Possible fix for shaky clutch engagement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-12-2012, 04:28 PM   #1
NWChris
Fan#: 93217
What I Drive: 2012 Gray SEL Hatch
FF Reputation: 1 NWChris Good Standing Member
So if you're reading the other threads you definitely have heard about the clutch issues on the Powershift "auto". I think I may have fixed the problem (at least in my car).
I have a 2012 Focus with a build date of 11/11. There are no software updates available for my car and Ford has claimed no fix for it other than letting the techs do a drive cycle, which does not work.
They say that the clutch needs to "break in", but that doesn't seem to be possible under any reasonable driving conditions so here is what I did...
At 1025 miles, I took the car out to a safe stretch of road, came to a complete stop, then full throttle accelerated to the speed limit. I stopped again and did this 5 to 6 times in succession. I then drove around in select shift mode, down shifting and up shifting at higher RPM's. I performed a few full throttle engagements forcing the car to downshift etc. Basically I went out and worked the clutches as hard as I could for a few minutes. I avoided anything that might be considered extreme or warranty voiding, but I gave it a good go. Immediately, the car was launching and shifting with extreme reduction in the shake/shudder.
At first I was a bit skeptical that I had somehow affected the adaptive learn, but after 2 days the shudder has not returned and it seems to be getting better by the day.
If you want to do it, give it a try.
I wish I didn't have to say this but, I am not to be held accountable for anything you do to your car. This is merely my observation and what you do is your own responsibility. I have some pretty extensive experience in the Auto industry, but I'm not a Ford Mechanic.
NWChris is offline
Old 01-12-2012, 04:44 PM   #2
aperson9923
aperson9923's Avatar
Fan#: 90061
What I Drive: 2012 SGM Ti Hatch
Points 1,812, Level 25
Points: 1,812, Level: 25 Points: 1,812, Level: 25 Points: 1,812, Level: 25
Level Up 12% Completed
FF Reputation: 1 aperson9923 Good Standing Member
OMG this is exactly what I did and it worked too. I swear by it. I just love my car now. I also feel that it makes your car more sporty
2012 Sterling Grey Metallic Ford Focus Titanium Hatch
401A, Navi, MFT, Rain Sensing Wipers
Built: 11/28/11 Arrived: 12/16/11 (4 Miles)
Mods: Tint 20/5, LockPick & Backup Camera, K&N Drop In
aperson9923 is offline
Old 01-12-2012, 04:46 PM   #3
hoover460
Fan#: 92046
What I Drive: 2012 Silver Titanium
Points 78, Level 1
Points: 78, Level: 1 Points: 78, Level: 1 Points: 78, Level: 1
Level Up 56% Completed
FF Reputation: 2 hoover460 Good Standing Member
Sounds like how I drive all the time!
Glad to hear it helped, mine actually has no shudder, but I need to get the TSB (May build), so who knows after that!
hoover460 is offline
Old 01-12-2012, 04:54 PM   #4
Rogerschro
Rogerschro's Avatar
Fan#: 90661
What I Drive: '12 FFE Frosted Glass
Points 901, Level 16
Points: 901, Level: 16 Points: 901, Level: 16 Points: 901, Level: 16
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 2%
FF Reputation: 3 Rogerschro Good Standing Member
I wish I didn't have to say this, but I am not to be held accountable for anything you do to your car. This is merely my observation and what you do, is your own responsibility. I have some pretty extensive experience in the Auto industry, but I'm not a Ford Mechanic.
This reminds me of doing a 'tune-up' on old carburated cars, take it out somewhere in the country and floor it! Called blowing out the carbon! It worked remarkably well and everything seemed better, even suspension seemed to work better. Must be all that utilizing the full range of performance rather than a very narrow range that let things seize up.
Rogerschro is online now
Old 01-12-2012, 05:04 PM   #5
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,035, Level 33
Points: 3,035, Level: 33 Points: 3,035, Level: 33 Points: 3,035, Level: 33
Level Up 90% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
Think you have to do this to the speed limit or do you think just a series of hard launches using only 1st gear would do the trick? That would seem to be where most of the clutch work would occur. Just trying to suit the technique to my environment.
Thanks for the suggestion!
dan50 is offline
Old 01-12-2012, 05:06 PM   #6
NWChris
Fan#: 93217
First gear only would probably work fine. I liked the idea of getting a full throttle 1-2 shift in there, but as long as the clutch is making solid/stressed engagement I would have to assume that's fine.
NWChris is offline
Old 01-12-2012, 05:45 PM   #7
noahsfocus
noahsfocus's Avatar
Fan#: 90974
What I Drive: 2012 White Platinum Ti Sport Hatch
Points 493, Level 9
Points: 493, Level: 9 Points: 493, Level: 9 Points: 493, Level: 9
Level Up 86% Completed
FF Reputation: 5 noahsfocus Good Standing Member
Me too !!! Every so often I employ all 160hp and always using sport shift and manual shift to drive with more rpm's. Guess that's why some of ours drive like a dream ... and shift amazingly well.
I also have a May build and just had the TSB done in December and let me tell you it's such an amazing difference after the TSB ... don't wait any longer and have it done right away. Perform the drive cycle yourself even if they say it was done ... just to be sure. Then break it in like you love to drive ... makes a world of difference, you'll see. I also loved mine before the TSB but now it's 10 times better driving, especially in the city.
noahsfocus is offline
Old 01-12-2012, 06:05 PM   #8
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,022, Level 33
Points: 3,022, Level: 33 Points: 3,022, Level: 33 Points: 3,022, Level: 33
Level Up 82% Completed
Forum Activity 12%
FF Reputation: 15 PratoN Great Standing Member
Originally Posted by noahsfocus View Post
I also have a May build and just had the TSB done in December...
How did you go about getting this? Did you have to complain about the transmission? Or do you have a friendly technician? Because it was a pain for me to get the October update. I still have the jerky stop-and-go issues.
PratoN is online now
Old 01-12-2012, 07:41 PM   #9
Vernl
Fan#: 92066
What I Drive: 2012 Tri white Titanium 401a
FF Reputation: 1 Vernl Good Standing Member
Seems logical enough, perhaps the clutches can become glazed during the break in period..similar I suppose to ''bedding in '' new brake pads.
I am going to give it shot too.
Vernl is offline
Old 01-12-2012, 07:50 PM   #10
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
one clutch is used on 1st, 3rd, and 5th gear. The other clutch is used for 2nd, 4th, and 6th gear......so I would say working the vehicle through the full range would be best.
I'm a Ford tech but honestly haven't had to work with many of them to hear anything about this (only ever looked at 1 focus for a shift concern and the standard update and drive cycle cured it), but it wouldn't surprise me that you could be experiencing better performance from it.
I know with older diesels, we get elderly people who come in with their 6.0L trucks and they never do anything other than putt around with it. Even while towing, they'll never work a truck hard and never go wide open throttle EVER! It is quite common to get these trucks in and the unison rings in the turbo are seized (the unison ring rotates to allow the vanes in the turbo to open and close). Once it gets seized up, you'll get underboost or overboost codes, lack of power etc. People will never change their driving habit so you'll get the same guy who will run through 2 or 3 turbos during the life of the truck. For the new 6.7L diesel, they had to program the PCM to do a full sweep of the turbo every once in a while to keep it from seizing like it did with the 6.0L......and now we get the old people who complain that their turbo sweeps on its own once in a while. aaaaahhhh!!!
Rat Fink is offline
