FRPP Suspension on a 2008? - Page 17 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-18-2012, 11:48 PM   #161
Coolen11
Coolen11's Avatar
Fan#: 95127
What I Drive: 2008 Black Focus SES
Points 770, Level 14
Points: 770, Level: 14 Points: 770, Level: 14 Points: 770, Level: 14
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 1 Coolen11 Good Standing Member
so could i buy the Frpp performance shock/strut kit and use H&R sports on them?
FSWerks CAI
FSWerks Race Exhaust
FRPP Kit
Upper and Lower Strut Bars
Coolen11 is offline
Old 10-10-2012, 09:16 AM   #162
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
Points 1,255, Level 19
Points: 1,255, Level: 19 Points: 1,255, Level: 19 Points: 1,255, Level: 19
Level Up 55% Completed
FF Reputation: 2 Gettysburg150 Good Standing Member
In theory you can use any spring that fits our cars and is advertised as a 1.5" drop, which is what the FRPP is advertised. Spring rates may be different but it should work
Sedan Revolution Two Three Zero
FRPP, "Stealth" CAI, Debadged, wider tires, louder stereo, turbo mainfold in the wrong place...
Gettysburg150 is offline
Old 10-29-2012, 06:38 PM   #163
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
Capture by DarderSauce, on Flickr
Not sure if that was the same price as it was on Tousley but found it here.
Part #'s used:
Springs: M-5560-ZX3B
Dampers: M-18000-ZX3B
If they still have them I might buy this setup, better than going with the H&R Cup Kit I was thinking about for $390 + $100 for the Omni Kit.
Anyone know anything about this site?
http://www.fortesparts.com/shopping_...0-ZX3B&sort=2a
If you can't wear it out, burn it off
DarderSauce is offline
Old 10-30-2012, 01:48 PM   #164
Gettysburg150
Fan#: 97408
Hmm, I wonder if Ford started making them again. The springs weren't listed on their catalog but if you do a search it says its available again. Tousley still doesn't list them online but it may be worth a call. Maybe Ford saw we were looking for them and started producing them again? Idk, I'd call and find out
I don't know anything about that site but if you go to www.fordracingparts.com and search for those numbers it says they are avaiable. Give Tousley a call and see if you can buy from them Darder
Old 10-30-2012, 02:09 PM   #165
DarderSauce
Fan#: 95564
Just emailed the white bear lake Tousley Parts Dept. near me to see what they say.
Old 10-31-2012, 07:18 AM   #166
DarderSauce
Fan#: 95564
This is the response I got from Tousley:
The M-5560-ZX3B is no longer available. A popular alternative has been the M-5560-ZXM1, which we have in stock. These provide a bit more drop and are a little stiffer than the ZX3B.
The M-18000-ZX3B runs $159.50, and in stock as well
Thanks
Mike R
So I guess my next question is would the M-5560-ZXM1 be liveable on a daily driver that sees mostly hwy miles?
Spring Rates:
ZXM1: 120-160 and 110-280
^^ Why are the rates different for the same spring?
Since this seems to be the best bang for your buck I will probably end up doing it but I just wanted to get some insight from the experts
Thanks Feljas
Old 10-31-2012, 08:02 AM   #167
Gettysburg150
Fan#: 97408
Rates are different probably due to placement, front vs rear. As for being liveable, that's up to you. Guys drive in slammed on coil cars all day. Being that you say its mostly highway I would say go for it. You shouldn't be hitting messes up roads at any high speeds in any car, unless you got lots of money.
Old 10-31-2012, 09:13 AM   #168
DarderSauce
Fan#: 95564
Well I suppose I have (for the most part) waited for others to do something to their car and provide feedback before I try it on my car so maybe I will do this and give my feedback for once. I will buy the parts for the swap and put them on this Spring (Pun intended). I was considering the H&R cup kit but that would cost around ~$500 so I think this is a better "budget friendly" option in my opinion. Might as well do the suspension, brakes, and endlinks all at the same time.
P.S. Car is making that "pop" sound when I get after it on right hand turns so I am thinking the endlinks are junk which is a problem most of our cars have. Time for some MOOGS!
EDIT: Just ordered my MOOG endlinks. Use Code 110294729047570 for 5% off. Only ended up being $1.70 but hey I'll take it.
Suspension : Stabilizer Bar Link
MOOG Part # K80066 Problem Solver
Old 10-31-2012, 12:11 PM   #169
DarderSauce
Fan#: 95564
Just putting this here for a reference to look at when I bring my car in for allignment and to help anyone else that may read this in the future. Originally posted by Geezer
For most Foci (especially 00 to 05) the following specs work. For 06+ cars these specs also seem to work, but rear camber (per Ford), should not exceed -1.3 degrrees:
Front toe: .01 to .02 inches of "toe-out" but no more (zero toe if you have poly bushings)
Rear toe: .04 inches of "toe-in" (per side)
Front Camber: anything "within spec".... its non-adjustable.
Rear camber: -1.0 to -1.5 degrees (you can go less without problems but some negative camber tends to improve handling characteristics). More than -1.5 degrees and you start to promote inside edge tire wear especially if your toe setting exceeds what's recommended above.
Old 10-31-2012, 01:31 PM   #170
Gettysburg150
Fan#: 97408
FWIW, my rear camber is -1.9 degrees. Its a little excessive but I did (and still do) not feel like buying camber arms or bolts. I have had no excessive wear. This does not apply to all people since we are all running different styles/sizes of wheels and tires but I just don't want you to be scared if you hit this number.
