2012 HID Thread (Info Only No Arguing) - Page 38 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-01-2013, 05:19 PM   #371
Creative
Creative's Avatar
Fan#: 108024
What I Drive: 2013 Ford Focus
Points 3,615, Level 37
Points: 3,615, Level: 37 Points: 3,615, Level: 37 Points: 3,615, Level: 37
Level Up 77% Completed
FF Reputation: 3 Creative Good Standing Member
Idea to edit my fog light setup with HID foglights now that I have hid headlights. I need thoughts and ideas headlights are 35w and foglights will be 35w.
Originally Posted by Dialed View Post
Let's be honest guys, car modding is not synonymous with warranty-covered cars.
As the old saying goes, you have to pay to play.
Creative is offline
Old 04-01-2013, 05:30 PM   #372
KibaWolf
KibaWolf's Avatar
Fan#: 97035
What I Drive: 2012 Ford Focus Titanium
Points 2,609, Level 31
Points: 2,609, Level: 31 Points: 2,609, Level: 31 Points: 2,609, Level: 31
Level Up 6% Completed
FF Reputation: 1 KibaWolf Good Standing Member
you sure could do that but you would need another relay harness for the fogs and they will be on all the time with the headlight, if its what you want, I say go for it, but i prefer running only with my fog light on and turn my headlight off :P, you can do that with a switch on the trigguer circuit of the relay harness
Posted via FF Mobile
KibaWolf is offline
Old 04-01-2013, 05:52 PM   #373
Creative
Creative's Avatar
Fan#: 108024
I honestly don't mind them being on all the time and I don't use my drl at all either, I'm just worried about the load on the wires and possibly shorting out the system
Creative is offline
Old 04-01-2013, 05:58 PM   #374
KibaWolf
KibaWolf's Avatar
Fan#: 97035
you wont have a problem since you will need another relay kit for the fogs like I said, the relay kit draw allmost no juice at all from your original car headlight wiring, everything is drawed from the battery, so you dont have to worry about it, Trust me I know what I am talking about, im a car technician and I do a lot of electrical stuffs.
KibaWolf is offline
Old 04-01-2013, 06:13 PM   #375
Creative
Creative's Avatar
Fan#: 108024
Okay I will order it and check it out then. Ps my car also did not have fog lights.
Creative is offline
Old 05-07-2013, 06:45 PM   #376
electricbeach
electricbeach's Avatar
Fan#: 113132
What I Drive: 2012 blue focus SE 5-speed
Points 145, Level 2
Points: 145, Level: 2 Points: 145, Level: 2 Points: 145, Level: 2
Level Up 90% Completed
FF Reputation: 1 electricbeach Good Standing Member
Originally Posted by Fraychild View Post
Posting some pics to try and help out as much as I can... Okay... not my official write up, but trying to give people a boost.
Basically - you have a "Relay Harness", two "Resistor Harnesses" and an HID Kit (2 Ballasts and 2 Bulbs)...
You'll notice that the "Relay Harness" has two ballast male connectors with open ground wires - A short wire with a male connector (for driver side ballast), a long wire with a male connector (for passenger side ballast) and also a shorter wire with a female connector (for driver side car headlight connector).
DRIVER SIDE:
1 - Using the "Relay Harness" connect the fused red wire to the + side of your battery:
2 - Take the shorter wire with the female connector from the "Relay Harness":
and plug in one of your "Resistor Harnesses" male connector in it:
3 - Now plug the car's male connector from the Headlight into the female connector of your "Resistor Harness":
4 - Screw in your HID bulb and Plug in your bulbs/ballasts connectors:
5 - Plug the driver side male connector from the "Relay Harness" into the ballast and screw down both Ground wires from the "Resistor Harness" & "Relay Harness" to car chassis:
PASSENGER SIDE:
1 - This one is really easy - You will NOT be using the male connector from the 2nd "Resistor Harness"... You'll only need to plug in the car's Headlight connector into the female side of it:
2 - Connect the "Relay Harness" long male connector into the Ballast and once again, screw down the Ground wires for both the "Resistor Harness and Relay Harness down to the car's chassis: (I used one of the fender's mounting bolts)
Hope this helps and doesn't confuse you guys any further!
Personally, I'm no longer getting the dipped beam error message, however, I haven't found the best mounting spots for either one of my ballasts... and I also haven't mounted my resistors in secure enough locations... as I mentioned before, they're dangling in my fender walls for now...
Sorry to quote with the pics but I just want to make sure I understand this right.
So plug the resistors into the plugs coming from the relay kit.
Then the other plug from the resistors gets plugged into the ballast.
Only one plug (driver's side for us) from the factory headlights goes into the relay to physically turn the relay on?
Then just plug the two small bulb connectors into the ballast and that's it?
Thanks for the help.
electricbeach is offline
Old 05-10-2013, 11:54 PM   #377
Dalamar
Fan#: 94696
What I Drive: 2012 SE hatch Blue Candy
FF Reputation: 1 Dalamar Good Standing Member
I ordered mine from https://www.ddmtuning.com/
I called in my order for 55 watt and supposedly they come plug and play, cheap for the low/high/fogs too. I also had them send me LED's for the side lights up front, I've had great luck with this company in the past, their staff knows what they're doing and helpful.
my .02
Dalamar is offline
Old 05-17-2013, 11:05 PM   #378
jayw32
Fan#: 103280
What I Drive: 12 sonic blue se
FF Reputation: 1 jayw32 Good Standing Member
my .02
any news on this kit??
jayw32 is offline
Old 05-18-2013, 07:17 PM   #379
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,498, Level 52
Points: 6,498, Level: 52 Points: 6,498, Level: 52 Points: 6,498, Level: 52
Level Up 74% Completed
Forum Activity 4%
FF Reputation: 9 SilverPony2001 Good Standing Member
Originally Posted by zolemite View Post
I started to have one light not firing. I had both lights not firing so I just pulled them out and put my halogen bulbs back in. I'll rock OEM until/if I ever get projectors, then buying a high end kit from retrofit resource
What kit were you using? I used to have an $50 Ebay kit on my old ZX5 and I would have ballasts fail like every 3 - 4 months and have to replace them. But you get what you pay for.
SilverPony2001 is offline
Old 05-18-2013, 07:19 PM   #380
zolemite
zolemite's Avatar
Fan#: 36933
What I Drive: 2012 Focus S 2.0 5mt
Points 1,448, Level 21
Points: 1,448, Level: 21 Points: 1,448, Level: 21 Points: 1,448, Level: 21
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 zolemite Good Standing Member
Ddm tuning 55w
zolemite is offline
