#101 | ||||
I'm wanting projectors with HID's because I want them... it's as simple as that. I will be doing very few things to the car, and this is one of them. I have no problem with the current light output, but I think the black housings and projected HID's will just look a hell of a lot cooler. |
| Sponsored Links | |||
Advertisement | |||
#102 | ||||
For those of you that have HID's in your fog lamps, does the heat cause an issue? I don't want to melt my housings.
#103 | ||||
How much about are you looking at to do a HID conversion. Im not sure if I want to do that or just get better bulbs in the current headlights.
#104 | ||||
$30 for the 35watt, $40 for the 55watt plus shipping. I think the bulbs are under lifetime warranty. DDM Tuning.
#105 | ||||
#106 | ||||
No you need the HID kit, then there is lamp error you need to fix with either resistors or something I did was add an engine bay light. No more lamp error.
#107 | ||||
#108 | ||||
Sonic Mk3 Crew #03
Read the first post...........
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq 01 Turbo Focus 300+ whp 2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq |
#109 | ||||
After reading this thread everything seems quite clear. The only question I have is that will I need one resistor link or two? If the unused plug is the only one causing the issue then only one resistor would be needed. However, in the OP's wiring explanation it says that both sides have a resistor.
#110 | ||||
Sonic Mk3 Crew #03
I use resistors on both sides without it you have a chance of getting the dipped bulb fault from time to time.
| Thread Tools | |
| Display Modes | |
