Front wheel bearing replaced - now ABS light is on - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-08-2012, 11:26 AM   #1
biederboat
Fan#: 9840
What I Drive: 2000 ZTS
Points 878, Level 15
Points: 878, Level: 15 Points: 878, Level: 15 Points: 878, Level: 15
Level Up 78% Completed
FF Reputation: 1 biederboat Good Standing Member
Okay, I did some searches but couldn't find anything really conclusive. Had a whining front wheel bearing. Bought a replacement, just telling the parts guy what car I had (wasn't asked with or without ABS). Had a shop press it in. At first, the ABS sensor wouldn't go in as the snap ring opening wasn't positioned correctly. I fixed that, got it all in, ABS light is on.
I'm trying to get answers on two things:
1. Are there ABS and non-ABS bearings?
2. Does it really matter which way the bearing is pressed in?
I went back to the parts place, they said the same bearing is spec'd out for with & without. I looked at the bearing before it went in and can't recall seeing any difference in how it went in.
If none of the above matters, anything else it could be that went wrong during the R&R? I did check the connection, looks okay.
Thanks,
BB
biederboat is offline
Old 02-08-2012, 11:47 AM   #2
lexington523
lexington523's Avatar
Fan#: 84279
What I Drive: 2012 Yellow Titanium
Points 1,044, Level 17
Points: 1,044, Level: 17 Points: 1,044, Level: 17 Points: 1,044, Level: 17
Level Up 44% Completed
FF Reputation: 3 lexington523 Good Standing Member
When I replaced my rear wheel spindle and hubs my ABS light came on. It took 3 days for the computer to "relearn" the signal aparently. After 3 days the ABS light went out and has been ok for 9 months now. This happened even though I was using the same ABS sensors. Aparently being disconnected can affect their relationship with the computer. Wait a few days of normal driving and see if it goes out.
lexington523 is offline
Old 02-08-2012, 12:04 PM   #3
biederboat
Fan#: 9840
Thanks, but this has been on for 3 months. Car's so old and has so many other problems it's hard to know where to start but I sure would like my ABS again!
BB
Old 02-08-2012, 05:27 PM   #4
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 14 SE hatch
Points 2,392, Level 29
Points: 2,392, Level: 29 Points: 2,392, Level: 29 Points: 2,392, Level: 29
Level Up 62% Completed
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
you got a NON-ABS bearing. the pick-up ring is in the bearing. only fix it put in a ABS bearing.
OR
you got a ABS bearing and they pressed it in backwards
Mike_Mac is offline
Old 02-08-2012, 05:40 PM   #5
97f150
Fan#: 91463
What I Drive: 03 ZX3
FF Reputation: 1 97f150 Good Standing Member
Yes same wheel bearing for ABS non ABS but one side of the bearing is black I believe and that side must be pressed in facing the sensor. So the bearing is more than likely pressed in backwards.
97f150 is offline
Old 02-08-2012, 11:59 PM   #6
biederboat
Fan#: 9840
Okay, I guess the next one I'll buy will make sure it's spec'd for ABS. I am assuming that you can't pull out the existing bearing (if it's an ABS type) and just reverse it (i.e. it would destroy the bearing)?
BB
Old 12-25-2013, 12:55 PM   #7
kkblparker
Fan#: 116204
What I Drive: 2005 black ZX4 ST
FF Reputation: 1 kkblparker Good Standing Member
I got my bearings from advanced auto same part number gave me to diffrent boxes with two differnt bearings one was abs one was not the one with looked like the seal was different and attracted to my fridge I would get a finger nail sized peace of steal and see if it sticks to it one one Side be for buying jus to double check
kkblparker is offline
Old 12-25-2013, 09:55 PM   #8
Bonesacked
Bonesacked's Avatar
Fan#: 113745
What I Drive: 2000 Silver ZX3
Points 965, Level 16
Points: 965, Level: 16 Points: 965, Level: 16 Points: 965, Level: 16
Level Up 65% Completed
FF Reputation: 1 Bonesacked Good Standing Member
I'm pretty sure there's only one bearing, just ABS. It wouldn't be cost effective to make two types of them. The bearing was put in backwards. This actually happened to me too, only they completely broke the bearing putting it in, and I gave them the knuckle assembly directly instead of having my car serviced.
Removing the bearing will destroy it, they can't be reused.
Bonesacked is offline
Old 12-26-2013, 05:33 PM   #9
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,379, Level 20
Points: 1,379, Level: 20 Points: 1,379, Level: 20 Points: 1,379, Level: 20
Level Up 79% Completed
FF Reputation: 1 coldbear Good Standing Member
An ABS wheel bearing has a different colors at each end. Black at one end, red on the other. One would think that the manufacture would color the sensor end in red. But the correct answer is the black side goes toward the sensor. If you ever screw one of these up, as I have done, you'll never forget the bearing location. Hope this helps.
coldbear is offline
Old 05-31-2014, 09:02 AM   #10
MstrTeK
Fan#: 166954
What I Drive: 2002 Toyota Prius
FF Reputation: 1 MstrTeK Good Standing Member
The best way to know for sure is get a paperclip or like metal object. The Tone Ring is really just a magnet built into the bearing. Place the paperclip on each face of the bearing. The paperclip will stick to one side and not the other. The magnet side goes toward the ABS Sensor.
MstrTeK is offline
