Front brake pad WIRE retainer - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-21-2011, 12:58 PM   #1
mrdeath2000
Fan#: 91996
What I Drive: 2014 White SE 5spd
Points 1,331, Level 20
Points: 1,331, Level: 20 Points: 1,331, Level: 20 Points: 1,331, Level: 20
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 3 mrdeath2000 Good Standing Member
Is the wire clip that sits on the outside of the caliper a required part?
My passenger side one was sticking out when I got to work and will have to wait until I get home to do anything with it. It appears the caliper will prevent anything from falling off, does this wire just reduce some movement of the other pad?
2014 Focus SE Manual -
2006 Focus ZX4 SE Auto -commuter 110k /traded
mrdeath2000 is offline
Old 12-21-2011, 02:02 PM   #2
91Sickness
91Sickness's Avatar
Fan#: 59174
What I Drive: 2003 Metallic Grey Se 2.0 Zetec
FF Reputation: 2 91Sickness Good Standing Member
i would fix it because it holds the pad in their under hard braking and if you hit a big enough pot hole it could fall out on you
03 Focus Dark Shadow Metallic Grey SE 2.0L Zetec
Sedan Revolution
Zetec Crew
91Sickness is offline
Old 12-21-2011, 02:21 PM   #3
alex62390
BACON?
alex62390's Avatar
Fan#: 60434
Location: People's republic massivetwoshits, United States
What I Drive: 2004 svt focus EAP
FF Reputation: 22 alex62390 Great Standing Member
You talking about this thing? Its a anti rattle spring. pull it off, the re install it when you get home. Nothing will fall apart. It does not hold the pad in there, the pad is retained by the caliper and the bracket. all it does is hold the caliper in the correct place, to keep the noise down.
SAAB's have the same thing, i have seen the missing off cars for long periods of time with no major issues. But i would get it on there as soon as possible. Lube the ends so it does not seize in there.
2004 svt focus EAP #658
Former Hatch Nation #08
alex62390 is offline
Old 12-21-2011, 02:51 PM   #4
mrdeath2000
Fan#: 91996
Yup, that's the B!
I've never seen one before that was this way, usually they were integrated into the pad and clipped onto part of the caliper.
Thanks! :D
Old 12-21-2011, 04:16 PM   #5
deadend9009
Fan#: 69681
What I Drive: 2003 Grey Focus ZX5
FF Reputation: 3 deadend9009 Good Standing Member
Without the clip your caliper is only held by the caliper slide pins and will make the caliper unstable under braking and eventually your pads will wear completely crooked. Ask me how i know....
It isn't an option, fix it!
deadend9009 is offline
Old 03-05-2013, 11:33 AM   #6
mizts
Fan#: 59912
What I Drive: 2000 ZTS
FF Reputation: 1 mizts Good Standing Member
What braking issues did you have caused by clips or lack thereof?
I had a total loss of braking at one point (pedal to the floor) caused by a clip that wasn't fitting onto the mounting properly (it was actually rubbing against the inside of the roadwheel).
mizts is offline
Old 03-08-2013, 10:36 PM   #7
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,384, Level 65
Points: 9,384, Level: 65 Points: 9,384, Level: 65 Points: 9,384, Level: 65
Level Up 12% Completed
Forum Activity 6%
I ran without mine for several thousand miles and had no issues. I keep a couple old ones off my used pads just incase I ever need on for some reason in the future.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 03-09-2013, 01:10 AM   #8
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
Forum Activity 3%
They hold the caliper dead flat with much more force than none. The pads will begin to wear cock-eyed with springs missing, since the caliper can then raise up out of plane much easier.
amc49 is offline
Old 03-09-2013, 01:23 PM   #9
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
the previous owner half-assed my retainer clips, so the pads didn't sit flush. Created the craziest wear pattern you've ever seen.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
