rough idle, SOMEONE PLEASE HELP! - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 10-15-2004, 09:56 AM   #1
driftripper155
driftripper155's Avatar
Fan#: 856
What I Drive: Blue 2000 Focus 2.0L Zetec ZX3
FF Reputation: 1 driftripper155 Good Standing Member
Angry rough idle, SOMEONE PLEASE HELP!
For Several months now, I have been experiencing a minor problem with my engine that is driving me up a wall. When I start my engine, it runs perfectly. However after the engine warms up it idles rough and actually runs a little rough throughout the entire driving range except at highway speeds. The roughness is characterized by a minor, but notable pop or put in an otherwise smooth running sound. It's not rhythmic but intermittent and it only occurs after the engine is warmed up. If I allow the engine to cool and start it up again, it's gone until the engine warms up. Right now I have several modifications to the engine. I have a performance ignition system with 10mm cables. Cold Air Intake. Street style exhaust header. 3 inch cat back system and 3 inch underdrive crank pully. At this point, I have had no check engine lights activate and the condition is not worstening. I have however heard what I think is a notable hissing sound from the rear of the engine compartment. It is noticeable over the normal engine noise and I'm not the only one who's heard it. Currently, I've replaced the O2 sensors, the pcv valve. I've pressure tested the pcv hoses and made sure there is a good seal on the nozzle where pcv hose connects to the manifold. I've also replaced the fuel filter. At this point I'm thinking my only option is to remove the intake manifold and check for cracks as well as replace the gasket as I'm convinced the piece of crap, PLASTIC intake manifold has cracked somewhere. I was wondering if anybody has experienced similar problems and what the hell was wrong. I need to know if I'm heading in the right direction with the leaking intake manifold theory.
Thanks
Matt
driftripper155 is offline
Old 10-15-2004, 02:25 PM   #2
soffiler
Registered User
soffiler's Avatar
Fan#: 372
What I Drive: '03 ZX3 PZEV 5-spd Twilight Blue; '97 F-250 4x4 w/ 351 V8 & AT
FF Reputation: 1 soffiler Good Standing Member
Matt -
The combination of the hissing sound, the fact that it only occurs after warmup, the rough idle - yes, it ceratinly sounds like it could be an air leak, and the manifold is one of a few likely candidates.
One thing bugs me, however. For a fairly large air leak (large, totally subjective term, but I mean it's large enough to HEAR above the engine noise!) I would expect a Check Engine light with a code P0171 (system too lean bank 1)
soffiler is offline
Old 10-15-2004, 05:40 PM   #3
driftripper155
Fan#: 856
Hey, thanks for your reply. I should however, have mentioned that you can only really hear the hissing over the sound of the engine when you lean all the way in over the head cover and put your ear near the throttle body. If it makes more sense now let me know. But regardless, if there's a leak, I have to take the manifold off anyway in order to check for and fix it. I haven't gotten the time or the nerve to perform this surgury yet, but time time is drawing near. Anyway, it's still a myster and any more help anyone can offer would be greatly appreciate.
Thanks
Matt
Old 10-15-2004, 06:31 PM   #4
joshandlauri
Fan#: 11168
What I Drive: Focus ZX3 pitch black
FF Reputation: 1 joshandlauri Good Standing Member
if its an air leak and its doing it hot and idle you can pin point it be taking a soapy water solution in a spray bottle, spray it around the intake until it stops for a second, this is how i firgure it out in my shop, diagnose many-a leaks this way.
josh
joshandlauri is offline
Old 10-15-2004, 09:08 PM   #5
driftripper155
Fan#: 856
hey about the soap trick. Are you suggesting that the soap mixture will temporarily stop the problem, thus confirming my suspicions. Or do you mean that the soapy mixture will show where the leak is if there is one, because it's nearly impossible to see what's going on down behind the engine. You know I'm sure.
Thanks for you help
Old 10-15-2004, 09:13 PM   #6
Tikinsin
Tikinsin's Avatar
Fan#: 5916
What I Drive: '02 Gun Grey ZX3
FF Reputation: 1 Tikinsin Good Standing Member
you didnt mention having them, but ive heard that having engine mounts can cause rough idoling, not really much you can do about that though if thats what your problem is...
Tikinsin is offline
Old 10-16-2004, 10:44 AM   #7
evnldr_Focus
Fan#: 10794
What I Drive: Silver 2001 ZX3
FF Reputation: 1 evnldr_Focus Good Standing Member
Mine dose the same thing. I havenít pin pointed it to hot or cold operation but every few seconds it has like a miss it is random ... But cruzing at 50-60 it kind of sputters off and on a lil I can feel it but its not much...and I do not hear a air leak noise that im aware of . id like to know the outcome also
MODS:
Nology Wires
MAGNAFLOW Flex Back
AEM Cold air intake
BODY:
Wings West Avenger Body Kit
Eibach Sportline Springs
Ford Racing Tail lights (nolonger chrome)
Ugly Carbon Fiber "Looking" Turn Signal Mirrors.
Billet 3rd Brake light cover
http://home.comcast.net/~evnldr/sig.jpg
<B>FRIENDS DONT LET FRENDS BUY SUBARU'S</B>
DON'T BLAME I VOTED FOR
ELMO!!!!!!!!!!
EVNLDR AKA Boomologist
evnldr_Focus is offline
Similar Threads
yet another rough idle thread (with occasional stalling/dying) dj elite General Technical Chat 9 01-14-2009 02:32 PM
Solutions for a rough idle? Acclaimed General Technical Chat 6 01-23-2008 01:57 PM
Irregular Surging and Falling Rough Idle that worsened. focusowner2001 General Technical Chat 10 07-06-2007 09:00 AM
Rough Idle -- Bad Battery? GearDriven General Technical Chat 4 12-18-2006 12:11 PM
rough idle CowsGoMoo ZETEC Performance (2000-2004) 9 10-16-2003 03:11 PM
