How successful is using Dynamat? - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-29-2013, 02:26 PM   #41
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,774, Level 54
Points: 6,774, Level: 54 Points: 6,774, Level: 54 Points: 6,774, Level: 54
Level Up 12% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
Originally Posted by Njk570 View Post
Fill it with expanding foam. That'll do the trick. Before i had my Focus i had a Fiesta, 2011. I was running Two Sundown Audio 12s, along with a Rockford T-1500 BDcp, which pushed almost 2000w RMS. I tried everything, and nothing seemed to work, but then i tried the expanding foam, and the results were fantastic.
You are not explaining the importance of protecting wiring, etc.
Are you telling this member that expanding foam is a be all end all? I do have a little in my car but, it is for a certain thing.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 01-29-2013, 07:41 PM   #42
02Zetechse
02Zetechse's Avatar
Fan#: 65832
What I Drive: 2002 Satin Black SE
FF Reputation: 6 02Zetechse Good Standing Member
The majority of road noise will come from the floor, fender wells, and cargo area... I noticed a 2db reduction from deadening my floor . the only places IMO that foam belongs, is places where structural bracing and sheet metal can hit against each other.
Id stay away from Higher End applications like Second Skin and Dynamat, no matter what you do its gonna make a difference. I would only recommend higher end stuff if you were planning on doing some car audio work to it. But in terms rattle, even the cheap stuff will be just fine. Look into Fat Mat and Rattle Trap. Best bang for the buck in my book.
As for this, how many layers of the "cheap stuff" is needed to make the same difference one layer of higher end product ? the cost of Peel and seal times the amount of layers needed almost equals the price of the good stuff. Deadener does not stop rattles 100% , hence why expanding foam or additional bracing is needed in certain areas.
Current : 2 15s 149.5@56hz 2k rms Previous Trunk box 1 18 ,146.4@43hz 3500rms,Sony 12s 145.6@63hz
02Zetechse is offline
Old 01-29-2013, 08:40 PM   #43
Njk570
Fan#: 109191
What I Drive: 2012 Ford Focus Titanium
FF Reputation: 1 Njk570 Good Standing Member
Also note though, most people misunderstand what Dynamat, Second Skin, Peel and Seal, etc is really for. All that stuff really does is add weight to panels and what not, to prevent them from vibrating more. More weight= less vibration. Yes, it will help with road noise slightly, but its not the best route to take if you wish to kill outside noises. Second Skin makes something thats called Luxury Liner, which is a layer of foam almost that you roll out in the car. I would recommend apply that to your floors and whatnot if you want to really "deaden" the car.
Njk570 is offline
Old 01-29-2013, 08:42 PM   #44
Njk570
Fan#: 109191
Im telling him i got better results from the foam rather than Sound Deadener.
Njk570 is offline
Old 01-30-2013, 11:16 AM   #45
02Zetechse
02Zetechse's Avatar
Fan#: 65832
well yes mass loading a panel is the most common way to deaden a vehicle, but you also miss the fact that alot of deadeners also absorb vibration from the exterior and convert it into low level heat, peel and seal is pure mass loading, no other benifit
Old 01-30-2013, 01:32 PM   #46
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 49%
02Zetechse covered that.
When my windows are up, you can barely hear my system on the outside. Which is good because it decreases the chances of my system getting jacked.
Covering deadener with Ensolite(closed cell foam)helps a lot also is a good(cheaper)option as well. MLV(Mineral or, Mass Loaded Vinyl)is a great option as well. But getting it to stick on things that are not the floorpan can be tricky.
Hatch Nation #140
freemind is offline
Old 01-30-2013, 03:42 PM   #47
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
What I Drive: 2000 silver zx3
Points 4,255, Level 41
Points: 4,255, Level: 41 Points: 4,255, Level: 41 Points: 4,255, Level: 41
Level Up 53% Completed
Forum Activity 3%
FF Reputation: 6 alaskanzx5 Good Standing Member
its a simple choice. either you can cheap out and do what people say works or do it right and do what is proven to work.
hn155: Rockford punch pro speakers, t400.4 deh 80prs, full audio build to come. working towards 175hp n/a, simple but fun.
alaskanzx5 is offline
Old 01-30-2013, 06:40 PM   #48
02Zetechse
02Zetechse's Avatar
Fan#: 65832
This right here , is the truth .... halfass product equals half ass results
Old 01-30-2013, 08:38 PM   #49
Njk570
Fan#: 109191
Is the ass half full or half empty?
Njk570 is offline
Old 01-31-2013, 02:12 PM   #50
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
neither, it not half full or half empty. it is full, just not correctly.
