Everythings fine... But the clock - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-17-2012, 12:17 PM   #61
DrRay
Fan#: 14474
What I Drive: A car
FF Reputation: 1 DrRay Good Standing Member
Originally Posted by BetaDnB View Post
I found this (sorry for the caps. copy/paste job):
4966 - 2012 FOCUS AND 2013 ESCAPE - MYFORD TOUCH - INCORRECT CLOCK
SOME 2012 FOCUS AND 2013 ESCAPE VEHICLES EQUIPPED WITH MYFORD TOUCH WITH OR WITHOUT NAVIGATION MAY EXHIBIT A CLOCK DISPLAYING INCORRECT TIME IN THE 8" DISPLAY SCREEN. THIS ISSUE WILL BE ADDRESSED IN A FUTURE UPDATE. ON NAVIGATION EQUIPPED VEHICLES A SELECTABLE ON/OFF GPS SYNCHRONIZATION SETTING FOR THE CLOCK IS AVAILABLE. TURNING GPS SYNCHRONIZATION ON WILL SYNCHRONIZE THE CLOCK WITH THE GLOBAL POSITION SATELLITE MODULE (GPSM) ENSURING CORRECT TIME. MONITOR OASIS FOR UPDATES.
I found it here yesterday, but that page reads different today. I'm not sure exactly what it is. I kind of just stumbled upon it.
My clock is fine, but my calendar is one day ahead of reality. The Calendar is set by GPS, and cannot be adjusted. Even non-Nav MFTs have an active GPS sensor.
The fix for the calendar was to reboot the GPS by disconnecting the battery cable for 5 minutes while outside facing south.
DrRay is offline
Old 08-17-2012, 12:18 PM   #62
kxweil38
Fan#: 100546
What I Drive: 2012 Candy Red Titanium
Points 105, Level 2
Points: 105, Level: 2 Points: 105, Level: 2 Points: 105, Level: 2
Level Up 10% Completed
FF Reputation: 1 kxweil38 Good Standing Member
I was having this same problem about once a week. Just realized that I have not had to reset the time in over a month. I have MFT but no nav.
kxweil38 is offline
Old 08-23-2012, 02:02 PM   #63
FordIVTteam
Official Ford Rep
FordIVTteam's Avatar
Fan#: 87765
What I Drive: Ford Focus
Points 2,197, Level 28
Points: 2,197, Level: 28 Points: 2,197, Level: 28 Points: 2,197, Level: 28
Level Up 32% Completed
Forum Activity 2%
FF Reputation: 3 FordIVTteam Good Standing Member
Hey everyone!
I just wanted to jump in and say we're aware of this concern and our engineers are working on a solution. I don't have an ETA for the next update, but announcements will be made here:
http://Boards.SyncCommunity.com/n/pf...cmb&listMode=0
In the meantime, if you're experiencing this concern and your vehicle is equipped with navigation, please make sure your GPS Time Synchronization is set to ON. To check, press the clock and select ON next to the GPS TIME SYNCHRONIZATION field.
If your Focus doesn't have navigation, I recommend contacting your dealership service department; please do not attempt to disconnect the battery cable.
BTW, in case you haven't heard, the Outside Air Temperature Display is coming back to the main screen on the next update! (I'm pretty pumped! )
Let me know if you have any questions.
Jaclyn
FORD IN-VEHICLE TECHNOLOGY TEAM
p: 800.392.FORD (Prompts 1 then 3)
f: facebook.com/FordFocus facebook.com/Ford
FordIVTteam is offline
Old 09-19-2012, 06:50 AM   #64
Tra1969
Tra1969's Avatar
Fan#: 99323
What I Drive: 2012, Tuxedo Black, Focus Titianum
Points 44, Level 1
Points: 44, Level: 1 Points: 44, Level: 1 Points: 44, Level: 1
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Tra1969 Good Standing Member
Look like the update came out last week, then was pulled a day or two later. So back to waiting for the update again. If you go to sync message board you can get a little more info on the subject. Looks like Ford is dagling a carrot.
2012 Focus Titanium HatchBack 4/9/2012
Tuxedo Black Metallic
400a, winter package, 17" alloy wheels, .select shift (sst)
Moonroof, Sony MFT, siriusxm
Tra1969 is offline
Old 09-19-2012, 07:53 AM   #65
copernicium112
Fan#: 87742
What I Drive: 2012 Sonic Blue Ti Sedan
Points 1,491, Level 21
Points: 1,491, Level: 21 Points: 1,491, Level: 21 Points: 1,491, Level: 21
Level Up 91% Completed
FF Reputation: 4 copernicium112 Good Standing Member
The update does not apply to the Focus or the Escape. It was never put up there for either of these models. It was put up for other models and removed shortly thereafter. It was then put up again. We just don't see it under "Sync Updates" at SMR because it does not apply to us. Owners of other models will see it.
.......here's a lockpick. It might come in handy if you, the master of unlocking, take it with you.
copernicium112 is offline
Old 09-19-2012, 08:59 AM   #66
Tra1969
Tra1969's Avatar
Fan#: 99323
Points 44, Level 1
Yes, I had a conversation with the sync person on it, I still don't understand why the fix is good for one model and not another one. That just baffles me. But, I will wait and pray that when I do get the update it addresses all the issues and not just a few. I'm sure there is a reason behide it, but as long as people have waited, seems like they would explain why its not for all of us. Oh well.
Tra1969 is offline
Old 09-19-2012, 10:19 AM   #67
copernicium112
Fan#: 87742
Someone over at SMR started a thread for those to report what they find after installing the update. Unfortunately, it looks like, from what people posted, that it did not address anything other than the 4-5 things they listed as part of the update. Of course, I don't have it but from what they are saying, not much. Still some of the same bugs there.
Old 09-20-2012, 03:03 AM   #68
paul21
Fan#: 87707
What I Drive: 2012 SEL Hatchback
Points 373, Level 7
Points: 373, Level: 7 Points: 373, Level: 7 Points: 373, Level: 7
Level Up 46% Completed
FF Reputation: 0 paul21 Newbie
It's beyond me why this car doesn't have an autoset clock. All the MFT models have a GPS receiver that gives time, regardless of navi, Sirius that gives time, and the RDS that gives time. It's like the designers intentionally left it out.
paul21 is offline
Old 10-12-2012, 01:47 PM   #69
dadudzik
Fan#: 104775
What I Drive: 2012 Grey SEL
FF Reputation: 1 dadudzik Good Standing Member
I was there under Sync Updates for my Focus for a day or two and then it was pulled
There are some who downloaded and installed it but for some it broke their climate functions on the MFT
dadudzik is offline
Old 10-12-2012, 01:55 PM   #70
dalbeck
Fan#: 98629
What I Drive: 2012 Tuxedo Black Focus SEL 5 Door
Points 148, Level 2
Points: 148, Level: 2 Points: 148, Level: 2 Points: 148, Level: 2
Level Up 96% Completed
FF Reputation: 1 dalbeck Good Standing Member
My climate control stopped working since I updated my Sync about 2 weeks ago. It always says "Climate Off".. pretty annoying.
dalbeck is offline
