Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 12-20-2011, 12:15 PM   #11
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
FF Reputation: 6 dan50 Good Standing Member
Originally Posted by Houten View Post
Sorry question here from the mechanically challenged: Drain first then swap filter?
Also when checking for leaks should i rev the engine a bit or just let it idle? And how long to test for leakage?
Also do you recommend preloading the filter since its sitting with hole up?
Is there any reason that they can void the warranty for self oil change? (besides making stupid mistake like forgetting the drain plug), I plan to buy filter from dealer.
While it doesn't matter much, I remove the oil filter first. Then I can install the new filter while the crankcase drains.
Once the engine has run for a minute or so, rev it to around 2,000 RPMs for a few seconds. This will build oil pressure to near its maximum level and may identify leaks that wouldn't occur at idle.
I don't preload the filter because it's messy and it introduces a batch of unfiltered oil into the engine. If you want to avoid some of the start-up clatter crank the engine for a few seconds with the accelerator floored. Gas is shut off when you do this but the oil pump should fill the filter.
Changing your own oil shouldn't jeopardize your warranty but make sure you keep receipts for oil and filter and record date and mileage. To be extra careful, take a picture of the oil, filter and receipt and email them to yourself. This is harder to lose and also gives evidence you used oil that meets Ford's specs (WSS...945 - see owner's manual).
dan50 is offline
Old 12-20-2011, 12:33 PM   #12
ElectricAL
ElectricAL's Avatar
Fan#: 71376
What I Drive: 2005 Silver ST
FF Reputation: 2 ElectricAL Good Standing Member
Anybody know the purpose of the felt thing???? Is that some kind of splash guard? If so, call me skeptical of the long-term durability of the material
ElectricAL is offline
Old 12-20-2011, 12:37 PM   #13
2012sel
2012sel's Avatar
Fan#: 84814
What I Drive: 2012 Red Candy SEL 5 door
FF Reputation: 8 2012sel Good Standing Member
Nice!
I've added this to the OP. I've never preloaded an oil filter, but considered it after hearing the racket my engine made for 3 seconds after the oil change.
Current
2012 SEL 5 door w/Premium Package - April 2011 | 1957 Chevrolet 3200 - 2005
Past Rides
2000 F150 Sport 2000-2011 | 1988 Ranger XLT 4wd 1988 - 2000 | 1966 Mustang 1983 - 2008 | 1963 Ford Econoline Van 1979 - 1983
2012sel is offline
Old 12-20-2011, 12:43 PM   #14
2012sel
2012sel's Avatar
Fan#: 84814
I don't know for sure, but I'd wager it's for sound deadening and aerodynamics. It appears to be the same material used inside the wheel wells. I've seen that this material has been in use by Ford for a couple of years.
I think it's a sheet of plastic with a textured felt covering. Only time will tell on it's lifespan.
Current
Past Rides
2012sel is offline
Old 12-20-2011, 12:49 PM   #15
ElectricAL
ElectricAL's Avatar
Fan#: 71376
Yah, you're probably right... on all counts. That stuff is in my wheel wells ('05 ST) and I've never liked the looks of it, esp in the winter when there's sometimes heavy icicles hanging off of it... but it's still there and seems to be doing fine
Old 12-20-2011, 07:56 PM   #16
Houten
Fan#: 92118
What I Drive: 2012 Ford Focus
FF Reputation: 1 Houten Good Standing Member
How does cranking the engine with accelerator floored work with the push start?
I think the car only goes into accessory mode without the brake pressed...?
Houten is offline
Old 12-20-2011, 08:21 PM   #17
Royal Tee
Royal Tee's Avatar
Fan#: 10037
What I Drive: Black Loaded Titanium & 2k1 SE
FF Reputation: 1 Royal Tee Good Standing Member
Wow, I was just wondering today if a 2012's wells would be like my 2001 which looks like a dead squirrel w/a dangling hairpiece.
glad to know it's actually better.
>B^)>
Royal Tee is offline
Old 12-31-2011, 05:52 PM   #18
2012sel
2012sel's Avatar
Fan#: 84814
Advanced Auto parts has 5 quart Motorcraft 5W20 for 14.99 on their website.
Current
Past Rides
2012sel is offline
Old 12-31-2011, 07:25 PM   #19
jbird1955
jbird1955's Avatar
Fan#: 48235
What I Drive: 2012 Red Candy Ti Hatch
FF Reputation: 1 jbird1955 Good Standing Member
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!ALWAYS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!ALWAYS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!ALWAYS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!PRECHARGE YOUR NEW OIL FILTER WITH FRESH OIL!!!!!!!!!!
Do this to ANY new oil filter you install, even if it's a horizontal mount (and of course put a little oil on the gasket).
One other item is to make sure the old gasket came off with the old filter. I had that happen to me once many moons ago.
But please, charge the filter with new oil before you put it on. Much better and safer than cranking the engine before hand.
Joe
Ford Focus 2012 Hatchback 400A Titanium w/ Moonroof
Red Candy Metallic
jbird1955 is offline
Old 01-01-2012, 10:15 AM   #20
Dgc333
Fan#: 85422
What I Drive: 2012, candy blue, SEL
FF Reputation: 1 Dgc333 Good Standing Member
In the 40+ years I have been changing my own oil I have never pre-filled an oil filter. This included all through high school and college working in a garage where no one pre-filled oil filters
My vehicles all have gone 250-300k miles before I have gotten rid of them and I have never had an internal engine failure.
Certainly not a bad idea but I don't feel the benefit out weights the nuisance factor.
Dgc333 is offline
