Finally Zxthrizzle05 turbo zetec build - Page 3 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
Old 01-28-2012, 02:51 PM   #21
forcedfocus
Fan#: 72073
What I Drive: 2004 silver zx3
FF Reputation: 4 forcedfocus Good Standing Member
you need valve springs or that built bottom end will do you little good. When you start turning up the boost it will actually start to push the valves open. So you need them even if you dont swap cams or plan on turning more rpms.
forcedfocus is offline
Old 01-28-2012, 07:59 PM   #22
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
Well until then ill have to drive on 12psi until than....here's the progress today
Got the trans and engine out. And tomrows goal is to pull the head off pull the clutch flywheel off take the crank out clean the block then send it out monday
FF MODERATOR
RISE AGAIN EGGYOLK130 WHP 124 WTQ ZETEC CREW #271
RIFF CREW
TURBO DYNO COMING SOON
ZXthrizzle05 is online now
Old 01-29-2012, 04:09 PM   #23
Eastwood
Eastwood's Avatar
Fan#: 62095
What I Drive: 2001 zetec premium zx3
FF Reputation: 1 Eastwood Good Standing Member
Buy-Sell-Trade Rating: (19)
I have a set of fel pro gaskets will they be good for turbo 350-400 hp focus ?
or it's better to use OEM?
Eastwood is offline
Old 01-29-2012, 04:47 PM   #24
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: Miata, STi, GSXR1k
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
stock valve springs are fine with boost as long as stay with stock redline. if you raise the redline that is when you will need valve springs. and fel pro gaskets are ok except for the hg. use a motorcraft or cometic mls
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is online now
Old 01-29-2012, 07:25 PM   #25
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Yep I allways use motorcraft gaskets. Got the block on the stand today got the clutch and flywheel off and the timing belt cover off. Now uim stuck on how to get the crank pulley off. It just spins freely when I try to get the bolt out
FF MODERATOR
RIFF CREW
Old 01-30-2012, 11:55 AM   #26
Turbo Turtle
Fins Up!
Fan#: 32772
when you take the windage tray off put a wooden hammer handle in the block so the crank will hit it
Turbo Turtle Garage
Old 01-30-2012, 06:33 PM   #27
ZXthrizzle05
TURBO ZX3
Fan#: 24434
I got it off by puttin two flywheel bolts in and a prybar.I have a huge problem now. Two of the E 10 torq bolts that hold the intake camshaft in are rounded and I don't know how to get them out now
FF MODERATOR
RIFF CREW
Old 01-30-2012, 06:34 PM   #28
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Also for the windage tray I got all the ten mm bolts out cept I don't know what fits on the two long bolts that stick out on the plate on the exhaust side of the block
FF MODERATOR
RIFF CREW
Old 01-30-2012, 08:12 PM   #29
ZXthrizzle05
TURBO ZX3
Fan#: 24434
FF MODERATOR
RIFF CREW
Old 01-30-2012, 08:13 PM   #30
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
Post up a pic. I can't picture what your talking about.
iroc34 is online now
