Tow hooks/points needed? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-27-2012, 08:18 PM   #1
Vernl
Fan#: 92066
What I Drive: 2012 Tri white Titanium 401a
FF Reputation: 1 Vernl Good Standing Member
I've read the manual and checked both ends of the car but do not see any solution to the problem of getting stuck in the snow or mud.
The manual has lots of info for towing , loading on flat bed etc but nowhere does it show where its safe to actually hook onto the car,even if its bed loading on flat dry ground.
The manual shows no hook up points that will take the weight of the car..If you slide off the road and end up in a snow drift or mud etc, how are you supposed to attach a tow rope or winch to the car , there is no place to tie on that wont just pull right off and make a bad situation worse.
Any ideas on this?
Vernl is offline
Old 01-28-2012, 10:16 AM   #2
02svtf300
02svtf300's Avatar
Fan#: 83769
What I Drive: 2002 sonic blue SVT(moded)
FF Reputation: 2 02svtf300 Good Standing Member
On the back of my svt left side i think there is a tow loop off the unibody... behind bumper
Front... ? Subframe maybe
02 sonic blue svtf...< modified addiction < DD
88 bronco II (x2)... < the twins
00 yamaha banshee... <will be the end of me
02svtf300 is offline
Old 01-28-2012, 02:19 PM   #3
Vernl
Fan#: 92066
I'll have it up on ramps to change oil one of these days and have a look, but the problem is all the covers underneath etc...if you hook onto it too far inboard,either from front or back, when you attempt to tow it out of a ditch you will lift the rope up against the bottom of the car and pull up on plastic bumpers and air dams and destroy cowlings under panels etc....I guess its best to leave it parked in shitty weather..lol
Vernl is offline
Old 01-28-2012, 03:20 PM   #4
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
What I Drive: 2012 Black Titanium 5-Door
FF Reputation: 5 hotleadsingerguy Good Standing Member
And you don't think Ford has changed anything since then? Your car is 10 years old lol pretty sure it's not identical to the 2012s.
I've had it up on ramps and didn't see any tow points, but maybe they're hidden somewhere (I didn't inspect the back end of the car). At least in the front I don't think there are any real points to tow except some of the supporting suspension points. Either way those are under the front covers, so either you'd have to take off the cover or you're going to break it and possibly light it on fire when it's sitting in direct contact with your engine.
hotleadsingerguy is offline
Old 01-29-2012, 05:13 AM   #5
locutist
locutist's Avatar
Fan#: 33592
What I Drive: 2005 Volvo V50 T5
Points 843, Level 15
Points: 843, Level: 15 Points: 843, Level: 15 Points: 843, Level: 15
Level Up 44% Completed
FF Reputation: 1 locutist Good Standing Member
You mean this:
side
front
with cap on
And finally, the Euro Focus with the cap on
If the US model has the same rebar as the European model, then there should a threaded hole behind the bumper cover on the right side up front and one on the right rear side, then a tow hook can be mounted.
2005 V50 T5 6-Sp Manual: Flint Grey Metallic|Premium Sound System w/ 6-Disc CD Changer|De-badged Rear Hatch | E-Code Head Lights |Roof Spoiler |Dubstop black mesh grill| European Spec Wide Angle side view mirrors
locutist is offline
Old 01-29-2012, 07:41 AM   #6
Rogerschro
Rogerschro's Avatar
Fan#: 90661
What I Drive: '12 FFE Frosted Glass
Points 910, Level 16
Points: 910, Level: 16 Points: 910, Level: 16 Points: 910, Level: 16
Level Up 10% Completed
Forum Activity 2%
FF Reputation: 3 Rogerschro Good Standing Member
Originally Posted by locutist View Post
You mean this:
I wondered what that was for on the Euro Focus... US Focus don't have that feature.
Rogerschro is offline
Old 01-29-2012, 08:24 AM   #7
locutist
locutist's Avatar
Fan#: 33592
Yeah, behind that cap is a threaded port for a tow eye hook.
locutist is offline
Old 01-29-2012, 08:53 AM   #8
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,082, Level 34
Points: 3,082, Level: 34 Points: 3,082, Level: 34 Points: 3,082, Level: 34
Level Up 22% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
I think this is a "tie-down" hook, not something made for towing. It's meant to be used while the car is in transit or on a recovery trailer. I suspect very bad things will happen if you try to pull a car out of a snowbank with it.
dan50 is offline
Old 01-29-2012, 09:09 AM   #9
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
What I Drive: 2012 Ford Focus SE Sport - 5 Speed
Points 15,457, Level 80
Points: 15,457, Level: 80 Points: 15,457, Level: 80 Points: 15,457, Level: 80
Forum Activity 35%
Activity: 35% Activity: 35% Activity: 35%
FF Reputation: 10 Shade-010 Great Standing Member
we need to find one where someone removed the bumper and see if the threaded hole is there... if it is then just need the Euro bumper cover
2012 Ford Focus SE Sport-5 speed-203A package
Basline 1 -155.48hp 145.80 tq 93 oct. Lunchbox delete & K-N Drop in filter.
Dyno 4 -177.17 hp 157.28 tq - 93 oct. RDC 2.5" Catback & RD-X Prototype CAI + Tune.
http://www.rebeldevil.com
Shade-010 is online now
Old 01-29-2012, 11:11 AM   #10
locutist
locutist's Avatar
Fan#: 33592
It is used for towing. I was pulled out of a sand bar using this hook. And here in Germany, many cars are towed by this method. Look at some of the DTM races where you might see this hook with a red arrow pointing to it. It is definitely not used for a tie down (it can be, but not meant for it).
locutist is offline
