How to replace dog bone mount. - Focus Fanatics
Old 12-19-2011, 12:18 PM   #1
Ispi
Fan#: 44846
What I Drive: 2003 Silver Focus SE (SPI-SOHC)
FF Reputation: 1 Ispi Good Standing Member
I have recently replaced both the driver's side and passenger side front motor mounts. Having some trouble with the dog bone. I can get the bolts out, but can't quite rock the engine forward enough to get the old mount out. Considering the following:
  • Loostening the 4 bolts on the drivers side mount.
  • Loostening the 3 bolts on the passenger's side mount.
  • Loostening the air intake from the airbox.
Does this seem wise? I just need another inch to get the old tranny dog bone out. Any help would be appreciated. Don't want to pinch the new mounts and have to replace them latter.
P.S. I strongly recommend anyone doing the mounts to replace the dog bone 1st.
Ispi is offline
Old 12-19-2011, 12:26 PM   #2
FocusFreak09
Flat Black King
FocusFreak09's Avatar
Fan#: 51243
What I Drive: 2001 Chevy Silverado
FF Reputation: 30 FocusFreak09 Great Standing Member
Buy-Sell-Trade Rating: (9)
All i did was maybe rock the engine a lil bit and mine came out. Mine was easy. Now putting the old one back in with new poly bushings was hard. Took that one back out and the stock one fit back in. I would wiggle the mount around too
R.I.P. Izzy
R.I.P. Flat black focus
Stretch&Poke=
FocusFreak09 is offline
Old 12-19-2011, 12:29 PM   #3
alz focus
Fan#: 67546
What I Drive: 2002 Blue SE
FF Reputation: 5 alz focus Good Standing Member
Remove the bolts on the pass side and you should have enough room and flexibility to rotate the motor forward.
Al
2002 Focus SE Zetec ATX
2000 Focus SE SPI ATX
2006 Freestyle SEL AWD
alz focus is offline
Old 12-19-2011, 12:37 PM   #4
Ispi
Fan#: 44846
rocking the engine for dog bone replacement
Thanks Al
So I just need to loosen the 3 bolts on the passenger's side mount.
This forum answered my question quickly.
Ispi is offline
Old 12-19-2011, 12:38 PM   #5
Nickgt40
Wheel King, Bow Down
Nickgt40's Avatar
Fan#: 40924
Location: Annoying the Liberals, California, United States
What I Drive: 01 Black ZX3, 09 FSWerks SEMA Coupe
FF Reputation: 19 Nickgt40 Great Standing Member
The ATX doesn't have a braket that the MTX does which holds the lower mount into place.
Which transmission do you have?
Also, having poly mounts up top definitely inhibits the movement of the motor more than stock mounts (even new ones)
Feb 2011 Ride of the Month ~ 2011 Hatch Nation Hatch of the Year ~ 2011 Focus Fanatics Ride of the Year!
Hatch Nation #2
Nickgt40 is offline
Old 12-19-2011, 12:54 PM   #6
Ispi
Fan#: 44846
Vehicle info
My bad. Forum rules do state that we must indicate the vehicle type.
I have an 03 SPI with automatic trans.
Changing the front motor mounts has made a world of difference.
Ispi is offline
Old 12-19-2011, 01:23 PM   #7
norcalfocus01
Fan#: 55603
FF Reputation: 132 norcalfocus01 Excellent Standing Membernorcalfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Wrong. There's a bracket there on the auto.
Yes you want to remove the bracket to get the dogbone out. Its much easier. Its two 13mm bolts.
norcalfocus01 is offline
Old 12-19-2011, 01:48 PM   #8
Ispi
Fan#: 44846
Dog bone bracket
Was hoping not to need to remove the bracket.
The bolts look very hard to get at. I could try to borrow a 13m ratcheting wrench.
Just popped the hood. Looks like the exhaust manifold heat shield has very little clearance from the radiator fan. Think I will try again to replace the dog bone without removing the bracket after removing the fan and loosening the 3 passenger mount bolts.
Will post back. Feel foolish if that was the problem.
Ispi is offline
Old 12-19-2011, 02:05 PM   #9
norcalfocus01
Fan#: 55603
The top one you can get at with a 13mm socket from the top. The bottom I use a box end wrench to break it loose then the socket to get it off.
Old 12-19-2011, 02:22 PM   #10
Ispi
Fan#: 44846
Words of wisdom
O.K. you are the expert. Will try this 1st. Thanks in advance!
Ispi is offline
