Battery Corrosion 2010 SE - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-20-2011, 12:05 PM   #1
BillyKeith
Fan#: 90032
What I Drive: 2010 white suede SE
Points 557, Level 11
Points: 557, Level: 11 Points: 557, Level: 11 Points: 557, Level: 11
Level Up 14% Completed
FF Reputation: 1 BillyKeith Good Standing Member
2010 Ford Focus SE sedan, 4 cylinder. Seeing white corrosion around battery "hold down" but none on either terminal. Could battery be bad or beginning to fail?
BillyKeith is offline
Old 12-20-2011, 05:07 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,426, Level 86
Points: 18,426, Level: 86 Points: 18,426, Level: 86 Points: 18,426, Level: 86
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 7%
FF Reputation: 49 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
It's normal for a lead/acid battery to 'leak' around the terminals. This is one large advantage of dry or gel batteries, no corrosion/leakage.
The other thing is if the cable ends are not lead there will be "galvanic corrosion" taking place, on top of the leaking battery acid. I'm not sure what type of metal Ford used for the cable ends.
But you're best bet is to remove the cables, clean them with a wire brush, baking soda and warm water. Then use wheel bearing grease or dielectric grease to coat the terminals and cable ends. This seals out air and prevents corrosion.
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 12-21-2011, 05:22 AM   #3
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 34,176, Level 100
Points: 34,176, Level: 100 Points: 34,176, Level: 100 Points: 34,176, Level: 100
Level Up 0% Completed
Forum Activity 5%
I know you said it's on the tie down and not the terminals but I'd give it a this a shot to see if it goes away. Here's how I cleaned mine up and the products I used I got at autozone (not pictured I used bulb grease on terminals before attaching everything).
Originally Posted by ranger_mclaren View Post
Cleaner, protectant, and washers.
What I have been dealing with.
I sprayed cleaned off and wire brushed the terminals, and the connectors. It looks like the factory connectors are cooper too.
I cleaned up all the over splash and greased up everything and reattached all the wires then spaid on the protectant.
TheGlassMaker is offline
Old 12-21-2011, 10:56 AM   #4
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,616, Level 58
Points: 7,616, Level: 58 Points: 7,616, Level: 58 Points: 7,616, Level: 58
Level Up 33% Completed
Forum Activity 12%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
not sure about your battery location/hold down but the same thing was happening with mine. I'm going to assume its the same thing I'm talking about.
I painted the bare metal hold down with some high temp black paint i had laying around. I took it off, cleaned off the corrosion and then painted it with a couple coats. Let it dry and then reinstalled it. I bet some of the liquid plasti-dip would work well for this hook too, just dip it and let it dry.
Mine was corroding right at the hook where it was anchored to the plastic (right above where the FSWerks sticker is on my CAI on this picture.)
I'm not sure why it was corroding there as it actually isnt touch the battery, so not sure if it was just the metal the hold down was made out of? I hit up the nut that screws the hook/hold down too but the paint wore off as soon as i reattached it
I havent noticed it corroding again yet, i painted it this past spring.
rambleon84 is online now
Old 12-04-2012, 02:06 AM   #5
ranger97
Fan#: 106811
What I Drive: 2011 blue Focus S manual. miss rgr
Points 17, Level 1
Points: 17, Level: 1 Points: 17, Level: 1 Points: 17, Level: 1
FF Reputation: 1 ranger97 Good Standing Member
I just purchased a used 2011 Focus. There was a small amount of corrosion on the hold down. I thought this might not be unusual but upon removing and cleaning, noticed corrosion down in the battery tray and on the support plate and even underneath that, I fear on top of the transmission. There were pools of acid in the depressions where the tray bolts are. I cleaned the tray up however the bolts are so corroded I think they will break if I try to remove them. Going back to the dealer. Has anyone else had this experience?
ranger97 is offline
Old 12-04-2012, 10:43 AM   #6
mjd4277
King of all blacks!!
mjd4277's Avatar
Fan#: 64900
What I Drive: 2013 Fusion SE,2012 Fiat 500 Abarth
FF Reputation: 7 mjd4277 Good Standing Member
It hasn't happened to me yet,and I live in a state where you have to watch out for salt corrosion.
1975 MG MGB Mk IV "Downshift"
2012 Fiat 500 Abarth "Scorpion"
2013 Fusion SE "Epyon"
2003 Nissan Frontier SVE "Trailbreaker"
Team Duratec #241-Bailout Money?!?! WTF is that??
mjd4277 is offline
Old 12-04-2012, 08:38 PM   #7
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,656, Level 78
Points: 14,656, Level: 78 Points: 14,656, Level: 78 Points: 14,656, Level: 78
Level Up 52% Completed
Forum Activity 3%
FF Reputation: 90 goinloco1 Excellent Standing Member
what I'm seeing is pure lack of under hood maintenance from the pictures I'm seeing. Keeping the engine compartment at least half way clean prevents alot of problems.
Dirt attracts moisture which in turn will give voltage a path to flow. This includes across the top of the battery from terminal to terminal or terminal to hold down, or any path it can establish for that matter. the corrosion your seeing is actually created by small amounts of sulfuric acid (yes, they give off vapor occasionally. when this mixes with moisture it becomes acid again) from the battery mixing with the moisture in the dirt and being attracted to a voltage source.
the powder you are seeing is actually dried acid and is in itself caustic. don't brush it off and blow it away, you're just leaving it to create corrosion elsewhere later, or find it's way back to where it started.
either mix up some baking soda and water or grab a can of coke, either will neutralize sulphuric acid. gently pour on and you'll see it foam (I pour it over the entire battery and terminals and also the top of the tranny). let it do its thing for a bit, apply liberally once again and give a little time, when foaming quits rinse with fresh water and brush, or disassemble then reapply once more, then rinse and clean.
Keep your battery and surrounding area clean if you want it to keep you happy. as some have found, repairing battery cables isn;t cheap. but 20 minutes every 6 months or so can save a boatload of time and money. :)
goinloco1 is online now
Old 12-04-2012, 08:41 PM   #8
nekoashide
Fan#: 50156
What I Drive: 2010 Ford Focus S
FF Reputation: 1 nekoashide Good Standing Member
When that started to happen I replaced the battery. Texas heat got to it and I knew it was only a matter of time before it started eating things.
nekoashide is offline
Old 12-05-2012, 08:26 PM   #9
ranger97
Fan#: 106811
Points 17, Level 1
In my vehicle I would like to remove the battery tray to inspect underneath. But I think the bolts holding it down are actually studs attached to the metal plate underneath. These are so corroded they will probably break by removing.
Does anyone know if the metal plate supporting the box can be replaced? It looks like there may be something underneath the plate that is supported by it. I have the manual transmission, which is directly below the battery and support.
The dealer (non-ford) that sold me the vehicle wouldn't remove this to inspect underneath, and Ford Customer service told me there is no technical support that can tell me anything about it, I have to go to the dealer and pay an $80 fee for them to even talk to me.
ranger97 is offline
