MK3 2012 Focus - Oil Change 101 - Page 63 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-12-2014, 01:45 PM   #621
mishka
mishka's Avatar
Fan#: 107408
What I Drive: 13' TB SE Sport Sedan DCT 201A pack
Points 2,335, Level 29
Points: 2,335, Level: 29 Points: 2,335, Level: 29 Points: 2,335, Level: 29
Level Up 24% Completed
FF Reputation: 1 mishka Good Standing Member
deleted
~ Shadowfax ~ 169.5 whp; 156.5 torque
mishka is offline
Old 03-22-2014, 01:34 AM   #622
mishka
mishka's Avatar
Fan#: 107408
my acceleration feels sluggish and slower after I did my oil change. Could it be because it's full synthetic? anyone else get the same feeling?
thanks
mishka is offline
Old 03-22-2014, 01:36 AM   #623
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,265, Level 67
Points: 10,265, Level: 67 Points: 10,265, Level: 67 Points: 10,265, Level: 67
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
FF Reputation: 26 suss6052 Great Standing Member
thanks
No, that doesn't make too much sense if you didn't use the wrong viscosity motor oil, if anything synthetic flows easier, which should impart less drag on engine components.
suss6052 is online now
Old 03-22-2014, 03:51 AM   #624
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
190 weight gear oil might but no check if you unplugged a connector by accident..
Seminoles is offline
Old 03-22-2014, 04:51 AM   #625
Kjanracing
Kjanracing's Avatar
Fan#: 135409
What I Drive: 2014 Ruby Red SE hatch with DCT
Points 503, Level 10
Points: 503, Level: 10 Points: 503, Level: 10 Points: 503, Level: 10
Level Up 6% Completed
FF Reputation: 2 Kjanracing Good Standing Member
Retrace your steps. Did you put oil back in? It went in the opening under the 710 cap?
Kjanracing is offline
Old 03-22-2014, 10:00 AM   #626
mishka
mishka's Avatar
Fan#: 107408
We drained the oil, which took maybe only 5 minutes tops... I was running low... I had that Oil change warning for a few days. I forgot I had an extra quart of 5w-20 synthetic blend - I could have topped it off.
Anyways I used 5w-20 full synthetic Castrol Syntec. put in 4 quarts and then in the user manual it said it needs 4.5 so I put in another half quart but it maybe was too much oil to put in? When I check the dipstick the oil is a few milimeters above the hashmarks (bit too much) - it's supposed to be in the middle of the hashmarks right?
I also cleaned/lubed my air filter, and treated my gas tank with Seafoam motor treatment, but that should already but gone through the engine.
could it be that or a combination of all those things?
mishka is offline
Old 03-22-2014, 10:31 AM   #627
Seminoles
Seminoles's Avatar
Fan#: 98405
Forum Activity 2%
How many miles between last change light should never come on I do 5000 had it come on once they forget to reset it. If it is low to the add mark in even 7500 miles take it in to dealer. The level cold would be at high line or just above recommend check is a fee minutes after turning off engine. Good luck. Not sure what sea foam would do might have fouls a plug have codes checked for miss fires. Also lightly oil air filter to much oil will destroy the MAF meter try cleaning it.
Old 03-22-2014, 10:35 AM   #628
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,458, Level 75
Points: 13,458, Level: 75 Points: 13,458, Level: 75 Points: 13,458, Level: 75
Level Up 52% Completed
Forum Activity 99%
Just a few mm. high on the dipstick isn't an issue. Should be at the top of the hash marks when full, bottom of them is 1 qt. low.
Don't know how much gas you've gone thru since the Seafoam gunk in the tank, you'll have some in there for a while as it gets diluted more.
IF it is actually running any different, the air filter service might be involved. What filter & how did you clean/dry/oil it?
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 03-22-2014, 11:09 AM   #629
mishka
mishka's Avatar
Fan#: 107408
It was around 9,500 miles on the last oil... I know... that's really bad lol...
I did clean and oil the air filter myself as per instructions. The filter is Steeda's. I sprayed it with the cleaner, let it sit 10 mins, and cleaned it in the sink with water which did most of the job. Let it dry completely, the oiled it. I do not feel that I used too much oil, and even let it sit inside the house for over 24 hrs after oiling. I will check the MAF.
"Seafoam Motor Treatment" and K/N cleaner kit
After oiling filter
maybe a re-flash of my tuning will sort things out?
thx
mishka is offline
Old 03-22-2014, 11:16 AM   #630
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,411, Level 29
Points: 2,411, Level: 29 Points: 2,411, Level: 29 Points: 2,411, Level: 29
Level Up 74% Completed
Forum Activity 2%
FF Reputation: 3 Juicedz Good Standing Member
Grab some Maf sensor cleaner and give that a shot. Some people have issues with them getting gunked up after an air filter cleaning/oiling. I highly doubt the oil change has anything to do with it.
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
