Hidden Menu DTC's, What do they mean? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-25-2012, 05:47 PM   #1
eyeballeater
eyeballeater's Avatar
Fan#: 87226
What I Drive: 2012 Sedan SE with sport appearance
Points 10,472, Level 68
Points: 10,472, Level: 68 Points: 10,472, Level: 68 Points: 10,472, Level: 68
Level Up 6% Completed
FF Reputation: 1 eyeballeater Good Standing Member
When I went to the hidden menu and scroll to the DTC page mine shows:
DTC 01 C140_00
DTC 02 0850_62
Any idea what these mean?
Now after my transmission update it says NO DTC, but I'm still kinda curious.
2012 SE Sedan Spec 201A, Sport appearance package and 17" wheels
eyeballeater is offline
Old 01-25-2012, 07:11 PM   #2
noahsfocus
noahsfocus's Avatar
Fan#: 90974
What I Drive: 2012 White Platinum Ti Sport Hatch
Points 493, Level 9
Points: 493, Level: 9 Points: 493, Level: 9 Points: 493, Level: 9
Level Up 86% Completed
FF Reputation: 5 noahsfocus Good Standing Member
How can I find the Hidden Menu? edit: The Test Mode menu? .. I see you must mean the DTC page in test mode.
Thanks
noahsfocus is offline
Old 01-25-2012, 09:09 PM   #3
Deth-jeep
Fan#: 88163
What I Drive: 2012, Oxford white SE
FF Reputation: 2 Deth-jeep Good Standing Member
I'm all ears on this one too
2012 Oxford white SE Hatch, 5spd, Sport package, 203A, 17" Machined face wheels, Winter package
Ordered 7-25-11, Built 8-16-11, Delivered 9-2-11
Deth-jeep is offline
Old 01-25-2012, 10:35 PM   #4
st falcon
st falcon's Avatar
Fan#: 92343
What I Drive: 2012 Blue Candy HATCH SEL
FF Reputation: 3 st falcon Good Standing Member
Thanks
Hold down the right "ok" button on the steering wheel before starting the car, and for several seconds after starting the car, and they should pop up.
Diagnostic Trouble Codes
2012 Focus SEL Blue Candy Metallic
1996 Bronco XLT 351W
Cant wait for Summer when I pop the top!!
st falcon is offline
Old 01-25-2012, 11:44 PM   #5
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
Hmm, so they don't have the full DTC being displayed to you. (A full listed DTC is 5 characters....and DTCs shown in these newer vehicles are often 5 characters followed by 2 more as a descriptor).
I found a P0850:62, Desription: Park/Neutral Switch Input Circuit: Signal Compare Failure
Trigger Conditions: A continuous and on-demand DTC that sets if the IPC detects a discrepancy between the hardwired park detect input and the messaged transmission mode display actual input.
Honestly, this one seems it could set if there was a slight hickup in communications. If its not something that returns, I wouldn't even worry about it. Its quite common to see a handful of useless codes in memory when scanning a vehicle. To base diagnosis on some of these codes would be like walking in a field trying to find fly poop.
Can't find a C140 code....but did find a U0140:00. Maybe what looked like a "C" was a "0"?? In any case, if it was in fact U0140, its another communications code. The BCM may have been busy for 5 seconds and couldn't report to another module. These kinds of codes can set during a state of high traffic networking between modules. Since a lot of the modules in your car are multiplexed networks, several bits of info are sent along the same pair of wires between modules. Lets say you have "Module A" reporting to "Module B". it could be busy sending info even though another module C could be requesting info from it. If Module C doesn't get its info in time, it can set a communications fault. There may me nothing wrong with the network, or the modules, or the vehicle at all....in some conditions where networking gets busy, you could have a module "get pissy" and set a useless code in memory.
If you aren't noticing an actual fault with the vehicle, then I wouldn't worry about it.
Rat Fink is offline
Old 01-26-2012, 05:53 AM   #6
eyeballeater
Fan#: 87226
Thanks Rat, I just checked and its definitely C140_00. In any case I'm not worried, The car drives great and I don't really have complaints. I was more curious than anything. Have to admit that it is kinda nice being able to see DTC's without the need for a OBD2 scanner.
Old 01-26-2012, 07:17 AM   #7
bobakman
bobakman's Avatar
Fan#: 89045
What I Drive: 2012 Sterling Grey Titanium Sedan
FF Reputation: 1 bobakman Good Standing Member
Great write up. I love your analogy about the fly poop.
bobakman is offline
Old 01-26-2012, 12:02 PM   #8
noahsfocus
noahsfocus's Avatar
Fan#: 90974
Points 493, Level 9
Would be nice to know what these codes stand for without having to ask Ford. Does anyone know where to find a list of DTC codes and explanations that will apply to the '12 Focus.
Mine has just one DTC 0852_62
Must be similar to the P0850:62 that Rat Fink found.
Old 01-26-2012, 12:08 PM   #9
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 7%
FF Reputation: 13 BetaDnB Great Standing Member
Isn't it the left ok button? I don't think the car needs to start. I think it just needs to be switched to the on position. Not positive.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is online now
Old 01-26-2012, 02:31 PM   #10
st falcon
st falcon's Avatar
Fan#: 92343
I might be, I've only done it once like three months ago when I read about it on here. I'll have to try again to be sure. YOUR OTHER RIGHT LOL!!
