Help adjusting where headlights point - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-03-2012, 06:47 PM   #1
biggens77
Fan#: 87841
What I Drive: 2012 Titanium Hatch
FF Reputation: 1 biggens77 Good Standing Member
Hey all has anyone adjusted where there headlights point and if so where is the screw to do it? I just looked for like an hour and maybe I am just not so swift but I can not find it for the life of me. Any help is greatly appreciated.
biggens77 is offline
Old 01-03-2012, 06:54 PM   #2
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,086, Level 34
Points: 3,086, Level: 34 Points: 3,086, Level: 34 Points: 3,086, Level: 34
Level Up 24% Completed
Forum Activity 6%
FF Reputation: 13 dan50 Great Standing Member
Take a look at the Owner's Manual, page 126.
It should be a warranty issue if they are out of alignment, so you could also have the dealer do it.
dan50 is offline
Old 01-03-2012, 06:57 PM   #3
biggens77
Fan#: 87841
I did check the manual and it the only screw i see anywhere near the top is to remove the whole entire light. I just got my car back from an accident and I have to drive to work tonight so wanted to get it done before I went to work.
Old 01-03-2012, 11:10 PM   #4
hoffmanr09
Fan#: 89468
What I Drive: 2012 ford focus se
FF Reputation: 1 hoffmanr09 Good Standing Member
I dont think there is a way to adjust them. I put HID's in and messed around with that for a couple hours and saw nothing that would adjust them. maybe one side of your head light is looser than the other or the headlight may need to be tweeked by a mechanic.
hoffmanr09 is offline
Old 01-03-2012, 11:52 PM   #5
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
If you look at the back of your headlights, you'll find a plastic nut with gear teeth around it. The plastic nut is one way to adjust the headlight aim, but this requires removing the headlight to access the nut.
However, if you look down from the top of the headlight, you'll notice a funnel-shaped hole that goes directly to the teeth on the plastic nut. Simply stick a standard phillips-head screwdriver into the hole and turn it in the corresponding direction to either raise or lower your headlight beam.
Zillon is offline
Old 01-04-2012, 09:15 AM   #6
biggens77
Fan#: 87841
Zillion thanks so much. I was trying to do this in the dark last night which def did not help. Here are some pics for others who might not see it so easy.
Old 01-04-2012, 07:05 PM   #7
DarinS
Fan#: 88257
What I Drive: 2012 Titanium hatch, BMW E30 335iC
FF Reputation: 1 DarinS Good Standing Member
FYI, the owner's manual states that only the pitch (up/down) is adjustable on '12 headlights, the left/right orientation is not.
DarinS is offline
Old 01-05-2012, 09:53 AM   #8
Ghost71
Ghost71's Avatar
Fan#: 91701
What I Drive: 2012 black Ti hatch
FF Reputation: 1 Ghost71 Good Standing Member
Always contact your local dealer. They're set from the factory and shouldn't be adjusted.
Ghost71 is offline
Old 01-05-2012, 01:25 PM   #9
Nutty 5.0
Nutty 5.0's Avatar
Fan#: 81405
What I Drive: 2005 ZX3 SE Sonic Blue 5spd
Points 1,560, Level 22
Points: 1,560, Level: 22 Points: 1,560, Level: 22 Points: 1,560, Level: 22
Level Up 60% Completed
FF Reputation: 1 Nutty 5.0 Good Standing Member
Above is correct; adjustment only up and down; no left and right adjustment. Best way to adjust is take large box cut flat and lean box against building, garage, etc. and have car 10-20 feet away ON LEVEL GROUND and adjust per owner manual. You'll be able to see just how off they are left to right. If you're swapping headlights, good to measure and mark first prior to swapping lights. My worthless $0.02...
2012 SGM SE 4 door-5 spd,SE Sport
2010 SGM FX4 F150 Lux,Flowmaster catback,2.5" level,sat-nav,305/55/20,HD grille,heads,&tails,Jon Lund SCT tune
2005 SB ZX3 SE 5MT
1993 Mustang Featured in MM/FF and 5.0 and Super Ford Magazine SOLD - 2003 Cobra SOLD
Nutty 5.0 is offline
Old 08-05-2012, 05:04 PM   #10
jayseatee
Fan#: 93750
What I Drive: 2012 SEL Tuxedo Black
FF Reputation: 1 jayseatee Good Standing Member
Thanks Zillion for the info and Biggens for the pics. After I put my HIDs in I had an issue with the passenger side being way to high on adjustment. Now it's all set. The book shows what appears to be a typical phillips screw and thats not the case. For anyone in the future don't be fooled by that. It does, indeed, take a #2 phillips. Thanks again so much.
jayseatee is offline
