ATX trans gasket - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-29-2012, 09:58 PM   #1
JET DH
Fan#: 24263
What I Drive: 01 ZX3
FF Reputation: 1 JET DH Good Standing Member
ATX trans gasket
So I changed my transfilter with the Fram kit a while back and since I've had a leak coming from somewhere. I can't find the leak itself, but I'm going to try the simple stuff first.
My question is what is the best way to make sure it is sealed completely?
I'm kind of thinking that if I just use the gasket, it may get a tear or something and I'll be back where I started. If I use some RTV as backup, I am thinking about putting it on the pan then putting the gasket on the RTV, and installing the pan creating a sandwich kind of seal. Or I could put the RTV on both sides of the gasket, but I think that may be overkill.
K&N drop in-Esslinger UDP-SVT snorkel-Euro radiator cover-hatch full o' bike tools.
JET DH is offline
Old 01-29-2012, 10:09 PM   #2
md2009
Fan#: 93649
What I Drive: 09 S Sedan - Black
FF Reputation: 2 md2009 Good Standing Member
I've seen a product that you spray on the gasket which is supposed to help with sealing. It comes out red, and is a very tacky substance.
The #1 mistake folks make when installing a pan gasket is OVER tightening the bolts. If you go too tight, you will split the gasket and it will leak like civ. The correct torque is probably measured in inch pounds, although I don't have the specs in front of me. If you take the pan off, I would choose to either use the gasket or use gasket maker, but not both. Personally, the gasket has always worked fine for me.. just make sure you get the right torque specs!
md2009 is offline
Old 01-29-2012, 10:42 PM   #3
JET DH
Fan#: 24263
I know the tourqe is pretty low, like 10 whatever pounds.
15nm - google
JET DH is offline
Old 01-29-2012, 11:19 PM   #4
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,109, Level 34
Points: 3,109, Level: 34 Points: 3,109, Level: 34 Points: 3,109, Level: 34
Level Up 40% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
Glue the gasket to the pan with RTV.
Put some plastic wrap down on floor.
Put gasket and pan on plastic wrap.
Add some weight to pan (stacks of old newspaper work)
Let sit overnight.
Install pan with RTV smeared on gasket to tranny.
No leaks.
If you don't let the gasket and RTV dry onto the pan, when you tighten the bolts the gasket tends to be pushed out from between the pan and tranny........(RTV makes a great lubricant if it isn't dry).
Ed
emsvitil is offline
Old 11-01-2012, 11:01 AM   #5
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
I'd use a minimum of 30 pounds weight. The RTV will dry lumpy otherwise and lumpy leaks very easy.
I've put on hundreds of gaskets dry and no leak for years. Clean and DRY surface is the key, 99% of time when I view others' errored work the surface is still dirty or oily. Oil and uncured RTV absolutely do not mix. ANY RTV and ATX do not mix, the little BBs come loose and if get in valve body problem city.
The gasket can easily be overtightened to leak too. The pan must be prepped by knocking pull in back out at all the bolt holes. The pulled in area at holes relieves the rest of flat between holes to leak.
I'll take a gasket and no RTV any day, although I have no trouble either way making it work.
amc49 is offline
