Coolant Question -Is this normal? - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-18-2012, 07:28 AM   #51
kbass24emtp
Fan#: 87665
What I Drive: 2012 Sonic Blue Focus SEL
Points 75, Level 1
Points: 75, Level: 1 Points: 75, Level: 1 Points: 75, Level: 1
Level Up 50% Completed
FF Reputation: 1 kbass24emtp Good Standing Member
I think the gunk is some type of assembly lube or something left over from it getting built. My 2012 F150 has the same coolant and it is clear as can be. Totally different looking from our Focus There is just over 15000 miles on the Focus now and the gunk on the cap is not accumulating like when it was new and the coolant only has a slight film occasionally. Weird
kbass24emtp is offline
Old 06-18-2012, 08:35 AM   #52
got3fords
Fan#: 93395
What I Drive: 2012 Sterling Gray SE Sport HB 203A
FF Reputation: 1 got3fords Good Standing Member
Originally Posted by hotpass105 View Post
This post is so ignorant it makes me mad. Firstly, do you understand what boiling is? It is a process in which water evaporates and turns into steam. The only thing that is going to be carried up onto the radiator cap is H20. Any solids would be to heavy and remain in the coolant. *End Rant*
You do realize that gasoline and other products are derived from crude oil by BOILING it? I thought not. Its hard to tell what happens to oily contaminants in the cooling system when the temperature reaches 200 degrees or so.
got3fords is offline
Old 06-18-2012, 08:43 AM   #53
csvt2060
csvt2060's Avatar
Fan#: 84122
What I Drive: 2013 Ford Escape Titanium
FF Reputation: 2 csvt2060 Good Standing Member
It seems like this car now has the reputation by Ford shops to "not touch it" and "it's normal" unless corporate tells us otherwise.
To the person who replaced the coolant with non-Ford coolant. I would be careful with that as it's a speciality coolant from the factory, and you don't need another reason for Ford to deny service and/or warranty in the future.
csvt2060 is offline
Old 06-18-2012, 09:28 AM   #54
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Well, they certainly won't "boil off". The boiling point of water/coolant mix in a pressurized system is about 255 degrees @ ~14PSI. Of course, the boiling point of oil will be much higher than that.
If the water/coolant mix in your cooling system is reaching those temperatures, you have more important things to worry about than oily contaminants!
Hatch Nation #90
TboneZX3 is offline
Old 06-18-2012, 09:36 AM   #55
got3fords
Fan#: 93395
Right, the coolant won't boil, but there may be other contaminants with varying boiling points.
Old 06-23-2012, 09:43 AM   #56
prv5004
prv5004's Avatar
Fan#: 90916
What I Drive: 2012 Black SE Sport Hatch 5-spd
FF Reputation: 1 prv5004 Good Standing Member
Warning noted. I may switch back to the orange coolant eventually, but so far the yellow is still nice and clear.
prv5004 is offline
Old 04-08-2013, 04:49 PM   #57
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,090, Level 34
Points: 3,090, Level: 34 Points: 3,090, Level: 34 Points: 3,090, Level: 34
Level Up 27% Completed
Forum Activity 3%
FF Reputation: 15 PratoN Great Standing Member
I realized my coolant was noticeably low this weekend (maybe an inch below the MIN line) and - especially at 50 degrees - I would think the coolant should be higher than the MIN line...
Anyway, I opened the cap at saw this same build-up. Has anyone gotten any closure on this issue? Should I bring it up to the dealer or just clean it and top it off?
(Also noted on this thread: http://www.focusfanatics.com/forum/showthread.php?t=306659)
PratoN is online now
Old 04-08-2013, 08:41 PM   #58
got3fords
Fan#: 93395
Don't sweat it. You would have to have a perfectly clean block on assembly not to have anything in there. It's no big deal!
Old 12-06-2013, 06:06 PM   #59
prv5004
prv5004's Avatar
Fan#: 90916
Just to update everyone, I sold my car about 7 or 8 months (another 10k miles) after I replaced the reservoir tank and switched to yellow coolant, but it remained perfectly clear for that remaining period of time.
I think I mentioned somewhere that a new coolant tank can be purchased from fordparts.com as part number 8A080.
prv5004 is offline
