Tire pressure sensor fault > 2010 Focus SES - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-12-2012, 06:50 AM   #1
Smoker
Fan#: 93433
What I Drive: 2013 Gray SE
Points 469, Level 9
Points: 469, Level: 9 Points: 469, Level: 9 Points: 469, Level: 9
Level Up 38% Completed
FF Reputation: 1 Smoker Good Standing Member
I have a Focus 2010 SES. I replaced the 4 tires yesterday and not I'm getting a light on dash for the tire pressure sensor fault. It flashes for a minute or so and then goes solid. Never had this on before. Air pressure is ok. Any thought on fixing this ? The manual don't tell me much other than take to dealer so they can charge me an arm and leg.
Smoker is offline
Old 01-12-2012, 07:55 AM   #2
misfire
Moderator
misfire's Avatar
Fan#: 31379
What I Drive: 2012 SEL Hatch, 2014 Mazda CX-5
Points 17,017, Level 83
Points: 17,017, Level: 83 Points: 17,017, Level: 83 Points: 17,017, Level: 83
Level Up 34% Completed
Forum Activity 2%
FF Reputation: 31 misfire Great Standing Member
Buy-Sell-Trade Rating: (13)
Who installed the tires? The sensors are in the valve stems. If it wasn't done right, the installer may have damaged a sensor.
Will aka Misfire
2003 LX "traded in"/2010 SES "traded in"/2012 SEL Hatch "current"
misfire is offline
Old 01-12-2012, 01:16 PM   #3
miles@tirerack.com
miles@tirerack.com's Avatar
Fan#: 85510
FF Reputation: 3 miles@tirerack.com Good Standing Member
Did they service the valve stem/sensor when they installed the tires? This should be shown on your invoice.
Refer to 'Miles/FocusFanatics' as your previous contact when you order online. You can also credit the forum by ordering through any Tire Rack link.
miles@tirerack.com is offline
Old 01-12-2012, 01:48 PM   #4
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
It also might take several hours of driving for the system to reset itself. This is quite commom even when tire pressure is allowed to go low and then the tire is properly filled. The light tends to remain on for awhile. My GTI sometimes takes a day of driving before the system acknowledges the new pressures.
Geezer is offline
Old 01-12-2012, 02:03 PM   #5
misfire
Moderator
misfire's Avatar
Fan#: 31379
Forum Activity 2%
With VW's that statement is correct. I worked for VW for 5 years
if all tire work was done right, it needs to visit a dealer to have pressure set and reset monitor with our tool.
Will aka Misfire
misfire is offline
Old 01-12-2012, 06:48 PM   #6
Smoker
Fan#: 93433
Points 469, Level 9
drove over 200 km already - still a problem
Smoker is offline
Old 01-12-2012, 06:49 PM   #7
Smoker
Fan#: 93433
Points 469, Level 9
drove over 200 km. what do you mean reset with our tool ?
Smoker is offline
Old 01-12-2012, 06:50 PM   #8
Smoker
Fan#: 93433
Points 469, Level 9
my local garage. I saw the sensor on rims ?? You mention valve stem ?
Smoker is offline
Old 01-12-2012, 06:51 PM   #9
Smoker
Fan#: 93433
Points 469, Level 9
local mech. Good guy
Smoker is offline
Old 01-12-2012, 07:41 PM   #10
Geezer
Fan#: 1427
The sensor is either attached to the valve stem inside the tire or attached to the wheel with a metal band inside the tire. Regardless of design, either can be reset (programed) with a special tool. You can buy the tool yourself from places like Tirerack.
Any good shop that mounts tires should have one as well. The sensor should reset itself if the original sensors were re-installed. If not then the system has to be reset (programmed). The shop that did the tire install should take responsibility for this. The sensors are usually serviced (new seals installed, etc) when new tires are installed. Some sensors have to be removed to prevent damaging them with the tire removal machine. As Miles from Tirerack mentioned, most shops will charge an additional fee (for parts and labor) to service the TPMS sensors.
Geezer is offline
