2012 Focus SE Hatchback Sport - Changing stock speakers - Page 14 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 07-09-2013, 08:19 AM   #131
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 913, Level 16
Points: 913, Level: 16 Points: 913, Level: 16 Points: 913, Level: 16
Level Up 13% Completed
Forum Activity 8%
FF Reputation: 4 Tiger-Heli Good Standing Member
Somewhat - Sync is a separate module.
So if you don't have the MFT system, there is a metra (or PAC) interface that retains SYNC (or the stock inteface might).
That said, I think the Metra dash kit and wiring adapter is around $250, the head unit needs to be single Din with a rear AUX port, and the SYNC audio comes through the rear AUX input, so you lose display of song title and artist, unless you use a cheesy LCD screen with it.
2) You can add a main amp and a subwoofer amp, or a 5-channel amp.
3a) - There are add-on's like the JL Cleansweep, or Rockford 3.sixty.three - not sure they are required, but they can help the sound (along with option 3, not by themselves)
Tiger-Heli is offline
Old 07-09-2013, 11:48 AM   #132
jcw122
jcw122's Avatar
Fan#: 111081
What I Drive: 2014 Race Red SE 201A Hatch - MTX
Points 1,052, Level 17
Points: 1,052, Level: 17 Points: 1,052, Level: 17 Points: 1,052, Level: 17
Level Up 52% Completed
FF Reputation: 2 jcw122 Good Standing Member
So why do people chose to replace the headunit vs. using stock unit + JL Cleansweep,etc?
2014 SE in Race Red, 201A, Winter Package, Moonroof. Manual Transmission. e-Focus RMM. Snorkel Delete Mod. Love it!
jcw122 is offline
Old 07-09-2013, 12:11 PM   #133
Tiger-Heli
Fan#: 12379
Forum Activity 8%
EDIT: Was doing some research on the Fiesta and the OEM radio for it only supports 255 Folders and 255 files per folder. That's pretty common for a head unit, but it's a limiting factor for some people. I have one album (not necessarily full) per folder and I have more folders than that. My JVC KD-A815 supports less total files 20,000, but supports up to 2000 folders. (Granted - I could re-name my files and put 10 or 20 albums per folder, but then it is harder to browse by folder, ...
This won't win me any points on here, but the stock head unit is fairly boring/basic looking.
The Cleansweep is almost as much, if not more expensive, than many new head units, so IF you don't care about SYNC, and IF you can get past the cost of the Metra dash kit/harness, you might as well just start from scratch and replace the head unit, amps, speakers, etc. (You KNOW that can work and you aren't having to add a component to compensate for an EQ curve that you don't want the car to have to begin with).
What I wish Ford had done would be to leave the Driver Info center for warning messages and then have a standard Double-DIN radio for the MFT and a standard single DIN with a pocket for the base radio - build SYNC into the headunit and NOT tie it into the CANBUS.
But they'd rather sell you the MFT system for $1000 or $2000, so they didn't do that.
Old 07-09-2013, 10:49 PM   #134
ptbish
ptbish's Avatar
Fan#: 114734
What I Drive: 2013 Ruby Red Focus SE, HB
Points 22, Level 1
Points: 22, Level: 1 Points: 22, Level: 1 Points: 22, Level: 1
Level Up 43% Completed
FF Reputation: 1 ptbish Good Standing Member
Glad you got it sorted out.
Forgot - you can also do a "Battery Pop Test" to sort it out.
Connect a small battery (D-cell or 9V) to one wire and briefly touch it to the other speaker wire terminal. If the speaker cone moves outward, the plus battery terminal is connected to the plus wire. If it moves inward, the plus battery terminal is connected to the negative speaker wire.
Of course, this only works BEFORE you destroy the OEM speakers to mount the replacements.
That's precisely what i did! Great minds......
ptbish is offline
Old 07-09-2013, 11:02 PM   #135
redzone
Fan#: 114512
What I Drive: 2013 Blue Candy Hatchback SE
Points 769, Level 14
Points: 769, Level: 14 Points: 769, Level: 14 Points: 769, Level: 14
Level Up 69% Completed
FF Reputation: 1 redzone Good Standing Member
is it just me or do the buttons on the metra kit just look cheap!
thats my biggest reason id stick to the stock headunit.
2013 Focus Hatch Se
Blue Candy
Build Date: 03.02.2013
Stock for now
redzone is offline
Old 07-10-2013, 07:19 AM   #136
Tiger-Heli
Fan#: 12379
Forum Activity 8%
It isn't just you - although I haven't seen the kit in person - only videos and pictures on the WWW.
Also - Metra kinda got screwed over here. They made a similar kit for the Ford Fiesta (which in 2011 had red interior lighting). All I can guess is they ASSuME'd the Focus would have red lighting also, so their Focus kit has red lighting instead of ice blue to match the car - and now the 2014 Fiesta will have ice-blue lighting, so their kit doesn't match it very well either.
What doesn't make much sense to me, though is that the Chinese knock-offs manage to match the lighting perfectly for a reasonable cost - see:
http://www.aliexpress.com/item/free-...687721704.html
http://www.aliexpress.com/item/Car-D...905089495.html
http://www.aliexpress.com/item/New-g...619426666.html
http://www.aliexpress.com/wholesale/...Type=price_asc
http://www.optimaforums.com/forum/23...s-install.html
All of which are viable options if you don't care about SYNC (or SIRIUS) ...
Old 07-10-2013, 02:29 PM   #137
redzone
Fan#: 114512
would you not be able to keep non-mft sync if you used the adapter? assuming those head units have an aux in?
2013 Focus Hatch Se
Blue Candy
Stock for now
redzone is offline
Old 07-10-2013, 03:17 PM   #138
Tiger-Heli
Fan#: 12379
Forum Activity 8%
Sure - sortof ...
Here's this way that works, though ...
First off, the adapters are $140-$150:
http://www.metraonline.com/part/AFSI-01
http://www.pac-audio.com/productDeta...?ProductId=919
Now:
If you have the factory system, as you probably know, you plug your USB stick in the center console, you say "USB - Play Track "Shooting Star", the system says "Playing track - "How You Are" ... and eventually you get it sorted out and the system starts playing and displays the song title and artist name (and with MFT, the album art).
If you have the adapter - you plug the USB stick in the center console, switch to the AUX input, and say "Play Track Shooting Star" and hopefully the song starts playing, but the AUX input is analog, so you don't get any song title or artist name unless you install a tacky external LCD screen. Or you can plug your USB stick into the adapter with the aftermarket head unit and you get full ID3 tag info and album art (and better sound quality), but you can't say "Play Track Shooting Star" and have anything happen.
Old 07-10-2013, 03:41 PM   #139
Tiger-Heli
Fan#: 12379
Forum Activity 8%
I have a related question - I tried asking one of the suppliers (was mainly wondering about the Fiesta, but I think the Focus would be the same setup):
The Metra dash kit retains the 4.3-inch display - I think b/c the display is also used for certain warning messages (on the Fiesta, one of them is ABS FAIL, TRANSMISSION MALFUNCTION, etc.)
The Chinese kits above clearly replace the 4.3-inch display with an 8-inch display.
Would you think the kits are tied into the CANBUS well enough that an ABS FAIL warning will be displayed on the 8-inch screen, or would you just never see these messages? Would it be a big deal not having the 4.3-inch screen if you weren't using it for the radio?
Thanks!!!
Old 07-10-2013, 06:16 PM   #140
redzone
Fan#: 114512
the only reason i wouldnt mind keeping sync (and installing a android aliexpress thing) would be to keep the steering wheel controls.
not sure if that android headunit would do that.
2013 Focus Hatch Se
Blue Candy
Stock for now
redzone is offline
