2012 Focus SE Hatchback Sport - Changing stock speakers - Page 13 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 07-06-2013, 05:21 PM   #121
ptbish
ptbish's Avatar
Fan#: 114734
What I Drive: 2013 Ruby Red Focus SE, HB
Points 22, Level 1
Points: 22, Level: 1 Points: 22, Level: 1 Points: 22, Level: 1
Level Up 43% Completed
FF Reputation: 1 ptbish Good Standing Member
I am trying to use the originalspeaker brackets and also reuse the existing speaker plug. Anyone have any idea which side of the plug is positive/negative. I am sure this has been posted in the past, but I'll be darned if I can find it. I also tried doing a search on the web without luck. Help is appreciated.
ptbish is offline
Old 07-06-2013, 05:26 PM   #122
ptbish
ptbish's Avatar
Fan#: 114734
Points 22, Level 1
Originally Posted by MetalMuffins View Post
+1 on this. When I replaced mine, I cut the old cones out and used the stock rings of the speakers to mount them. Soldered the new speakers to the stock plugs and re-used the stock wiring. I think this is the best way to do it and avoid hassle.
Yes, but which side of the terminal did you solder the new postive and negativ wires to. This matters.
ptbish is offline
Old 07-06-2013, 05:45 PM   #123
ptbish
ptbish's Avatar
Fan#: 114734
Points 22, Level 1
Originally Posted by vacman View Post
Finally installing today. Anyone know which is ground on the stock harness?
Sent from my Xoom using FF Mobile
Yes, this is my question too! Ford does not mark pos neg, and both wires leading to plug are black.
ptbish is offline
Old 07-06-2013, 06:04 PM   #124
ptbish
ptbish's Avatar
Fan#: 114734
Points 22, Level 1
Originally Posted by Casbs_12 View Post
Have the 6-speaker system. Updated all four door speakers to Polk DXI650 today. Sound is a lot crisper and I'm able to turn the volume up without any distortion. The upgrade is well worth the money. Thanks to the OP for the mod instructions and inspiration.
Hey, I am in the process of installing the same speakers. Just wondering, did you disconnect the factory tweeters?
ptbish is offline
Old 07-06-2013, 11:07 PM   #125
jcw122
jcw122's Avatar
Fan#: 111081
What I Drive: 2014 Race Red SE 201A Hatch - MTX
Points 1,052, Level 17
Points: 1,052, Level: 17 Points: 1,052, Level: 17 Points: 1,052, Level: 17
Level Up 52% Completed
FF Reputation: 2 jcw122 Good Standing Member
Originally Posted by geocore View Post
I just picked up Tux Black 2013 SE... I didn't get the MFT since the Sony system was not a great system. Below is a few pics.
Can you describe the setup? What's the box in the door? Did you keep sync?
2014 SE in Race Red, 201A, Winter Package, Moonroof. Manual Transmission. e-Focus RMM. Snorkel Delete Mod. Love it!
jcw122 is offline
Old 07-08-2013, 07:55 AM   #126
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 913, Level 16
Points: 913, Level: 16 Points: 913, Level: 16 Points: 913, Level: 16
Level Up 13% Completed
Forum Activity 8%
FF Reputation: 4 Tiger-Heli Good Standing Member
There is no ground, the input to the speaker is AC Voltage.
It would be nice to figure out from a harness diagram, but it doesn't really matter.
As long as you use the SAME terminal as NEG at all locations, it will work fine.
If the bass drops off when you set the balance or fader to centered, one speaker is out-of-phase and you need to reverse those wires.
Tiger-Heli is online now
Old 07-08-2013, 08:35 AM   #127
ptbish
ptbish's Avatar
Fan#: 114734
Points 22, Level 1
factory speaker jack
Thanks for the reply. I did some testing on the original speaker and determined the right side of the speaker jack is pos when installed in its original orientation. Hope this is useful to somebody.
ptbish is offline
Old 07-08-2013, 08:42 AM   #128
Tiger-Heli
Fan#: 12379
Forum Activity 8%
Glad you got it sorted out.
Forgot - you can also do a "Battery Pop Test" to sort it out.
Connect a small battery (D-cell or 9V) to one wire and briefly touch it to the other speaker wire terminal. If the speaker cone moves outward, the plus battery terminal is connected to the plus wire. If it moves inward, the plus battery terminal is connected to the negative speaker wire.
Of course, this only works BEFORE you destroy the OEM speakers to mount the replacements.
Old 07-08-2013, 05:50 PM   #129
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
That's how I did it. I don't recommend a 9V battery. Use a 1.5V AA, C or D.
Hatch Nation #90
TboneZX3 is offline
Old 07-08-2013, 06:37 PM   #130
jcw122
jcw122's Avatar
Fan#: 111081
I don't really wanna make a whole thread about this but I wanna ask something...what are my options for replacing the stock 6 speaker system? As far as I can tell I can:
1) Just replace the actual speakers
2) Add an amp to the stock system with a subwoofer, use a line-out (I think?)
3) Combo of 1+2
4) Completely replace the headunit and lose Sync, which seems to be the most complex method
What am I missing here? Is there a way to power the "normal" speakers better than the stock headunit can and get a sub, without trashing the Sync features and creating all the hassle of #4? I've seen people just use a Android/Windows device with the Metra front interface, and keep Sync but is there yet another way to do it?
jcw122 is offline
