Getrag gear oil (hopefully the final thread on it) - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-06-2013, 12:32 AM   #21
Lscman
Fan#: 95211
What I Drive: 2007 ZX3
Points 1,224, Level 19
Points: 1,224, Level: 19 Points: 1,224, Level: 19 Points: 1,224, Level: 19
Level Up 24% Completed
FF Reputation: 9 Lscman Good Standing Member
Originally Posted by 1turbofocus View Post
Ford chooses the fluids for the MTX for what FORD plans the use of the car to be used for over the life of the car , when you change a car from its intent of getting you to work and for groceries to a performance car you then have to make other changes as well , engine oils and trans fluid is one of those changes
Change your fluids regular and it wont matter much what you put in there , they all will work , like stated I use mobile engine oil in the MTX-75 and the Getreg , I have never seen any improvement using the redline or RP lines of fluids and I am around some major teams that also have done testing and they dont use them either
To say a trans will go bad if you dont use the fluids ford says is silly as the car isnt being used for what Ford expected it to be used for
No way, it is not silly to state that certain fluids are not compatible. That is an ignorance-based position that will cause harm to member's hardware. This I know after working in the petroleum industry and rebuilding manual transmissions for 35 years. There are fewer than five 6spd getrag BMW M3/M5/540i tranny rebuilders in the USA and I'm one of them. The additives in GL5 hypoid gear fluids eat modern yellow metal, sintered or carbon-wrap synchros widely used since the early 80's. You can change the fluid daily and the chemistry will still be wrong. If you get 5 years out of the tranny you'll be lucky. This reminds me of my buddy who used gear lube in his beautiful $6K Husaberg one summer and it ate the nikasil bore coating. The drain pan looked like aluminum paint. Being around a race team does not make anyone a transmission or lubricity expert. All it does is coerse people into falsely assuming that race fluids are better or even OK for street. Redline is not approved for use in ANY street car, period. It is a competition fluid for competitors who are willing to wear out and rebuild their hardware on a seasonal or frequent regular basis simply to achieve fractional horsepower gains. I'm not going to rebuild my street car more often just to gain a couple HP or less. If you want your motor or tranny to last more than 10K miles, choose recommended fluids with proper certifications, ratings and formula. The factory fluid is $20/qt for a reason. The MTX-75 will easily last 300K mi with the proper lubricant and changes once every 100K mi. With the GL5 hypoid stuff the synchros will disintegrate until clearances exceed spec and it chronically grinds. My MTX-75 will never need rebuilt because I run the appropriate lubes. The chassis will rust away first. I've rebuilt over 20 track trannys and I know what the wrong lubes will do. The Supra, Mustang and BMW communities learned this long ago.
Lscman is offline
Old 02-06-2013, 12:17 PM   #22
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,240, Level 35
Points: 3,240, Level: 35 Points: 3,240, Level: 35 Points: 3,240, Level: 35
Level Up 27% Completed
Forum Activity 8%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
Ive been saying this since the FIRST fofo back in 2004 been using Amsoil 75w90 and now I use RP MAX Gear 75w90 (just cause i get it a little cheaper) and will continue to do so
those of you using lighter weights enjoy the brass that gets eaten up in your trans
all the mini cooper S guys have been running Redline 75wMTL for YEARS
either use Ford OEM that costs a Grip or get Royal Purple or Amsoil GEAR OIL 75w90
qweesy is offline
Old 02-07-2013, 01:44 AM   #23
Lscman
Fan#: 95211
I'd bet the idiot count for mini cooper S owners running unapproved redline fluid is closer to a couple hundred guys out of a total fleet size of 100K+ cars. That's maybe 0.2%, not exactly "all". A large percentage of these folks are still getting repairs under warranty. Please realize a couple misguided folks experimenting on the cooper forums don't speak for the whole owner community. This is exactly what happened on the Supra, Mustang and BMW forums when fools started promoting the incompatible redline fluids and trannys began dropping like flies in 5-7 yrs, shortly after warranty expired. History repeats itself and many refuse to learn from other's mistakes. BMW guys come to me to get Getrag trannys rebuilt after they do stupid stuff. The manfuacturer of these transmissions (Getrag) called out Redline and other non-approved lubricants as the culprit and the failures were clearly documented. You think you know more than the Engineers??? Do you have grounds to disagree with conclusions drawn on other forums where a community of folks with Getrag trannys learned the hard way over a decade?? Have you even seen a Getrag tranny inside? Most have no clue what is inside their transmission being damaged from improper fluid or abuse. All they know is the synchros shift more smoothly with certain lubricants, but that has nothing to do with lifecycle, corrosion, compatibility or wear rate. A tire wall will stop a car faster than the best racing brakes, but that does not mean tire walls are preferred for stopping. The objective when choosing tranny fluid should be to maximize lifecycle and overall performance. Shift feel is only one criteria. If quick synchro engagement were the only concern we'd all be trying kerosene or gatorade in our trannys.
Lscman is offline
Old 02-08-2013, 01:04 AM   #24
LittleRedSVT
LittleRedSVT's Avatar
Fan#: 105384
What I Drive: '95 Mustang GT 'vert
Points 679, Level 13
Points: 679, Level: 13 Points: 679, Level: 13 Points: 679, Level: 13
Level Up 58% Completed
FF Reputation: 1 LittleRedSVT Good Standing Member
I'm just confused by this entire thread. Someone tell me what fluid I should use in my Getrag.
Supercharged '02 SVT
MODS: Vortech Supercharger, VF motor mounts, 61lb/hr injectors, Trubendz 3" cat-back.
Oh, and the massive pile of uninstalled parts sitting in my garage...
I like to go fast.
LittleRedSVT is offline
Old 02-08-2013, 01:09 AM   #25
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Level Up 0% Completed
Forum Activity 55%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
"When in doubt, use what the factory put out"
If your not sure just use the Ford Full Synthetic tranny fluid unless your comfortable with using what others have used. Really it's a personally preference has I have rarly if ever seen a getrag failure on here from different fluids being used. The one thing I think we can all agree on is the factory fluid at least..
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 02-08-2013, 07:22 AM   #26
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,232, Level 41
Points: 4,232, Level: 41 Points: 4,232, Level: 41 Points: 4,232, Level: 41
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Use ford dude.
I now drive a Japanese Ford.
macdiesel is offline
Old 02-10-2013, 07:20 PM   #27
haste
Fan#: 109497
What I Drive: 2002 Silver Focus SVT 3-door
Points 57, Level 1
Points: 57, Level: 1 Points: 57, Level: 1 Points: 57, Level: 1
Level Up 14% Completed
FF Reputation: 1 haste Good Standing Member
a quart of ford prescribed full synth here in PA was $18 each. youch!
drained out the gl-5 i had in there...you guys had me worried about it...luckily, it was only in the tranny for a month.
what kind of mileage can i put on this fill? 1 year or every 12k miles seems ridiculous to me...its just a daily driver with some spirited driving here and there.
haste is offline
Old 02-10-2013, 08:52 PM   #28
Lscman
Fan#: 95211
Ford dealership sells the proper fluid. It is specifically blended for your particular Ford-Getrag Transmission. This thread does a great disservice to the Focus community because 90% of the opinion is based upon gross ignorance. Recommendations to use alternative fluids are not appropriate and damage may result. Read your Operator's Manual in the glove box. If you don't have one, order one at the dealer or on ebay. It tells you what fluids to use. There are people on this forum that don't know a thing about lubricants aside from them being slippery, but they choose to recommend alternate products without any technical basis or understanding. This is really dangerous.
Lscman is offline
Old 02-10-2013, 09:00 PM   #29
Lscman
Fan#: 95211
I'd change it every 75K mi or so. Time interval is not a significant factor unles you're in a flood lol. Honestly it doesn't matter if it's every 3 yrs or 13 yrs. That should get you beyond 300K mi without wearout issues, unless you have some issue with your clutch dragging or shifter linkage malfunction. But what do I know after rebuilding Getrag 6spd manual trannys for BMW for 7 yrs and helping others with rebuilds for Mitsubishi VR4/Dodge Stealth and Toyota Supra. I have also rebuilt Corvette and Ford trannys from ZF, Tremec and Borg Warner.
Amateur racers running track typically change tranny lube about every 12K mi to 36K mi. This just flushes particulate out from abusive shifting. The fluid is easily good for 36K under severe duty. Anything under 50-75k mi is overkill for street unless you're abusive and grinding gears all the time. In that case, fresh fluids won't save it.
Lscman is offline
Old 02-11-2013, 11:13 AM   #30
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
Add me to the list of 5 guys in the US that build the Getrag SVT Trans , I have a SVT Getrag making over 300HP to the wheels with Mobile 50 wt oil and has seen over 10,000 miles or hard road track use ( mostly VIR) over 500 1/4 mile passes , 100 1/8 mile passes runs a 1/4 in 12.99 @ 111 mph and tens of thousands of miles on the road as a daily driver , I have over 200 SVT customers running this same oil 100% issue free and most of them boosted where the SVT Getrag is exceeding its load limits set by Getrag over 300TQ at the wheels , I build mostly daily drivers not race cars and I do not work for a race team , I own my own engine shop , trans business , tuning and dyno business as well as fabrication
the claimed "wrong fluids" at your # they should be 150+ out of the 200+ I have done that should of gone bad and none have , kinda throws a wrench into your scare tactics , a MTX-75 with over 150,000 miles turbocharged track / DD car with Mobile engine oil 50wt Syn , 3 clutches but never any trans issues ,
This many Foci with "the wrong fluids" and no issues has to say something at least to the point they dont brake if you dont use the Ford fluids
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
