42lb inyectors or 60lb? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-06-2012, 02:14 AM   #1
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Hey I'm making my own turbo kit I have almost everything, I only have two Qs? I'm installing a super 60 stage 3 turbo I'm going to put a 3inch downpipe with 3inch exhaust cutout, knock off intake manifold,and 42lb inyectors my engine is stock but I'm trying to get the most out of it should I get the 60lb inyectors? I'm gonna push only 12 psi and the other question is my waste gate have 2 springs inside should I take out one?
Thanks in advance
Posted via FF Mobile
koke'sfocus is offline
Old 02-06-2012, 03:51 AM   #2
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
Points 21,108, Level 91
Points: 21,108, Level: 91 Points: 21,108, Level: 91 Points: 21,108, Level: 91
Level Up 52% Completed
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (16)
2 springs means it will be 14psi from my experience unless its a stupid strong spring. so yes take it out and get a boost controller. Also go with 60 pound injectors so you wont have to change them when you want more pooowwwwaaaa later.
Also sounds like that turbo is going to be way to big for what your going to be doing.
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq
01 Turbo Focus 300+ whp
2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq
FocusBoy58 is online now
Old 02-06-2012, 07:44 AM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
You need to run the spring/spring combo to make your target boost , I would also go with the 60lb Inj
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 02-06-2012, 10:35 AM   #4
koke'sfocus
Fan#: 69779
Tom do u think is the turbo is way to big? And so should I leave both springs? I know one is for 14 psi and the other is 7 psi I think
Old 02-06-2012, 02:37 PM   #5
Dgc333
Fan#: 85422
What I Drive: 2012, candy blue, SEL
Points 750, Level 14
Points: 750, Level: 14 Points: 750, Level: 14 Points: 750, Level: 14
Level Up 50% Completed
FF Reputation: 1 Dgc333 Good Standing Member
Can someone educate me?
If you are only running 12 psi of boost why would you want a 60lb injector?
My years of Mopar 4cyl turbo experience the T2 engines that ran 12 psi of boost stock came with 30lb injectors and full Super 60 setups with cams and head work that ran 18 psi only used 50 lb injectors.
I would think that ecu would have a hard time throttling down a 60 lb injector for off boost driving resulting in the engine being overly rich.
Dgc333 is offline
Old 02-06-2012, 03:58 PM   #6
Rod H
Rod H's Avatar
Fan#: 53555
What I Drive: 1959 Austin Healey (Zetec Engine)
FF Reputation: 1 Rod H Good Standing Member
Here's a simple injector size calculator. The size injector you need is based on the horsepower your going to make. The BSFC is greater for a turbo/SC than a NA engine so be sure to take that into consideration.
http://www.gtsparkplugs.com/InjectorSizeCalc.html
R
Rod H
The older I get the more cynical I become, but, I can't keep up
Rod H is offline
Old 02-06-2012, 08:24 PM   #7
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
I'm using 42lb injectors in my ST.
Your sure the springs aren't one=7 psi and the two combined=14 psi? To hit your target boost you will want to use the exact spring or a spring that is rated lower than the target boost and then use a boost controller to up it to your target pressure. You cannot get a lower boost pressure than what your spring is rated for.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 02-06-2012, 08:53 PM   #8
koke'sfocus
Fan#: 69779
one is 7 and the other 14 i think one i longer than the other one so i should only use the longer one right? is less stiff
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
Old 02-07-2012, 09:24 AM   #9
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 61%
I would do the 60lb hands down , the ECU can do 130+lb Inj and drive and idle like stock thats all up to your tuner and how good he is
The T3 S60 STGIII should work very good for you
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 02-07-2012, 02:19 PM   #10
koke'sfocus
Fan#: 69779
Ok thanks tom and everybody :)
