2012 Focus SE Hatchback Sport - Changing stock speakers - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 11-06-2012, 07:12 AM   #61
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 744, Level 14
Points: 744, Level: 14 Points: 744, Level: 14 Points: 744, Level: 14
Level Up 44% Completed
Forum Activity 3%
FF Reputation: 4 Tiger-Heli Good Standing Member
Originally Posted by HatsuneMiku View Post
Is the SE speakers really bad? Would you guys pay up to get MFT and the Sony Speaker system for a extra thousand plus?
Look at the initial post of the thread - They are dual-cone paper speakers. I don't think they SOUND bad - but just about ANYTHING you buy (short of maybe Metra or Rampage) is going to sound better and be better quality.
MFT still has issues - you can do a LOT to make the stock system sound better (and for a $1000, you can make it sound MUCH better than MFT). I'd only consider MFT if I wanted factory nav - and even then, I'd lean toward a Kenwood/Garmin nav unit or a portable Garmin or a smartphone with a mount.
Tiger-Heli is offline
Old 11-08-2012, 05:52 AM   #62
shellback64
Fan#: 105133
What I Drive: 2012 Race Red Focus SE
Points 41, Level 1
Points: 41, Level: 1 Points: 41, Level: 1 Points: 41, Level: 1
Level Up 82% Completed
FF Reputation: 1 shellback64 Good Standing Member
When removing the round plug (behind the the door release handle) was anyone able to accomplish this withoug leave marks or gouges? I played with it a little last night investigating for when my speakers arrive but it looks like its pretty tight and can't be removed without damage???? Anyone??? Ordered Infinity Reference 6032cf from Amazon for $48.
shellback64 is offline
Old 11-08-2012, 06:58 AM   #63
majorChibi
Fan#: 103279
What I Drive: 2012 Oxford White SE
Points 173, Level 3
Points: 173, Level: 3 Points: 173, Level: 3 Points: 173, Level: 3
Level Up 46% Completed
FF Reputation: 1 majorChibi Good Standing Member
http://www.focusfanatics.com/forum/s...73&postcount=1
about halfway down is the picture of that plug with a red arrow.
I pushed it in at that edge with a small screwdriver wrapped with a cloth and I had another fine flat head screwdriver to catch the other end of the plug when it popped up.
majorChibi is offline
Old 11-08-2012, 07:16 AM   #64
shellback64
Fan#: 105133
Points 41, Level 1
majorChibi.......thanks that helpful and so was the hyperlink!!!
Old 11-20-2012, 02:52 PM   #65
shellback64
Fan#: 105133
Points 41, Level 1
Got the new speakers installed last week. It was really quite easy. The sound is better but still limited using the factory head unit. All in all it was well worth the $48 for the speakers!!!!
Old 11-21-2012, 04:18 PM   #66
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Did you buy speaker adapters, or use the factory speaker frames for adapters?
Hatch Nation #90
TboneZX3 is offline
Old 11-21-2012, 05:31 PM   #67
shellback64
Fan#: 105133
Points 41, Level 1
I used the factory frames. Worked out real slick!
Old 11-21-2012, 06:31 PM   #68
focusstu
Fan#: 103157
What I Drive: 2012 Oxford White Focus S 5MT
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Level Up 38% Completed
FF Reputation: 2 focusstu Good Standing Member
I installed Infinity 6032si's in the front last week. I also used the factory frames and it does come out looking good, especially being able to use the factory connectors. When I tried the Infinity frames, there were some gaps between the frame and the hole in the door. Someone earlier in this thread or another thread used Scosche frames. They looked a little wider.
I had to cut notches at the edge of the factory frame to fit the tabs in the speaker where the screws go. The only thing I had to be careful with was to offset the speaker terminals from the factory frame terminals. Otherwise one of the holes drilled to attach the speaker would have gone right through the factory connector. If I ever remove the door panel again I will put some loctite on the screws also.
focusstu is offline
Old 11-28-2012, 11:34 AM   #69
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I did the same thing. A dremel made very quick work of it.
The adapters that came with my Infinities would not have worked at all--there were large gaps around the adapter where it met the door.
Hatch Nation #90
TboneZX3 is offline
Old 01-06-2013, 12:43 PM   #70
kb911
kb911's Avatar
Fan#: 91864
What I Drive: 2012 Ingot Silver SE Hatch 5spd
FF Reputation: 1 kb911 Good Standing Member
stupid question to ask but can anyone tell me how to install new tweeter I have a pair of Rockford fostgate prime 1inch tweeters I want to swap out them out with the factory ones I am a little intimidated by how to connection is on the stock speaker versus
The days when a car aficionado could repair his or her own car are long past, due primarily to the high software content. - Marc Andreessen
kb911 is offline
