oxygen sensor graph review help. Cat dead? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-02-2012, 09:13 AM   #1
fast*st
Fan#: 93319
What I Drive: 1999 F350 Dually, 03 SVT ZX3
FF Reputation: 1 fast*st Good Standing Member
So managed to graph oxygen sensor output on the Focus SVT, cleaned the MAF, changed the PCV and trying to track down a P0420.
Red is front, green is rear, it seems like the voltage is lower on
the rear but not sure if its enough. On the standard xl graph
view for O2 sensor voltage, the rear is graphed on an 11 volt
scale and the front is a 1 volt scale so the rear looks smooth.
Any input appreciated!!
fast*st is offline
Old 02-02-2012, 12:27 PM   #2
fast*st
Fan#: 93319
Not sure if its relevant, did reset the MIL and the system isn't ready for testing yet, only 20 miles since reset.
fast*st is offline
Old 02-02-2012, 01:49 PM   #3
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 00 infared ZTS
Points 2,383, Level 29
Points: 2,383, Level: 29 Points: 2,383, Level: 29 Points: 2,383, Level: 29
Level Up 56% Completed
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
P0420 is for a failed/failing cat or bad rear o2
the rear o2 should be very close to a straight line (if i remember correctly)
Mike_Mac is offline
Old 02-02-2012, 06:49 PM   #4
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
Yeah, that's correct. I don't really understand some of the markings on the graph but those should both be between 0-1V. The front should fluctuate fairly quickly between 0-1V and average about .45 to .5V. The rear should be a basically straight line, it's mostly there to show the PCM that the front is maintaining the correct average.
The fact that you're getting a signal means the wiring is okay, I'd just replace the rear sensor, clear any codes, and retest it however you did that graph. How did you do that graph anyway?
6SPD_soul is offline
Old 02-02-2012, 08:16 PM   #5
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,854, Level 100
Points: 51,854, Level: 100 Points: 51,854, Level: 100 Points: 51,854, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
Both look about right and they are switching
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 02-02-2012, 09:26 PM   #6
fast*st
Fan#: 93319
Thanks, the graph is from scanxl pro the voltage is 0 volts at the bottom, 1 volt at the top. The rear 02 sensor had failed and that is the new one, old one had o2 heater failure and no output. So there seems to be 2 schools, on a full dual cat system the rear is a flatline and the front is the cyclic pattern. On the smaller single cat they can both oscillate with the rear being of lower amplitude from the front. I'm just not sure what the correct SVT pattern is. Red is the front sensor, yellow is the rear.
fast*st is offline
Old 02-02-2012, 09:50 PM   #7
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
I guess I was wrong about how the o2 sensors work on the SVT, a lot of other cars with a dual bed (single housing) cat will have a front sensor with that swinging voltage wave and a rear sensor with more of a flatline.
So the graph shows a reading of the new rear sensor, and you don't have a CEL on again yet right? I got sidetracked by the fluctuations of the rear sensor and skipped the part about you driving 20 miles without a new CEL. If that's the case it's fixed and operating correctly, those are monitored continuously as soon as they are hot enough, after a minute or two of running and relaxed driving.
Old 02-02-2012, 10:32 PM   #8
fast*st
Fan#: 93319
Well, there are two different flavors of cat and oxygen sensor setups, I'm not sure which one the SVT is supposed to have. So yeah, new rear sensor shows a slightly lower swing than the front. I don't have the CEL yet but well, I'm not sure what it looked like last time it threw the code. The last time it took about 55-60 miles before it came up to pending and then came on ten miles later.
fast*st is offline
Old 02-03-2012, 06:37 AM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,762, Level 98
Points: 27,762, Level: 98 Points: 27,762, Level: 98 Points: 27,762, Level: 98
Level Up 42% Completed
Forum Activity 4%
I believe what you're referring to is the difference between narrow and wide band sensors. Some manufacturers use wide band sensors which display continuous readings- flat line- if you prefer. Typically those are used in conjunction with cheaper narrow band sensors resulting in one jumpy line, and one flat line on those readouts.
Those look fine dude, like Tom said. IMO your bank 1 sensor needs to be replaced since it's reading lower than the new rear sensor. It's working, but it would put out more voltage if it was new. You'll probably pick up 2 mpg with a new front sensor.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-03-2012, 09:30 AM   #10
fast*st
Fan#: 93319
Well, its worth a shot before doing anything drastic, thanks for looking it over! The rear sensor had zero output before I started troubleshooting, that was replaced, the front is original with 95k miles on it. Hopefully the cat is happy. Oddly enough, after a drive to warm it all up, at idle, the rear sensor smooths out quite a bit but not while driving.
So O2S11 (sensor 1 front?) is just a tick higher in voltage from O2S12 (sensor 2 rear?) A newer front sensor would increase the voltage and put it closer to happyland? its an easy parts swap so I'll try to knock that off today. Today shows a P0420 in pending status
fast*st is offline
