from the obd port. tried a variety of things such a keeping the radio off and pulling fuses but no luck. updated the firmware on the xcal as well. im stumped.
