MK3 2012 Focus - Oil Change 101 - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-07-2012, 05:42 PM   #91
lolpetewtf
Fan#: 94906
What I Drive: 2007 BMW 328i coupe
FF Reputation: 1 lolpetewtf Good Standing Member
Originally Posted by dan50 View Post
While it doesn't matter much, I remove the oil filter first. Then I can install the new filter while the crankcase drains.
Once the engine has run for a minute or so, rev it to around 2,000 RPMs for a few seconds. This will build oil pressure to near its maximum level and may identify leaks that wouldn't occur at idle.
I don't preload the filter because it's messy and it introduces a batch of unfiltered oil into the engine. If you want to avoid some of the start-up clatter crank the engine for a few seconds with the accelerator floored. Gas is shut off when you do this but the oil pump should fill the filter.
Changing your own oil shouldn't jeopardize your warranty but make sure you keep receipts for oil and filter and record date and mileage. To be extra careful, take a picture of the oil, filter and receipt and email them to yourself. This is harder to lose and also gives evidence you used oil that meets Ford's specs (WSS...945 - see owner's manual).
lol whatttttttttt
lolpetewtf is offline
Old 03-07-2012, 08:16 PM   #92
greg hazlett
Fan#: 93486
What I Drive: 2012 Black Ford Focus SE Hatchback
FF Reputation: 3 greg hazlett Good Standing Member
Originally Posted by got3fords View Post
I will NEVER use a "quickie" oil change place again. Their quality of work sucks. Their knowledge of the vehicle and simple mechanical knowledge is severely lacking. Those places have made one too many SIMPLE yet potentially damaging mistakes for me to ever go back.
THIS +100000!
Plus how much is your time worth? True, they have the express lane but you are still going to be there for at least an hour, probably more and you are at their mercy whereas if you do it yourself you are on your schedule.
I had the oil changed at 1K on my mustang to have the break in oil removed at the dealership where I bought it; you would think the dealership of all people would know how much oil should go in a mustang and take a wild guess of who put 2 qts too much oil in my car? Yep, you got it!
I would much rather possibly pay a couple of bucks more to know it was done right, done when I wanted to do it and if something was done wrong only having to look in the mirror to figure out who done it.
greg hazlett is offline
Old 03-07-2012, 08:47 PM   #93
mrwhistles
Fan#: 90684
What I Drive: 2012 Yellow Blaze Titanium HB
Points 163, Level 3
Points: 163, Level: 3 Points: 163, Level: 3 Points: 163, Level: 3
Level Up 26% Completed
FF Reputation: 1 mrwhistles Good Standing Member
Thanks for the heads up on the wrench size and the T30. Using my drill to deal with the 8 screws, I probably had this done in 15 minutes flat.
Advance auto parts was doing the 5qt mobil one and filter for $32.99 so I hopped on it and knocked this out at 1512 miles.
2012 Yellow Blaze Focus Titanium HB. 400A. Painted and polished Wheels.
2001 Mustang GT Convertible.
mrwhistles is offline
Old 03-07-2012, 09:01 PM   #94
pkj099
Fan#: 94997
What I Drive: 2012 Focus Titanium
FF Reputation: 1 pkj099 Good Standing Member
That felt thing is the stupidest feature ever. Nice job ford.
pkj099 is offline
Old 03-07-2012, 09:11 PM   #95
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,035, Level 33
Points: 3,035, Level: 33 Points: 3,035, Level: 33 Points: 3,035, Level: 33
Level Up 90% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
Originally Posted by lolpetewtf View Post
lol whatttttttttt
You mean the messy part? Oh, probably the unfiltered oil part. Well, the area where you'd pour oil into the filter is where oil exits to the engine. So, the oil you pour in hits the engine without the edit of filtration. This probably doesn't matter, but manufacturing is imperfect and people have a way of knocking things into open containers, so bad stuff could get in there. A bit of sand could do bad things to a bearing...
Again, unlikely but not impossible.
dan50 is offline
Old 03-14-2012, 05:15 PM   #96
CourtneyNYC
Fan#: 86057
What I Drive: 2010 - Sterling Gray&2012 White Ti
FF Reputation: 1 CourtneyNYC Good Standing Member
It's actually a pretty amazing piece of engineering. It's been on high priced cars for years . . . neat to see Ford deploy it on the Focus.
The first time it took me perhaps 5 minutes, finding the right bit and so forth. The 2nd oil change the felt was gone in less than 60 seconds.
It's nice to see American engineering at work.
2010 - Sterling Gray - SEL
2012 - Titanium - White Platinum Tri-Coat (SOLD 9-15-2012)
2013 - Escape Titanium - White Platinum (Delivered 9-15 )
CourtneyNYC is offline
Old 03-14-2012, 06:25 PM   #97
Focus805
Fan#: 90582
What I Drive: 2012 Frosted Glass SEL HB 300A
Points 740, Level 14
Points: 740, Level: 14 Points: 740, Level: 14 Points: 740, Level: 14
Level Up 40% Completed
FF Reputation: 1 Focus805 Good Standing Member
I agree. The felt is a very clever solution. My VW Eurovan used a steel screen that weighed a ton and was a real mess to remove and replace. The felt does the aerodynamics job and is lightweight. We'll see how durable it is.
Focus805 is offline
Old 04-09-2012, 12:01 PM   #98
pvial
pvial's Avatar
Fan#: 97458
What I Drive: 2012,Blue Candy, SE, Hatchback
Points 10, Level 1
Points: 10, Level: 1 Points: 10, Level: 1 Points: 10, Level: 1
Level Up 19% Completed
FF Reputation: 1 pvial Good Standing Member
Thanks
Very helpful post.... thanks a bunch!!
pvial is offline
Old 04-10-2012, 09:54 AM   #99
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 124,710, Level 100
Points: 124,710, Level: 100 Points: 124,710, Level: 100 Points: 124,710, Level: 100
Level Up 0% Completed
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
My Subie had a heavy plastic windage tray under the engine. The question I have is (slightly off topic)... Could you replace the felt with an APR diffuser? Is the bottom of the bumper flat enough?
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
Old 04-10-2012, 10:50 AM   #100
2012sel
2012sel's Avatar
Fan#: 84814
What I Drive: 2012 Red Candy SEL 5 door
FF Reputation: 10 2012sel Great Standing Member
The felt doesn't go all the way to the front of the car. There's a plastic piece from the radiator to the bumper cover that isn't removed when you do the oil change. It's fairly flat. Check this post for a visual of the part...
http://www.focusfanatics.com/forum/s...9&postcount=19
Current
2012 SEL 5 door w/Premium Package - April 2011 | 1957 Chevrolet 3200 - 2005
Past Rides
2000 F150 Sport 2000-2011 | 1988 Ranger XLT 4wd 1988 - 2000 | 1966 Mustang 1983 - 2008 | 1963 Ford Econoline Van 1979 - 1983
2012sel is offline
