cant shut overdrive off - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-31-2012, 11:13 AM   #1
jeremy2717
Fan#: 94516
What I Drive: red 2001 focus se 4dr
FF Reputation: 1 jeremy2717 Good Standing Member
hi everyone im new here names jeremy from pa i just bought a 2001 se 4dr 2.0 zetec auto 139000 miles for my gf over the weekend. ive searched for the last couple days trying to figure some things out. rear windows dont work needs regulators not biggie had vibration changed pass motor mount fixed that no more vibration. but what i cant figure out now is i cant shut my overdrive off the button does nothing just clicks i know the light works it flashes when you start the car but while driving and pushing button nothing happens no light on dash doesnt shift out of overdrive nothing. can someone try to guide me in the right direction as how to get overdrive to shut off. i know this is kinda odd since most ppl want it to work but i would like to be able to shut it off when not on highway. thanks in advance hope someone around here can help im looking forward to seeing what you guys have to say jeremy
jeremy2717 is offline
Old 01-31-2012, 02:35 PM   #2
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,249, Level 46
Points: 5,249, Level: 46 Points: 5,249, Level: 46 Points: 5,249, Level: 46
Level Up 50% Completed
FF Reputation: 68 TerryB Excellent Standing Member
You may want to lift the center console to see if it's still plugged in. There is a tiny plug underneath. If any work had been done before, it's very easy to knock loose. You won't have to take the shifter out, but you'll have to find the plug.
TerryB is offline
Old 02-01-2012, 10:03 AM   #3
jeremy2717
Fan#: 94516
cool thanks ill take a look at that tonight when i drive it to work. any other ideas if thats not what the problem is. could the switch itself be bad? if so how hard is that to change. ill keep you posted on what i figure out
Old 02-01-2012, 11:00 AM   #4
PWGuy
Fan#: 91777
What I Drive: 2003 Pitch Black ZTS Sedan
Points 2,131, Level 27
Points: 2,131, Level: 27 Points: 2,131, Level: 27 Points: 2,131, Level: 27
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 PWGuy Good Standing Member
I have the same exact problem with my Overdrive.
PWGuy is offline
Old 02-01-2012, 11:07 AM   #5
jeremy2717
Fan#: 94516
Im going to check the plug tonight at work ill let u know if its the problem or not.
Old 02-01-2012, 08:31 PM   #6
jeremy2717
Fan#: 94516
Checked the plug tonight it was unplugged now od shuts off thanks for the help
Old 10-21-2013, 06:11 PM   #7
johnfre
Fan#: 120021
What I Drive: 2004 Grey Ford Focus Wagon ZTW
FF Reputation: 1 johnfre Good Standing Member
What is the procedure to reconnect that OD switch wire? Do you need to pull the shifter assembly out in order to do so?
johnfre is offline
Old 10-21-2013, 06:12 PM   #8
johnfre
Fan#: 120021
What is the procedure to reconnect that OD switch wire? Do you need to pull out the entire shifter assembly in order to do so?
johnfre is offline
Old 10-21-2013, 06:41 PM   #9
TerryB
TerryB's Avatar
Fan#: 34559
Nope. Lift the front of the center console. Remove screws under the cupholders. Remove the screws holding the armrest. Pull the ebrake all the way up. Then lift high enouth for access. It will be on the lower passenger side. You may have to looknfor it a bit. It's been quite a while since I fixed mine. I think I remembered all the steps correctly.
TerryB is offline
Old 10-21-2013, 07:16 PM   #10
johnfre
Fan#: 120021
Thanks Terry, I'll take a look. So if I understand correctly, I take it that you feed that wire into the metal shaft of the assembly that holds the shifting rod (pictured 2 posts above). then out an opening of that metal shaft and into its connector that you say is visible on the passenger side of the assembly?
johnfre is offline
